H16 Rudder Alignment #15845
01/28/03 03:12 PM
01/28/03 03:12 PM
San Ramon, CA
Curt Offline OP
Curt  Offline OP
San Ramon, CA
Looking for advice/info on aligning the rudders on my Hobie 16. I've heard about toe-out and toe-in, but having them parallel sounds best to me. Does anyone know what the distance between rudders should be, front edge vs trailing edge?
Re: H16 Rudder Alignment [Re: Curt] #15846
01/28/03 10:07 PM
01/28/03 10:07 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Hello,
Check the tips on this website. They discuss rudders and other items.
http://www.hobiecat.asn.au/qld/tips/tuningtips1.html
Jack
Re: H16 Rudder Alignment [Re: jmhoying] #15847
01/29/03 06:27 AM
01/29/03 06:27 AM
Bob_Curry Offline
Bob_Curry  Offline
Curt,
I also discuss the alignment in the Updated Hobie 14 Tuning Guide found on this list. The same applys to the Hobie 16. The reason behind a small bit of toe in is the water pressure wants to deflect the rudders outward making them brakes if they are even to begin with. The slight bit of toe in creats the parallel alignment you refer to when you are moving forward.
Hope this helps and have fun!!
Bob Curry
Re: H16 Rudder Alignment [Re: Curt] #15848
01/29/03 09:42 AM
01/29/03 09:42 AM
Flensburg, Germany
Fritz Offline
Fritz  Offline
Flensburg, Germany
Curt,
it depends on the rudders you use!
In general I agree with Bob, however if you have stiff rudders you may sail them extremly foward balanced and parallel. If you have the bendable rudders, you have to toe in and kick up the windward rudder, this reduces spin outs. By the way, see www.hobiefleet32.org! We will organize a training seminar which will cover all of this.
Fritz
0 registered members (), 2,806 guests, and 177 spiders.
