| Re: which cat do I purchase ?
[Re: ]
#163514 12/25/08 07:16 PM 12/25/08 07:16 PM |
Posts: 1,479 Thailand | That's going to be a big bag.;-))
[Re: davefarmer]
#163520 12/25/08 11:45 PM 12/25/08 11:45 PM |
Posts: 24 | Hi Dave: I am happy that you read my response with such enthusiasm . I use the standard halyard shackle & ring that comes with the boat for the top of the rigid extension...the shackle pin attaches to the hole in the extention(when you use the regular sail for the boat it is set up the same way ) & the ring is attached to the halyard line & fastens to the mast stop when you hoist the sail ! For the lower end of the extension ,the side that attaches to the sail, I use a large standard stamped halyard shackle(with a captive pin to prevent loss of pin)the open end of the shackle first goes through the mainsail grommet & the pin locks through the hole on the extension. There is No slop. if you need further explanation or picks contact me: [email protected] give me your home address & I will send you a simple diagram ...If you sail a P-19 it will definately work ! Bill | | | Re: which cat do I purchase ?
[Re: davefarmer]
#163534 12/26/08 08:58 AM 12/26/08 08:58 AM |
Posts: 1,226 Atlanta | I'd really like to try an A cat main on my HT, but it's an expensive carbon mast, don't want any surprises. Foolish to try? You wont break the HT mast with a Acat main. That Riba mast is plenty strong. If the mast track flex's and the bolt rope pulls out, add a 3-4 layers of carbon to the spot where it pulls out (if it does) Bill | | | Re: which cat do I purchase ?
[Re: davefarmer]
#163576 12/27/08 11:58 AM 12/27/08 11:58 AM |
Posts: 1,226 Atlanta | I was going to have a smaller main made, but then never got around to it.
I think you'll find that in really high wind its not sailing the boat that will be the issue, its leaving the beach and returning, getting the wheels, getting the sail down. All that stuff is going to be hard without an extra set of hands. The HT wants to fly away when it gets over 18kts.
I usually sail the HT alone or with my 6 year old daughter in the summer when the wind is 5-12knts, and its perfect, when its windier I can usually find someone to come with me, so I havent really needed the smaller main. The Kevlar main Peter Cogan made me works really well with the main, and I can flatten it so that the top half goes away in big breeze.
I went out last year with crew and it was blowing 25-30, gusting higher. The wind was offshore and we went upwind like a rocket, the whole top of the sail was flat as a board.
You might just have Peter Cogan make you a Kevlar main and then you have a sail for a wider wind range.
[Re: bvining]
#163584 12/27/08 06:15 PM 12/27/08 06:15 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Unless you're just looking for a new boat- a different/newer boat is always nice; The P19 is a very descent boat. as long as the centerboards are kept well, they usaully always will retract when hitting shallows, etc. If you race and a P19 class- that'd be hard to find.
You could go without the jib on the windier days, or furl it. Racking the mast a bit forward before hand would help some on weather helm, as would raising the boards some. (running a 1/4 inch bungee from the pivot point to the shroud allows the boards to move well when down and allows you to wedge it in the slot to keep the board at any given depth when you want it).
Have you traveled the main car out some in heavier winds, with max downhaul and outhaul? This depowers quite a bit.
And, as has been said, have you tried a righting pole, or righting bag? What about wings? There is a guy here on Galveston Bay that homemade a NICE set of wings for his P19.
As said also, newer/different boats are always good, or at least novel, and if you race, the F18 would be a good boat.
F-18 Infusion #626- SOLD it!
[Re: Buccaneer]
#163596 12/28/08 08:48 AM 12/28/08 08:48 AM | andrewscott
| andrewscott
Unregistered | That's going to be a big bag.;-)) we right 5.5 and 6.0 cats solo with a Murray's bag locally | | | Re: which cat do I purchase ?
[Re: whr241]
#163735 12/30/08 09:10 PM 12/30/08 09:10 PM |
Posts: 264 Long Island, NY | I had the same issues with my P19MX. Excellent boat-I had it for 12 years- but I couldn't always rely on crew. I'm very happy with the blade.
G Gove
Blade #728
Long Island, New Yawk
19,774
guests, and 666
