Replacement Parts for a Hobie Getaway, Dolly,Sail #155604
09/21/08 11:27 PM
09/21/08 11:27 PM
V
Vance Offline OP
Vance  Offline OP
V
Has anyone had any luck finding replacement pins, etc. for their Hobie Getaway that are non-Hobie brand (ie - not overpriced but same/better quality)? Also, the batten pockets in the mainsail have worn areas/holes where the mainsail hit the rigging (purchased mine used). Should I have someone sew an extension to the clear vinyl protectors already on the mainsail or will invisible sail tape do? Finally, has anyone purchased a dolly for their Getaway and if so, can you operated it fairly easily given the weight of the cat?
Re: Replacement Parts for a Hobie Getaway, Dolly,Sail [Re: Vance] #155605
09/22/08 07:33 AM
09/22/08 07:33 AM
Pins, ring-dings, shackles, etc. are all very generic and available anywhere sailing goods are found. West Marine, here at www.OnlineMarineStore.com, Layline.com, etc.
As far as the sail holes from the rigging goes, Sticky-back Dacron tape works great for those areas.
0 registered members (), 771 guests, and 442 spiders.
