| What cat has the best halyard lock system? #15383 01/14/03 01:41 PM 01/14/03 01:41 PM |
Joined: Sep 2002 Posts: 273 Key Largo, FL MaryAWells OP
Posts: 273 Key Largo, FL | By "best" halyard lock system, I mean the easiest to hook and unhook, both on land or on water.
Mary A. Wells
| | | Re: What cat has the best halyard lock system?
[Re: MaryAWells]
#15384 01/14/03 02:01 PM 01/14/03 02:01 PM |
Posts: 744 | The ones with a HALYARD!! Hobie 14/16/Wave  Bob Curry
[Re: Bob_Curry]
#15385 01/14/03 02:18 PM 01/14/03 02:18 PM |
Posts: 273 Key Largo, FL | Thanks for saying it so well, Bob. I was going to point that out in my question and exclude those as candidates, but then what would be left to say?
All the higher-tech cats and bigger cats seem to have internal halyards. So of that internal-halyard group of cats, which has the best halyard lock?
And if none of them has a "best" halyard lock, why doesn't somebody invent something that works better -- that WILL work with an internal halyard?
Somebody mentioned the Supercat having its halyard lock at the bottom of the mast, inside the sail track. Is that correct?
Mary A. Wells
| | | The hardest has to be...
[Re: MaryAWells]
#15387 01/14/03 04:30 PM 01/14/03 04:30 PM |
Posts: 1,253 Columbia South Carolina, USA | The Super Cat 20 with halyard and bolt rope both running down the same slot. Mine was so hard, it is the main reason for me selling the boat. But once it was up, what a sweet ride!!!
David Mosley
[Re: MaryAWells]
#15392 01/15/03 01:36 AM 01/15/03 01:36 AM |
Posts: 51 australia | i would have too say the  taipan  has the best halyard loking system i all ways unhook it on the water with ezz even in 25knots of wind,  regards kurt taipan 4.9 aus 029 | | | Re: What cat has the best halyard lock system?
[Re: carlbohannon]
#15395 01/15/03 09:22 PM 01/15/03 09:22 PM |
Posts: 344 Arkansas, USA | Carl- I don't know who you are referring to in your description of the "Taipan system" sail raising (It's more accurately the "A" cat system since it originated and is still predominate in that top level development class)? This certainly does NOT describe the normal procedure for raising the mainsail on the Taipan/"A" cats. After struggling with internal halyards on Nacras, Prindles and Hobies (of which I have to say I much prefer the external halyard with a good old stop on the wire!) I personally love not having to worry about the halyard disappearing up the mast, breaking (one of my old 18sq. buddies was notorious for breaking external halyards- both the wire, stops and "hooks"- with his 20:1 downhaul!!), coming untied, getting the knot "right", etc. With proper technique (and no mud dobber nests in the mast!) I have not had problems and have done on the water even single-handed (but if I HAD to raise/drop sails on the water with the boat upright- since you can always flip and drop/raise in an emergency- I would like a good old wire external halyard). The Taipans come with a small block at the mast head for a halyard but most owners find no need for it in my experience. The Auscat and Flyer "A" cats do NOT come with even this small block. My old 1986 "A" cat has an interesting halyard system- It uses a ring that hangs down from the masthead that engages a "hook" that faces forward and is bolted to the head of the sail. I use a 1/16" Spectra line as a halyard that runs through a tiny block on the side of the mast- so it's an external halyard but extremely small.
Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
[Re: carlbohannon]
#15398 01/16/03 01:26 PM 01/16/03 01:26 PM |
Posts: 344 Arkansas, USA | Carl- Sorry, I didn't recognize the humorous intent (if you had added "novice Taipan sailor" then I probably would have gotten it as I have been asked many times "Where's the halyard on this thing? You get the sail up HOW??" And then I get to demonstrate  ). Just get tired of the Taipans getting "flamed" and fully expected someone else (not you) to jump on your post as another reason to flame them- Thanks for clarifying- I CAN relate to the Tornado humor since that's also true of the 18 square meter I used to have!! Of course we have all declined to mention the venerable Aquacat- I'm not even sure if the correct name for the line that raises the top prtion of the lateen rig is "halyard" or not- Funniest thing I ever saw related to novices sailing was the newbie who hosted his sail UPSIDE down (now THAT"S a squaretop  ) and then walked down the beach to ask me where this pole thingy (boom) goes  . Kirt
Kirt Simmons
[Re: DanWard]
#15401 01/16/03 03:17 PM 01/16/03 03:17 PM |
Posts: 273 Key Largo, FL | Dan, I was hoping somebody would bring this up. Apparently, if mast compression is a problem, it does not bother Bill Roberts, designer of the Supercats, since their halyards attach at the bottom of the mast. Maybe compression is not as much of an issue if the halyard comes down the aft side of the mast through the sail track, rather than down the front of the mast? I have no idea.
And I have been told that the problem with external halyards that attach at the top of the mast on the forward side (Hobie 14, 16, Wave) is that with the larger, more powerful sails, it puts too much strain on the sheave(s) at the top of the mast and on the cable that has to bend over those sheaves. Seems as though those are problems that could be easily overcome, as Hobiegary described in the thread about "reefing points."
One problem we used to have back in the 1970's with using the Hobie 16 system (but on the Sizzler catamaran) was that the swaged balls on the cable portion would not always hold under a lot of pressure, and the ball would slip on the cable.
Seems like the ideal would be to be able to use a hook and ring at the front of the top of the mast, with the hook facing down. And you could even have two rings, at different levels on the cable, so you could easily reef. BIG PROBLEM: How do you get the ring(s) through the hole and over the sheave to get it to the front? Hmmm. Guess I have to dream on this a while. Maybe a bigger fork-type cleat on the mast and use thin, non-stretch line instead of cable, and use a knot to hold it in the "cleat." ??? You could have as many knots as you needed at different levels, too, for reefing purposes. (Line probably would have to be replaced fairly often, since knots weaken a line at the knot point.)
But even if the problems could be solved for cleating on the front top of the mast, you still have that halyard coming down on the outside of the mast and creating, heaven forbid, windage.
Mary A. Wells
[Re: MaryAWells]
#15402 01/16/03 04:35 PM 01/16/03 04:35 PM |
Joined: Aug 2002 Posts: 164 The Netherlands (North West Eu... RobLammerts
Posts: 164 The Netherlands (North West Eu... | I Currently own a Nacra 6.0 and I do not have any problems with the hook and ring system, before the Nacra I owned a dart with the same system. I do not have problems not on the water or on the land. The most important is that the cat is facing the wind at all times. I have seen many sailors who cursed the ring and hook system but I usually got the problem solved for them in one go. I do not want to brag but I think it is something you must have a feeling fore.
Rob
Nacra 6.0 European version
Nr 090 + Spi
22,305
guests, and 506
