nacra 5.2 hull spidering #153743
09/01/08 01:45 PM
09/01/08 01:45 PM
Moses Lake, WA
apettit7 Offline OP
apettit7  Offline OP
Moses Lake, WA
The spidering is very stiff - no give or noises when I push.Is this worth repairing? Or is its location a mark of a doomed boat? [Linked Image]
Re: nacra 5.2 hull spidering [Re: apettit7] #153744
09/01/08 02:22 PM
09/01/08 02:22 PM
France
pepin Offline
pepin  Offline
France
That is probably superficial gelcoat cracks due to some approximate tightening of the beam straps. The strap we see seems to be overtightened (the bold twisted the strap on the left side). If the inside strap is not as tight the hull would move against the beam and generate this kind of failure.
Sand the cracked gelcoat over and if there is no crack in the polyester below simply cover with a new layer of gel coat. When you mount the beam after that add a small amount of silicone between the beam and the hull to help distribute the load better, and use a torque wrench to tighten everything equally.
Re: nacra 5.2 hull spidering [Re: pepin] #153745
09/01/08 07:26 PM
09/01/08 07:26 PM
UK
Cheshirecatman Offline
UK
To spread load:
Silicone - No
Thickened epoxy or polyester resin - Yes
Wax or tape beam before bedding in resin and only lightly tighten beam until resin has cured. A washer at the sides of each hull under the beam will allow a good 'bed' of resin.
Cheshirecatman
Re: nacra 5.2 hull spidering [Re: apettit7] #153746
09/02/08 04:25 AM
09/02/08 04:25 AM
DHO Offline
DHO  Offline
[Put on flame suit]
I always thought the NACRA beam straps was a goofy way to do things. To my way of thinking, it allows movement of the hull with respect to the crosstube about the axis of the crosstube, and also allows movement parallel to the axis. Apparently it (usually) does the job though.
DHO
TheMightyHobie18 1067
Re: nacra 5.2 hull spidering [Re: DHO] #153747
09/02/08 05:26 AM
09/02/08 05:26 AM
France
pepin Offline
pepin  Offline
France
[Put on flame suit]
You do not need a flame suit. It's a ridiculous way of mounting beams. Bolting the beam through is so much easier and prevents the problem of rotating beams.
0 registered members (), 321 guests, and 55 spiders.
