| Re: Infusion Boards
[Re: Andy Humphries]
#160506 11/16/08 09:14 AM 11/16/08 09:14 AM |
Posts: 1,203 uk | They are not really gybing boards, more like twisting boards. Since they stiffened up the boards after the early ones were a bit brittle, they do not seem to twist like as much. With the 1st set that I had, I could really feel an odd lifting sensation once you got them locked in [mostly on flat water] - not so with the newer ones.
| | | Re: Infusion Boards
[Re: GBR6]
#160558 11/17/08 03:52 AM 11/17/08 03:52 AM |
Posts: 1,203 uk | Adrian One minute you are cruising along and the next it all goes blue/green and bubbly! About 20 meters from the finish too! I am pleased to say that nacra upgraded the adjusters after that. I try not to remember the screaming that day - like something from silence of the lambs, but it was the last time I WON some bloody thing too!
| | | Re: Infusion Boards
[Re: TEAMVMG]
#161128 11/22/08 04:26 AM 11/22/08 04:26 AM |
Posts: 36 World Citizen | Guys. Honestly, what do we mean by "gybing" boards and "lifting sensation". A-cat thinking? Ncik's comment is highly relevant. Do they tilt the boards inwards? If so, how much?
Btw. We've only had the "new" boards that are told to be more stiff. No lifting feeling there.
Recent news is that Nacra is from this even moment customising boards for every boat they deliver. This reason is told to be that certain boats have been delivered with boards that don't fit very well. I'm wondering if any tilting is made simultanously.
cheers, jonas
JFR Infusion Mk2
| | | Re: Infusion Boards
[Re: ncik]
#161130 11/22/08 06:27 AM 11/22/08 06:27 AM |
Posts: 52 | Are they being fixed straight with the hulls or at an angle inboard or outboard. I'm not sure, next time I speak with Grant I'll ask him and let you know. | | | Re: Infusion Boards
[Re: JFR]
#161147 11/22/08 01:19 PM 11/22/08 01:19 PM |
Posts: 1,203 uk | If you turn the boat on its side and put the board in, as you push down on it, it will rock on the knuckle in the slot opening so that the leading edge stays where it is but the trailing edge will move to leeward. This is well demostrated by the handsome bloke in the yachts and yachting test on the nacra europe website. the movement is only slight at the exit from the hull, but because the board stays fixed at the top of the hull, it is in effect twisting with a greater angle of attack at the tip. This angle of attack creates lift to windward. No need to raise the windward board because it is doing the same. The downside is that you will get more twist on a windy day when you perhaps want less. i wish that I had kept my old boards and use the new ones on windy days.
| | | Re: Infusion Boards
[Re: ncik]
#161271 11/24/08 01:05 PM 11/24/08 01:05 PM |
Posts: 36 World Citizen | [quote] Shouldn't that be the other way around? Exactly. I'm still lost.
JFR Infusion Mk2
| | | Re: Infusion Boards
[Re: JFR]
#161362 11/25/08 06:49 AM 11/25/08 06:49 AM |
Posts: 1,203 uk | Ok the leading edge does come to windward a little too.
| | | Re: Infusion Boards
[Re: NacraKid]
#161464 11/26/08 10:12 AM 11/26/08 10:12 AM |
Posts: 297 | Grant has had our boards filled in as thats what all the top boys do, as the lift they give is not worth it. Or sumthing like that.
Another thing to do with the infusions is to sikaflex the bungs on as they they stop that leaking.
I'll ask Grant tomorow. Translation, please... R
Nacra F18 #856
| | | Re: Infusion Boards
[Re: NacraKid]
#161476 11/26/08 12:32 PM 11/26/08 12:32 PM |
Posts: 3,906 Clermont, FL, USA | What do u want translated?? "sikaflex the bungs" I know what a bung is, what is sikaflex... a 5200 like product? Nevermind, Google is king. http://www.ellsworth.com/sikaflex.html?gclid=CPq9pLywk5cCFQhdswodhzMbnw
Last edited by David Ingram; 11/26/08 12:34 PM. Reason: got lazy, then changed my mind
| | | Re: Infusion Boards
[Re: NacraKid]
#161480 11/26/08 12:46 PM 11/26/08 12:46 PM |
Posts: 36 World Citizen | has had our boards filled in as thats what all the top boys do, Have you had (a) boards filled or (b) slots filled so that edges cannot move as originally planned by Nacra? Pictures please. Thanks.
JFR Infusion Mk2
| | | Re: Infusion Boards
[Re: JFR]
#161488 11/26/08 04:11 PM 11/26/08 04:11 PM |
Posts: 126 Southampton UK | has had our boards filled in as thats what all the top boys do, Have you had (a) boards filled or (b) slots filled so that edges cannot move as originally planned by Nacra? Pictures please. Thanks. Slots filled in so boards dont orignaly move as planned. adding some thickness to the boards would ruin thier shape. | | | Re: Infusion Boards
[Re: JFR]
#161566 11/27/08 05:32 PM 11/27/08 05:32 PM |
Posts: 126 Southampton UK | yes but not where it matters Yes where matters as you would have to reshape the boards below bottom of the hull to stop the gybin motion downhill | | | Re: Infusion Boards
[Re: NacraKid]
#163635 12/29/08 02:03 PM 12/29/08 02:03 PM |
Posts: 246 Kiel, Germany | Doesn't the Capricorn has gybing dagger-boards, too?
F18: C2 / A-Cat: Minelli
| | | Re: Infusion Boards
[Re: Tornado_ALIVE]
#163771 12/31/08 11:29 AM 12/31/08 11:29 AM |
Posts: 246 Kiel, Germany | ... and, being a Capricorn-owner since two months, do I have to worry about this subject, too?
556
guests, and 48
