buying a new hobie 16 #155965
09/24/08 05:36 PM
09/24/08 05:36 PM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
hello, everyone! my first post.
I am considering purchasing a new Hobie 16 and was wondering if anyone who had experienced this knew if there were any options or upgrades that should be done or would be nice to have.
I asked the dealer to include all the bells and whistles that are available in her estimate.
At the moment I am starting from scratch and will have to purchase anything not included with the boat.
Thanks
Re: buying a new hobie 16 [Re: Flip57] #155966
09/24/08 08:29 PM
09/24/08 08:29 PM
Carbon rudders, 6:1 downhaul, hotstick. Those are about the only upgrades you can do. Get a telo-cat, or some sort of windvane as well.
Re: buying a new hobie 16 [Re: Flip57] #155967
09/24/08 09:37 PM
09/24/08 09:37 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Karl's stuff plus an Hawaiian righting system. You can build them yourself for cheaper.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: buying a new hobie 16 [Re: hobie1616] #155968
09/24/08 09:47 PM
09/24/08 09:47 PM
Karls' stuff, Mikes' stuff, plus...
two "nice" life jackets, two "nice" trapeze harnesses (and a couple of pairs of gloves). Have them explain how the trapeze harness works while you're sailing (sitting down and on the trapeze)and try on the different models they have, in combination with the life jacket. Get what is comfortable for you.
Re: buying a new hobie 16 [Re: _flatlander_] #155969
09/25/08 07:28 AM
09/25/08 07:28 AM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
Thanks for your help
Re: buying a new hobie 16 [Re: Flip57] #155970
09/25/08 01:45 PM
09/25/08 01:45 PM
North Carolina
H
htsailor Offline
htsailor  Offline
H
North Carolina
For a weathervane use 2 pieces of knitting yarn tied to the bridle, one on either side. Costs nothing and works well. Some people use cassette tape but I find that it pulls off when trailering the boat. One other item is non-skid material on the side rails, either carpet or what I use which is strips of non-skid bath rubber tape. Also you should have rubber shoes or booties. When out on the wire you want good footing.
Howard
Re: buying a new hobie 16 [Re: htsailor] #155971
09/25/08 03:52 PM
09/25/08 03:52 PM
A trailer comes in handy when going across land as well <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: buying a new hobie 16 [Re: Karl_Brogger] #155972
09/25/08 10:09 PM
09/25/08 10:09 PM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
that came under the heading of "bells and whistles" but thanks for the comment.
Re: buying a new hobie 16 [Re: Flip57] #155973
09/26/08 01:07 AM
09/26/08 01:07 AM
L
lluistar Offline
lluistar  Offline
L
A security knife for you and one for your crew
Re: buying a new hobie 16 [Re: lluistar] #155974
09/26/08 01:05 PM
09/26/08 01:05 PM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
What about navigation? Do you guys carry a GPS? Are one of those little stick-on compasses worthwhile? I used to be an ocean power boater and I got really attached to my scrolling map gps (although I always had my charts and compass for backup). Do you carry a hand held VHF?
Re: buying a new hobie 16 [Re: Flip57] #155975
09/27/08 04:47 PM
09/27/08 04:47 PM
Syracuse, NY Hobie Fleet 204
Tom Korz Offline
Tom Korz  Offline
Skip the hot stick. Stock stick is lighter and more responsive.
Do not buy any real fancy wind vane.
Don't worry about nav and communication until you start sailing for distance or out of sight of land.
Re: buying a new hobie 16 [Re: Tom Korz] #155976
09/27/08 05:34 PM
09/27/08 05:34 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
I dunno about the hot stick. While the stock stick is lighter and more responsive, I find it to be a nuisance in light air. When I'm in 6-8, I end up in the middle of the boat and the stock stick ends up getting caught in my trap rings. I can shorten the hotstick so it doesn't get stuck in my trap rings and I can sit dead center on the tramp.
12+ with crew and the stock stick is the way to go.
I've got both and switch back and forth depending on the wind.
Re: buying a new hobie 16 [Re: Tri_X_Troll] #155977
09/27/08 09:12 PM
09/27/08 09:12 PM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
Thank you all for all your help. Today I just ordered my 2009 hobie 16 from KO sailing in La Porte, TX. The 6:1 down haul, EPO carbon rudder and the Aussie Jib setup are all stock items now. I would not have thought of asking about them without your help. I will ourfit the remainder of items when it comes in in about 2 to 3 weeks. I hope to see you at a gathering but if not, then here at the forum.
Re: buying a new hobie 16 [Re: Flip57] #155978
09/28/08 04:04 PM
09/28/08 04:04 PM
Tom Korz Offline
Tom Korz  Offline
No one mentioned a carpet kit for the rails.
Re: buying a new hobie 16 [Re: Tom Korz] #155979
09/28/08 09:20 PM
09/28/08 09:20 PM
L
lluistar Offline
lluistar  Offline
L
Isn't carpet standard equipment on a new hobie?
Re: buying a new hobie 16 [Re: lluistar] #155980
09/29/08 09:31 AM
09/29/08 09:31 AM
Strangely enough - no.
Guess there's too much personal preference in what people choose to put on their sidebars - carpet, neoprene, or that knobby EVA foam stuff that I can't remember the name of.
Re: buying a new hobie 16 [Re: mbounds] #155981
10/09/08 10:26 AM
10/09/08 10:26 AM
New Jersey
TopJimmy Offline
TopJimmy  Offline
New Jersey
I would also recommend the hotstick. The stock one bent in half the second time I launched from the beach and splintered.
Re: buying a new hobie 16 [Re: mbounds] #155982
10/09/08 03:48 PM
10/09/08 03:48 PM
hydro-turf
Re: buying a new hobie 16 [Re: _flatlander_] #158630
10/29/08 07:02 PM
10/29/08 07:02 PM
Dewey, AZ
Flip57 Offline OP
Flip57  Offline OP
Dewey, AZ
Note: Hobie does not come with the 6:1 down haul. Will have to add that later. Does come with Aussie jib halyard and EPO carbon fiber rudders.
Re: buying a new hobie 16 [Re: Flip57] #158639
10/29/08 08:52 PM
10/29/08 08:52 PM
If you are using a spinnaker you do not want to mount a windvane of any kind. Unless its a its something like a ribbon on the bridle. The spin will get destroyed hanging up on it. Tape everything you can too. Ringdings, pins, chainplates, anything that the spinnaker can touch.
I didn't think it would make that much of a difference, but coating the snuffer sock, and the spinnaker in the seal n' glide made the chute go up and down way easier. I think that's what it was. It was left over's at a friends house. It was a Homeleko (sp) product
0 registered members (), 3,236 guests, and 277 spiders.
