materials #164168
01/06/09 11:52 AM
01/06/09 11:52 AM
fin. Offline OP
fin.  Offline OP
I was watching the Science Channel. Impregnating kevlar body armor with a mix of polytethylene glycol and silicon makes it impervious to stabbing damage. Any application to boat building?
Re: materials [Re: fin.] #164170
01/06/09 12:03 PM
01/06/09 12:03 PM
Who the hell is trying to stab your boat? shocked
Re: materials [Re: John Williams] #164176
01/06/09 12:29 PM
01/06/09 12:29 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
makes for shapeful bodies too
Re: materials [Re: John Williams] #164179
01/06/09 12:33 PM
01/06/09 12:33 PM
andrewscott
andrewscott
LOL!!!!
Re: materials [Re: John Williams] #164181
01/06/09 12:50 PM
01/06/09 12:50 PM
Etchell sailors, thats who! grin
Re: materials [Re: ] #164182
01/06/09 12:51 PM
01/06/09 12:51 PM
fin. Offline OP
fin.  Offline OP
smirk There has been some complaining about dimpling and the like with kevlar construction.
More to the point, anyone who saw Gordon's A cat split in half might be interested.
Re: materials [Re: fin.] #164184
01/06/09 01:35 PM
01/06/09 01:35 PM
I don't think that has much to do with the Kevlar...rather how MUCH kevlar was used and how well it was bonded to the core. A fiberglass boat with a thin skin will dent just as easily if not more so.
Re: materials [Re: Jake] #164197
01/06/09 04:24 PM
01/06/09 04:24 PM
Scarecrow
Scarecrow
as Jake notes skin dimpling has very little to do with material and a lot to do with thickness. Because you can get away with very thin skins with exotic materials you can end up with a lot more dimpling than a chop strand mat f/g boat. Higher density cores can be specified to reduce dimpling, however, this offsets some of the initial weight gain from using the high tech material.
Re: materials [Re: ] #164198
01/06/09 04:32 PM
01/06/09 04:32 PM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Poly glycol and silicon make it so the resin will not bind to the fibers. This is how Kevlar and the other composites become ballistic and or cut resistant. The materil becomes essentialy a net that slowly defoms and catches the projectiles, where stiff material fracture quickly and therfore dispate very little of the energy.
A hull needs to be stiff. Adding a binder inhibitor to it would not only make it structuraly unsound, but the thin skin would be in effect even less resistant to denting the core.
Re: materials [Re: Matt M] #164199
01/06/09 04:36 PM
01/06/09 04:36 PM
fin. Offline OP
fin.  Offline OP
Just wondered. The demonstration on T.V. was very impressive. Some guy using all his strength to try and stab an awl through a kevlar vest with no success.
Re: materials [Re: fin.] #164296
01/07/09 12:46 PM
01/07/09 12:46 PM
Don't worry, Pete. They're out with ceramic vests now. Seem to have better characteristics: Lower weight, higher impact resistance, and can defeat knives/schrapnel.
Re: materials [Re: waterbug_wpb] #164327
01/07/09 02:48 PM
01/07/09 02:48 PM
fin. Offline OP
fin.  Offline OP
Ceramic. . .tile. . .space shuttle. . . bullet proof boat!?
Has any tried using heavy dish washing gloves when painting or working with epoxy?
Re: materials [Re: fin.] #164335
01/07/09 03:38 PM
01/07/09 03:38 PM
Yep - works fine. I used them for a while and worked to keep them clean so I could reuse them...I got about 10 uses out of them before they were too trashed to continue. However, I still like the vinyl or latex gloves for convenience and the lack of having to keep up with or clean them. The vinyl or latex gloves also give you more dexterity.
Re: materials [Re: Jake] #164345
01/07/09 04:01 PM
01/07/09 04:01 PM
We use double layers of vinyl gloves when working with epoxy. Makes it easy to change the gloves when they get sticky and your hands are sweaty. If you dont need that extra "surgeons touch", heavy dish washing gloves with a vinyl set over them is the best from both worlds.
Buy vinyl gloves in bulk (a thousand), and they are cheap.
I think epoxy can work its way through latex gloves?
I just came up from the workshop after glassing a hull panel smile http://woodastic.blogspot.com/
Re: materials [Re: Rolf_Nilsen] #164347
01/07/09 04:03 PM
01/07/09 04:03 PM
fin. Offline OP
fin.  Offline OP
Size is the issue. Even large gloves are hard for me to wiggle into.
Re: materials [Re: fin.] #164349
01/07/09 04:09 PM
01/07/09 04:09 PM
Aha.. Perhaps a good set of dishwashing gloves with vinyl ones over then? Should be easier to pull on the vinyl gloves that way? The dishwashing gloves could last forever that way, and you would protect your wrists and arms from epoxy as well.
Be careful if you go with just dishwashing gloves. Epoxy can seep through some of that stuff.
Re: materials [Re: Rolf_Nilsen] #164358
01/07/09 06:25 PM
01/07/09 06:25 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
We always used multiple pairs of Latex surgical gloves for epoxy...sometimes as many as five pair at one time...you just strip off the outer pair as needed and keep going. They are dirt cheap and come in at least four different sizes to fit even the largest hands...
When you vacuum bagging large parts and you have a thousand dollars worth of materials at stake you don't have the luxury of stopping and changing gloves or cleaning them…
Bob
Re: materials [Re: Seeker] #164359
01/07/09 06:33 PM
01/07/09 06:33 PM
Bob
Both are terrific ideas! I did really like how the dishwashing gloves protected further up my arm.
Re: materials [Re: fin.] #164363
01/07/09 07:38 PM
01/07/09 07:38 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Still leaves a hell of a bruise and in some cases organ trauma. The bonus is that the target get to live!
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 1,019 guests, and 42 spiders.
