| Re: Shrouds... Coated or Uncoated
[Re: PTP]
#158832 10/31/08 11:25 AM 10/31/08 11:25 AM | andrewscott
| andrewscott
Unregistered | i use slip on covers. They are very cheap and i use 2 - 10' pieces on my 30' shrouds. This allows me to slide them up where any sail/stay friction would be.
they are a bit of a pain to put on (they are easier if left in a back window of a car to warm up and soften) but once on, they easily slide up and down for inspection and can even be totally removed and put back on for inspections.
I have PERSONALLY found ALL the broken strands and concern directly above or around the nicopress or on the swage and never in the middle area..
I was on a boat last weekend in 18knot that demasted from a few broken strands (not my boat)
[Re: wildtsail]
#158842 10/31/08 12:20 PM 10/31/08 12:20 PM |
Posts: 12,310 South Carolina | I peeled the coating off my F18 wires and found that wear on the sail greatly accelerated and that I put a lot of marks, wearing completely through the anodizing, in the mast where it rotates against the shrouds. I would probably still go with uncoated wire but I would put extra chafe protection on the sail and wrap the wires with electrical tape where they contact the mast.
Jake Kohl | | | Re: Shrouds... Coated or Uncoated
[Re: wildtsail]
#158867 10/31/08 01:41 PM 10/31/08 01:41 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Coated wire produce more friction than uncoated. Simple test. grab a coated wire and run your hand up and down it quickly while gripping it firmly. Now do it with a uncoated wire. I think you'll have your answer.
Also coated wire makes the wire larger which adds drag.
[Re: Kris Hathaway]
#158885 10/31/08 05:05 PM 10/31/08 05:05 PM |
Posts: 4,119 Northfield Mn | My FXone came with uncoated wires, I replaced them with uncoated wires. I've been told that injuries in a crash can be greater from uncoated. I doubt it though.
#158887 10/31/08 05:22 PM 10/31/08 05:22 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | On the sail. Friction = Wear. If it's blowing good at some point the main is going to be on the shroud regardless of the boat. I would want mine rubbing on something that has less friction. Older covered wires are worse for it. Rub your hand up and down one and see.
Uncovered wires are lighter.
The only reason for covered wires is they're stylish
[Re: catman]
#158908 10/31/08 10:48 PM 10/31/08 10:48 PM |
Posts: 805 Gainesville, FL 32607 USA | I was recently given some "good" black coated Hobie 18 wires that has been in salt water some years before before being stored for 10(?) years. The trap wires were completely rusted away inside the lumpy coating. The also lumpy shroud wires- equally bad. Didn't trust them: All Shot. I also have some 20-year old used uncoated A-cat wire shrouds and trap wires: They have been sailed in salt and fresh, then left outdoors in the rain for several years. They are good as new: No fishhooks or broken strands.
270
guests, and 50
