Winter Storage #153391
08/26/08 12:32 AM
08/26/08 12:32 AM
Minnesota
ryanm Offline OP
ryanm  Offline OP
Minnesota
Living in Minnesota we can have some pretty cold winters and I have to store my cat outside. Besides putting a tarp over the entire boat what other precautions should I take when leaving it outside? What damage can be done if it is in below zero weather? Any input helps.
Re: Winter Storage [Re: ryanm] #153392
08/26/08 05:30 AM
08/26/08 05:30 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Take tramp off - snow can get heavy
Keep water out of the hulls
Look up, try to not store under trees - falling limbs
Put all misc stuff in the house (sails, lines, boards, and blocks)
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Winter Storage [Re: ryanm] #153393
08/26/08 05:32 AM
08/26/08 05:32 AM
japan
erice Offline
erice  Offline
japan
my nacra spent upwards of 10 winters disassembled and upside down under 3-6 feet of snow under some trees. the mast was tied to 1 of the trees
there appears to have been no damage from that, but it did get osmosis bubbles in the gelcoat from 1 summer of being moored
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Winter Storage [Re: erice] #153394
08/26/08 07:07 AM
08/26/08 07:07 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Take yer cat OFF the trailer. My 17 hulls had the back rollers crush into the hulls on both sides.~repair job~. After that I built a ''A'' frame over my cats. It's a pain to take the tramp off of a 17. I now do it with all my cats. It's on TheBeachcats.com site~~ Tech. help gallery (see attachment here)
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: Winter Storage [Re: ryanm] #153395
08/26/08 10:45 AM
08/26/08 10:45 AM
Lake Norman, NC
Special_Treat_P182 Offline
Lake Norman, NC
I HIGHLY agree with 'popeyez7' on the no rollers thing! I made 18-inch-long padded/carpeted hull cradles from the same piece of scrap sewer pvc tube that's the storage tube.
Strip the boat of EVERYTHING. Down to just fiberglass hulls and crossbars (remove any barberhauler cleats screwed to crossbars). Cover any remaining exposed cleats (downhaul riveted to mast) with Hefty lawn and leaf bag, but poke holes in the bottom of the bag to allow for drainage. Drive the trailer tire over Hefty lawn and leaf bags, pull them up and over and tie them off to protect the tires from UV wear. Unplug the drain plugs and tape over the holes with nylon screen door meshing (cheap at Lowes). You WANT airflow through the hulls to allow for condensation to not build up, but don't let mice use your hulls as a winter hibernation home. Mice can easily fit through your drain holes and a cat hull is PERFECT for building a nest. NO tarps! It'll only catch rain/snow and weigh down and a polytarp the rubs on the hulls from a little wind will wear off and stain the hulls.
Just remember that fiberglass and aluminum with airflow is fairly impervious to weather/cold. It may get a little dirty, but is easily cleaned off in the Spring.
Re: Winter Storage [Re: popeyez7] #153396
08/26/08 10:52 AM
08/26/08 10:52 AM
Wow that looks bad!
any pics of your a frame in action?
Re: Winter Storage [Re: popeyez7] #153397
08/26/08 10:53 AM
08/26/08 10:53 AM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
If you take your boat off the trailer, make sure you tie it down.
I learned that the hard way last winter.
Re: Winter Storage [Re: erice] #153398
08/26/08 11:34 AM
08/26/08 11:34 AM
Minnesota
ryanm Offline OP
ryanm  Offline OP
Minnesota
Do the 5.2 get really bad when moored (thought about doing that next year)
Re: Winter Storage [Re: ryanm] #153399
08/26/08 11:43 AM
08/26/08 11:43 AM
none of these cats should be moored really.
Re: Winter Storage [Re: PTP] #153400
08/26/08 11:47 AM
08/26/08 11:47 AM
Minnesota
ryanm Offline OP
ryanm  Offline OP
Minnesota
isnt there a new gelcoat or some type of paint for older fiberglass hulls that stops water from being able soak through the gelcoat, some guy at westmarine was trying to get me to buy this for my monohull a bit back.
Re: Winter Storage [Re: ryanm] #153401
08/26/08 01:28 PM
08/26/08 01:28 PM
brucat Offline
brucat  Offline
Mooring causes all sorts of issues. Besides marine growth, the motion of the waves will work on the hull/crossbar connections, eventually loosening the whole boat.
Re: Winter Storage [Re: brucat] #153402
08/27/08 06:22 AM
08/27/08 06:22 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Hey Andy... No I don't have any picts of the 'A' frame. I'll get some for this yrs storage coming up in October.
PTP & brucat are right.. don't moore it. My neighbor lost his mast~~ <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> one of the shrouds broke and yer cat will rock & roll too much~~~~ ya ROCK & ROLL while sailin it~~ so go ROCK & ROLL..... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
~17,18 Hobies,
~2 Kayaks~
Re: Winter Storage [Re: ryanm] #153403
08/27/08 08:56 AM
08/27/08 08:56 AM
srm Offline
srm  Offline
I think using a tarp to cover the boat is ok as long as you make sure it's pulled tight so that it doesn't collect snow or rain water. Be sure to remove any snow that does happen to accumulate.
Loosen or better yet, remove the tramp, and remove any lines. All the hardware/fittings are impervious to weather/cold.
One other thing that I do that I didn't see mentioned is that I like to put my trailer up on blocks so the wheels are off the ground. I'm not sure whether it matters, but I just don't like the idea of having the wheels sit loaded in one position for several months in a row.
sm
Re: Winter Storage [Re: srm] #153404
08/27/08 01:05 PM
08/27/08 01:05 PM
brucat Offline
brucat  Offline
The ultimate answer is to store it indoors (barn, garage, basement, storage shed, etc.). This may mean taking the boat apart, but it is the best solution for areas prone to lots of snow.
Re: Winter Storage [Re: brucat] #153405
08/27/08 03:13 PM
08/27/08 03:13 PM
Minnesota
ryanm Offline OP
ryanm  Offline OP
Minnesota
Well i can store it in a garage but the door frame isnt large enough to fit the boat in, how hard is it to disassemble the cross beams so that the boat could fit in?
It would be a nacra 5.2 that i would have to disassemble
Re: Winter Storage [Re: ryanm] #153406
08/28/08 01:43 AM
08/28/08 01:43 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
chain saw 'VS' door frame guess who'll win ~~LOL <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
~17,18 Hobies,
~2 Kayaks~
Re: Winter Storage [Re: popeyez7] #153407
08/28/08 01:49 AM
08/28/08 01:49 AM
japan
erice Offline
erice  Offline
japan
my nacra 5.2 comes apart every year for winter breakdown
if yours hasn't come apart for some make sure that you can "crack" all &#65297;&#65302; beam bolts get them all turning a little before pulling any of them out
want to make sure you don't turn the captive nut in the glass
eric e
2009 weta tri - 294
Re: Winter Storage [Re: erice] #153408
08/28/08 08:04 AM
08/28/08 08:04 AM
NEVER had to deal with that before, BUT last winter has different. Only snow a few days, but I am boatlees this winter. Will get something worked out before next
Doug
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
