| Chicken rope/hook #158092 10/23/08 08:38 PM 10/23/08 08:38 PM |
Joined: Sep 2006 Posts: 586 Hobart, Tasmania, Oz. Dazz OP
Posts: 586 Hobart, Tasmania, Oz. | Hi Guys Im looking for some help to improve on our chicken rope system on the capricorn. at the moment we have a line running from the back of the boat with a stainless steel S hook attached. While not in use the spare rope is shock corded into the rear beam. the problem is the hook flapping around the end of the beam catches ropes, not cool. so I want to change it something better. looking though the pictures from the NA's i spoted an infusion with a chicken line running into the rear beam. Can anyone describe or photos of what is inside there? http://www.thebeachcats.com/index.php?module=pictures&g2_itemId=56134&g2_imageViewsIndex=1 full sized image
| | | Re: Chicken rope/hook
[Re: Dazz]
#158109 10/23/08 10:44 PM 10/23/08 10:44 PM |
Posts: 2,490 On the Water | Greetings Darren, How's the new ride been? Are you missing the 5.8?
The hook should be retracted inside the beam. The bungee should be purchased through small blocks attached to the beam caps. Attached to the end of the bungees are becket blocks that the chicken line runs through. This is just one of several ways to do it.
Philip USA #1006 | | | Re: Chicken rope/hook
[Re: Tornado_ALIVE]
#158131 10/24/08 05:03 AM 10/24/08 05:03 AM |
Joined: Jun 2001 Posts: 75 Ljubljana, Slovenia mayhem
Posts: 75 Ljubljana, Slovenia | For distance sailing, you can add two jam cleats on your harness (on either side of the hook)and then just run a line between the two means with a shock cord that keeps it retracted when not in use. Advantage is that it holds you both directions, easy to disconnect, not exposed hooks, and works for 2 people. I think there are some pictures of this system with Jamie Livingston on the Tybee500 report by Rick.
[Re: P.M.]
#158132 10/24/08 05:34 AM 10/24/08 05:34 AM |
Posts: 586 Hobart, Tasmania, Oz. | Thanks for the pictures Philip! they have given me a few ideas.
I wished for the 5.8 a couple of times.. mostly when we were battling to survive in 25+ knots. its been a steep learning curve and the conditions to date have not helped at all.
Yeah Steve, its a drama when the main is hooked on the wrong side of the boat in 25 knots... I would be quite happy to cut them off, but the crew likes them. from what i see in different photos its about a 50/50 between the haves and the have nots. even in the owners manual one boat is displayed with and the next without.
264
guests, and 46
