| Re: 4 to 1 main sheet with 2 to 1 fine tune cascade
[Re: waynemarlow]
#154033 09/04/08 04:41 PM 09/04/08 04:41 PM | Anonymous
| Anonymous
Unregistered | I've sailed Ts with a similar set up and yes it does work. But I wouldn't recommend it. To many ropes. The best system I've used had the ends of the 2:1 split port and stbd from the boom and tied off onto the side stays. Put a small ball or stopper knot just outboard of the blocks at the forward end of the boom so the "lazy" sheet doesn't pull through. When you get the setup right the lazy sheet will have just enough slack to rest on the tramp.
You won't get 4:1 at the back it will have to be 3:1 or 5:1 | | | Re: 4 to 1 main sheet with 2 to 1 fine tune cascade
[Re: bobcat]
#154034 09/04/08 04:43 PM 09/04/08 04:43 PM | Anonymous
| Anonymous
Unregistered | Wouldn't the 2:1 be the coarse trim and the 4:1 the fine trim? And are you also intending to increase to 8:1 advantage? The 2:1 picks up the dead end of the 4:1 making it 8:1. As mentioned above, 4:1 doesn't work, it will be 3:1 or 5:1. | | | Re: 4 to 1 main sheet with 2 to 1 fine tune cascade
[Re: waynemarlow]
#154038 09/05/08 05:51 PM 09/05/08 05:51 PM | Anonymous
| Anonymous
Unregistered | I can't remember ever doing a large scale dump to avoid a capsize upwind, that is what the tiller is for. Also with the proposed system the skipper will still hang onto the course main and/or the traveller, so that can be dumped at any time. | | | Re: 4 to 1 main sheet with 2 to 1 fine tune cascade
[Re: waynemarlow]
#154040 09/06/08 04:55 PM 09/06/08 04:55 PM | Anonymous
| Anonymous
Unregistered | If you race single handed don't do it. The hassle of letting go of one rope (course/traveller) so it can then wash overboard to then have to reach for another rope will be far more hassle than a slightly longer mainsheet.
My imaginary F16 (the one I've been threatening to build four quite a while) will have a tornado style internal cascade main, primarily because it will be much cheaper than the big blocks required to make a conventional 8:1 main. | | | Re: 4 to 1 main sheet with 2 to 1 fine tune cascade
[Re: ]
#154041 09/07/08 05:25 AM 09/07/08 05:25 AM |
For anyone interested.
I've been thinking for quite some time about a different path to make mainsail sheeting easier.
I've noticed that holding the sheet saps strength for when you want to sheet in. Basically, we are all strong enough to sheet the sail if we can fully relax afterwards. This means the line needs to be held in place by some system like a cleat or ratchet system that takes more of the line load then it currently does.
I'm not at all satisfied with the ratchet holding power on todays mainsheetsystems. The less then 90 degree wrap around the ratchetted sheeve does help here. I already use a tapered mainsheet and that was a large improvement in itself.
So two approaches are
-1- Make a full wrap around the standard ratchet with the sheet going to a small block on the boom just in front of the mainsheet system and then along the boom to a midboom sheeting point. The full wrap will at least improve the holding power by a factor of 2; which is alot
-2- Have the top block of the mainsheet include an auto ratchet (with also an auto ratched in the lower block). This way the mainsheet setup reflects the spi double ratchet setup and the holding power will be quite large but still have the sheet run very smoothly at lower line tensions (sheeting out).
538
guests, and 576
