| Re: New Hobie F18?
[Re: ]
#162112 12/06/08 05:21 PM 12/06/08 05:21 PM |
Posts: 3,224 Roanoke Island ,N.C. | Sweet pics. Was that Beto's crossing cat? The one with the wing tents?
| | | Re: New Hobie F18?
[Re: Team_Cat_Fever]
#162114 12/06/08 06:12 PM 12/06/08 06:12 PM |
Posts: 12,310 South Carolina | I enjoy watching evolution. That daggerboard is so thin and skinny - it's a complete deviation from the beginnings of F18 development. Early F18s (Nacras) used the high profile (skinny) I20 board profile but rumor had it that it made the boat really hard to handle on the start line when the water speed was low. F18 evolved fatter and fatter boards. Now this with the really high aspect ratio foil (it appears to be even more so than the early Nacra). Is it a step forward, or a step back? Perhaps it's something that you have to be REALLY good at boat handling to use on the start line - but I can see how it might have an upwind advantage.
The bow seems to be pretty thin. The reverse bow does sing a little like the Capricorn. It's hard to tell due to the color - but it doesn't seem to have as much down-low hull volume that the Capricorn has. The sterns look fat and wide and has the chine - Infusion-esque. It perhaps has more rocker than both the Capricorn and the Infusion - sort of like the older Nacra F18. It's a good looking boat.
Not that I'm in the market for an F18 at the moment - but I am disappointed that it appears that the Tiger trampoline attachment method will be carrying over to this boat. The Tiger tramps always felt so mushy because they aren't laced to any hard points on the sides. That, or the Tigers I've sailed on weren't tightened properly.
Jake Kohl | | | Re: New Hobie F18?
#162117 12/06/08 06:21 PM 12/06/08 06:21 PM |
Posts: 2,584 +31NL | Jake: the tiger you sailed was probably not set up properly, if you tighten it with the mainsheet it is usually quite stiff.
As you can see it is far from a finished product, from what i heard there will indeed be a different tramp setup (dont know the exact details yet).
| | | Re: New Hobie F18?
[Re: ratherbsailing]
#162120 12/06/08 06:36 PM 12/06/08 06:36 PM | Scarecrow
| Scarecrow
Unregistered | no reason for the foils to break if properly built. They do however look like a mistake to be. They would be fast on the computer and in two boat testing with the world's best on board. But in the hands of Joe Weekend, I see a lot of bad starts and poor tacks. | | | Re: New Hobie F18?
[Re: Tony_F18]
#162122 12/06/08 07:26 PM 12/06/08 07:26 PM |
Posts: 3,528 Looking for a Job, I got credi... | iCat it the new FX1-Full Carbon. The new F18 is actually called the W.Cat (or very similar). Tony, was there any published data on how huch the FX1 carbon tips the scales at?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: New Hobie F18?
[Re: scooby_simon]
#162124 12/06/08 09:07 PM 12/06/08 09:07 PM |
Joined: Mar 2008 Posts: 201 Adelaide, South Australia simonp
Posts: 201 Adelaide, South Australia | I think it looks fantastic. Those foils look dangerous. Can't wait to see it on the water. I wonder if all boats leaving the factory will have that high gloss finish on them.
Can someone please explain why the the very high aspect foils make it harder to control at lower speeds?
Simon BLADE F16 AUS405
| | | Re: New Hobie F18?
[Re: simonp]
#162126 12/06/08 09:22 PM 12/06/08 09:22 PM |
Posts: 12,310 South Carolina | I think it looks fantastic. Those foils look dangerous. Can't wait to see it on the water. I wonder if all boats leaving the factory will have that high gloss finish on them.
A short wide foil will resist side force at lower speed. Imagine an airplane with a big fat stubby wing...like this: It flies really well at low speeds - the fat wide wing generates a lot of lift without much air flowing over it. However, it has a lot of drag if you try to make it fly faster. Now picture a very long narrow wing....like this: Slope soarers / gliders are developed to be highly efficient but have to be at pretty good speeds to develop lift (compared to the lazy bee pictured above). This translates into this: a short fat foil will provide the side force needed to control the boat off the start line - when it's moving very slowly in the water. A long narrow foil will stall and not generate much lift until it achieves a certain amount of flow over it's surface. This will make a long narrow foil very sensitive at low speeds and susceptible to stall.
[Re: ncik]
#162130 12/06/08 10:59 PM 12/06/08 10:59 PM |
Posts: 334 Seattle,Wa | Excellent Pictures. I'm very envious that you were able to go. Hobie Tiger 2003 | | | Re: New Hobie F18?
[Re: Don_Atchley]
#162132 12/06/08 11:34 PM 12/06/08 11:34 PM |
Posts: 242 Brisveagas | Nice pictures tony!
Where's the rest of it?
Rear beam looks like it might be a bit of a wave slapper?
Aido Viper 288
| | | Re: New Hobie F18?
#162133 12/06/08 11:41 PM 12/06/08 11:41 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | I will post soms pics as soon as i get soms proper WIFI. That's kind of like the guy that leaves me voicemails at my desk stating "I'll try you on your cell phone, so disregard this message". Post intentionally left blank..... EXACTLY! Shouldn't this conversation be over on the "Test"? | | | Re: New Hobie F18?
[Re: Karl_Brogger]
#162137 12/07/08 01:01 AM 12/07/08 01:01 AM | Scarecrow
| Scarecrow
Unregistered | Keep scrolling through, there is a photo of a board. | | | Re: New Hobie F18?
[Re: ]
#162138 12/07/08 01:09 AM 12/07/08 01:09 AM |
Posts: 4,119 Northfield Mn | Keep scrolling through, there is a photo of a board. Holy hell! I was just looking at the hole in the hull. Yeah, that baby is tiny. Just a guess-timate, but 2 inches less than the Tiger board? | | | Re: New Hobie F18?
[Re: Tony_F18]
#162141 12/07/08 05:24 AM 12/07/08 05:24 AM |
Posts: 36 World Citizen | Where there any rudders? Your picture No. 37 indicates those will have surface under the hull. Yee...
This is all interesting but I'm wondering if they have not gone to far with the foils. No obvious "want-this-feel, but that's me and I'm always a late adaptor.
JFR Infusion Mk2
| | | Re: New Hobie F18?
#162152 12/07/08 10:01 AM 12/07/08 10:01 AM |
Posts: 571 Hamburg |
The conclusion is correct in general, however not only aspect ratio but also the area itself is important (a high aspect ratio foil would work, if it is only big enough). It is hard to judge the controlabilty without knowing area and span. But even more important: I have my doubts that it will bring any hydrodynamic advantage upwind. The reduced induced drag of the increased span, might be easily overcome by the increased friction drag due to reduced Reynoldsnumber. If the area is too small, there will be also a risk of cavitation at high speeds. Would be interesting if the production boat will have more conventional daggerboards or if they learn it the hard way. Cheers, Klaus
| | | Re: New Hobie F18?
[Re: FasterDamnit]
#162185 12/07/08 11:50 PM 12/07/08 11:50 PM |
Posts: 12,310 South Carolina | I just realized that color looks like Duratec surfacing primer. Did they bring out their plugs for the show?
#162210 12/08/08 10:23 AM 12/08/08 10:23 AM |
Posts: 5,590 Naples, FL | those boards would look even nicer if there were slanted slightly forward of center along the lengthwise midline. Kind of like a forward-swept wing.
I said LOOK nicer, because that would probably be inherently unstable (and collect seagrass like nobody's business!)
581
guests, and 506
