| Re: Best material for rail non-skid?
[Re: Cheshirecatman]
#158922 11/01/08 06:11 AM 11/01/08 06:11 AM |
Posts: 1,884 Detroit, MI | Mask off and brush a thin coat of gelcoat then sprinkle crushed glass non-slip and dust off. It's cheap, provides great traction and lasts. Do not use on areas you will be sitting on (or if you intend to sail barefoot) as it will eat your gear. If you want to 'tone down' the abrasive element overcoat again with gelcoat. Remember almost everything in sailing is a compromise.
Cheshirecatman That's way overkill on a Hobie 18. Either neoprene or HydroTurf. Hobie sells a die-cut neoprene kit for the 18 (part #16708) HydroTurf you can get through this site or direct from the mfg: HydroTurf | | | Re: Best material for rail non-skid?
[Re: HMurphey]
#158944 11/01/08 02:28 PM 11/01/08 02:28 PM |
Posts: 5,590 Naples, FL | I would guess surfboard wax is too 'primitive' ?
[Re: waterbug_wpb]
#159041 11/02/08 11:05 PM 11/02/08 11:05 PM |
Posts: 805 Gainesville, FL 32607 USA | Wax? No- Even SexWax comes off immediately: Useless. The harder 1/8 inch Neoprene foam is good. Cork Ball- pointless: Use a cylindrical foam handle-cover for little drag when it is out behind the cat at speed. Some 2 inch wide 3M white non-skid tape is pretty good and lasts for years: not too abrasive. The black stair-step tape will take your skin slap off- down to the blood supply! I know.
298
guests, and 46
