| Re: materials
[Re: John Williams]
#164179 01/06/09 12:33 PM 01/06/09 12:33 PM | andrewscott
| andrewscott
Unregistered | Who the hell is trying to stab your boat? LOL!!!! | | | Re: materials
[Re: fin.]
#164184 01/06/09 01:35 PM 01/06/09 01:35 PM |
Posts: 12,310 South Carolina |  There has been some complaining about dimpling and the like with kevlar construction. More to the point, anyone who saw Gordon's A cat split in half might be interested. I don't think that has much to do with the Kevlar...rather how MUCH kevlar was used and how well it was bonded to the core. A fiberglass boat with a thin skin will dent just as easily if not more so.
Jake Kohl | | | Re: materials
#164197 01/06/09 04:24 PM 01/06/09 04:24 PM | Scarecrow
| Scarecrow
Unregistered | as Jake notes skin dimpling has very little to do with material and a lot to do with thickness. Because you can get away with very thin skins with exotic materials you can end up with a lot more dimpling than a chop strand mat f/g boat. Higher density cores can be specified to reduce dimpling, however, this offsets some of the initial weight gain from using the high tech material. | | | Re: materials
[Re: fin.]
#164296 01/07/09 12:46 PM 01/07/09 12:46 PM |
Posts: 5,590 Naples, FL | Don't worry, Pete. They're out with ceramic vests now. Seem to have better characteristics: Lower weight, higher impact resistance, and can defeat knives/schrapnel.
| | | Re: materials
[Re: fin.]
#164335 01/07/09 03:38 PM 01/07/09 03:38 PM |
Posts: 12,310 South Carolina | Ceramic. . .tile. . .space shuttle. . . bullet proof boat!?
Has any tried using heavy dish washing gloves when painting or working with epoxy? Yep - works fine. I used them for a while and worked to keep them clean so I could reuse them...I got about 10 uses out of them before they were too trashed to continue. However, I still like the vinyl or latex gloves for convenience and the lack of having to keep up with or clean them. The vinyl or latex gloves also give you more dexterity.
#164345 01/07/09 04:01 PM 01/07/09 04:01 PM |
Posts: 4,451 West coast of Norway | We use double layers of vinyl gloves when working with epoxy. Makes it easy to change the gloves when they get sticky and your hands are sweaty. If you dont need that extra "surgeons touch", heavy dish washing gloves with a vinyl set over them is the best from both worlds. Buy vinyl gloves in bulk (a thousand), and they are cheap. I think epoxy can work its way through latex gloves? I just came up from the workshop after glassing a hull panel http://woodastic.blogspot.com/ | | | Re: materials
[Re: fin.]
#164349 01/07/09 04:09 PM 01/07/09 04:09 PM |
Posts: 4,451 West coast of Norway | Aha.. Perhaps a good set of dishwashing gloves with vinyl ones over then? Should be easier to pull on the vinyl gloves that way? The dishwashing gloves could last forever that way, and you would protect your wrists and arms from epoxy as well. Be careful if you go with just dishwashing gloves. Epoxy can seep through some of that stuff.
| | | Re: materials
[Re: Rolf_Nilsen]
#164358 01/07/09 06:25 PM 01/07/09 06:25 PM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker
Posts: 695 Ft. Pierce, Fl. USA | We always used multiple pairs of Latex surgical gloves for epoxy...sometimes as many as five pair at one time...you just strip off the outer pair as needed and keep going. They are dirt cheap and come in at least four different sizes to fit even the largest hands... When you vacuum bagging large parts and you have a thousand dollars worth of materials at stake you don't have the luxury of stopping and changing gloves or cleaning them…
Regards, Bob
| | | Re: materials
[Re: Seeker]
#164359 01/07/09 06:33 PM 01/07/09 06:33 PM |
Posts: 12,310 South Carolina | We always used multiple pairs of Latex surgical gloves for epoxy...sometimes as many as five pair at one time...you just strip off the outer pair as needed and keep going. They are dirt cheap and come in at least four different sizes to fit even the largest hands... When you vacuum bagging large parts and you have a thousand dollars worth of materials at stake you don't have the luxury of stopping and changing gloves or cleaning them…
Regards, Bob Both are terrific ideas! I did really like how the dishwashing gloves protected further up my arm.
[Re: fin.]
#164363 01/07/09 07:38 PM 01/07/09 07:38 PM |
Posts: 1,911 South Florida & the Keys | Still leaves a hell of a bruise and in some cases organ trauma. The bonus is that the target get to live!
Eric Arbogast ARC 2101 Miami Yacht Club | | |
344
guests, and 36
