Dings and Dents #155086
09/15/08 09:27 AM
09/15/08 09:27 AM
Edmonton, Alberta, Canada
bobcat Offline OP
bobcat  Offline OP
I am afraid that I started something slightly ugly when I mentioned how knees and elbows dent my hulls. This segued into a full on beach invasion type landing. Later on Matt M mentioned fairing out dents. How is this done?
Does one slop on gelcoat like he is repairing drywall?
I know that with automotive paint that there are a zillion colors of white. Does one need to find the right gelcoat for the best color match?
Up till now, I have been using Marine-tex to repair rudder dings, etc but I haven't tried fairing out dents in a foam cored boat. I have read about people doing bottom jobs but what about these smaller repairs.
Re: Dings and Dents [Re: bobcat] #155087
09/15/08 04:05 PM
09/15/08 04:05 PM
I use an ultralight body filler.
My "white" gelcoat seems to have a small amout of yellow tint, usually availble at your marine store.
Re: Dings and Dents [Re: fin.] #155088
09/16/08 08:07 AM
09/16/08 08:07 AM
UK
Cheshirecatman Offline
UK
Automotive body fillers use talc which retains moisture and should not be used for marine use. You can mix your own lightweight filler by adding glass bubbles to resin or you can use a propriety marine filler such as International Watertite.
Cheshirecatman
Re: Dings and Dents [Re: Cheshirecatman] #155089
09/16/08 09:37 AM
09/16/08 09:37 AM
bobcat Offline OP
bobcat  Offline OP
Both of these solutions would then require some painting? Interlux is the equivalent of International here in the colonies.
In the land locked prairies there is no such thing as the local marine store. Tractor parts we got, boat parts not so much.
Re: Dings and Dents [Re: bobcat] #155090
09/16/08 10:30 AM
09/16/08 10:30 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
You can mix your gelcoat (or repair material) with an acrylic tint ... from your local paint and crafts store.
I'll have to look at what color I picked up ... matched the Blade gelcoat pretty good with just a couple of drops [you'll need to experiment a bit to get the closest shade of "white"]
USA 777
Re: Dings and Dents [Re: tback] #155091
09/16/08 11:22 AM
09/16/08 11:22 AM
JJ_ Offline
JJ_  Offline
You did not start something ugly, BC.
It's just education.
Instructions on how to use a product, what ways not to use it or what ways to avoid using it, and how to maintain it if a problem should happen.
Cool headed, nothing more. The only way it gets ugly is if you give hotheaded responses credibility by responding to them in any way less than positively, IMO.
And that's my last public thought on this! Smile, it's a beautiful ocean out there, isn't it? I'd love to be on it everyday if I could. It's just work and bills that interfere...
Re: Dings and Dents [Re: JJ_] #155092
09/16/08 01:55 PM
09/16/08 01:55 PM
bobcat Offline OP
bobcat  Offline OP
Through the powers of YouTube I have discovered some instructional videos. West has their own series but I felt that Tap plastics was more suitable for this occasion.
Haven't figured out the embedded video thing so here is the link.
Re: Dings and Dents [Re: bobcat] #155093
09/17/08 05:51 AM
09/17/08 05:51 AM
Tornado_ALIVE Offline
Perhaps Marcus or Phill could confirm but I have been told that if you heat the dent with a hair drier not long after it has happened, it will return to it's original state. Be carefull not to blister the gelcoat. Should be OK with a hair dryier but take cation with a heat gun.
Re: Dings and Dents [Re: Tornado_ALIVE] #155094
09/17/08 06:18 AM
09/17/08 06:18 AM
Marcus F16 Offline
Marcus F16  Offline
Steve - I have heard of this method too. It was some time back & i would have thought would depend on the type of foam to get the best result.
What type of foam i am not sure. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Marcus Towell
0 registered members (), 641 guests, and 43 spiders.
