| Re: DIY Sailing watch specs wanted
[Re: David Ingram]
#165647 01/21/09 05:59 PM 01/21/09 05:59 PM | andrewscott
| andrewscott
Unregistered | i thought it wouldn't be to hard to create a swivel / cradle that could easily flip a device to the other side of the boom....
i think Jake could / should engineer one his work....!!! | | | Re: DIY Sailing watch specs wanted
[Re: ]
#165649 01/21/09 06:21 PM 01/21/09 06:21 PM |
Posts: 1,200 Vancouver, BC | I've made a display "tacker" for my Nauteek 2000 Sail Computer. It mounts under the boom near the mast. It's a swivel bracket bolted to the boom with a short "tiller" arm extending forward. I have bungee line running from the tiller arm down to the mast rotator tiller. This triggers the swiveling of the display bracket. I also run a limiter line from the bracket to the boom...stops the swivel going too far on either tack.
Works extremely well.
[Re: DennisMe]
#165671 01/22/09 04:57 AM 01/22/09 04:57 AM |
Posts: 4,451 West coast of Norway | The tack/gybe function is something I find useful on long windward/leeward courses where you can not see the marks after rounding. I.e. the old Tornado courses. What we do, is we round the mark, and then note how many minutes we sail before we gybe, and how long we sail between gybes. That way we have better control on where we are on the course, and we know how much longer we have gone left/right on the course compared to the previous lap. I dont know what kind of screen and other hardware you want to run and what is needed to visualize this. It might also be just me who thinks this is good to have and like to structure my sailing like this. It is your watch  I dont think it is against any current class rules to have this functionality, but there might be some classes who dont allow this. | | | Re: DIY Sailing watch specs wanted
[Re: DennisMe]
#165687 01/22/09 10:23 AM 01/22/09 10:23 AM |
Posts: 778 Houston | In designing a sailing watch remember what Reg White wrote in the 60's "All yacht timer will eventually leak around the buttons, treasure the Rolex Submariner" translation any mechanical penetrations of the case will eventually leak.
Below are some features I like:
My favorite sailing watch is the Timex Victory, it has a big red START button on the front. Because it is programmed for 5 minute increments , I can't use it all the time.
Take a look at the Nike Typhoon (tide model). It has multiple independent programmable timers. I programmed the timers for 1, 3,3, 5 and 9 minutes. It's like having preprogrammed times. You go to start mode and then page through the timers to the time you want. The advantage is if something screws up (restart, postponement, you missed a flag) you don't have to stop and reset your timer, you just page to a new timer. The active timers controls the display and sounds. The case on the typhoon is interesting. The case and the band are one. The only penetration is the back. The case has pushers under the plastic of the band/case skin to operate the micro switches on the movement. The display, electronics and battery are a single module that is seperate from the case. When the case/band wears out or you crack the crystal you replace it.
I think the Garmin 201 or the Suunto M9 have the best computer interface, gold contacts on the outside of the case and a matching holder. The contacts provide battery charging and a serial port to the movement. The holder touchs the contacts and provides standard connects for serial and battery charger.
My SWISSSAIL had a button lockout. You rotated the bezel to set the mode and clicks between the modes was last mode, buttons inactive. That way you didn't reset your watch halfway through the start sequence. Everything else about that watch sucked. It was hard to read, use and it leaked.
I have seen old PDA's used in Labs as Timers and data loggers. If you could build a waterproof case, you would have all the programmability features, and interfaces you would need to play for a couple of years.
[Re: carlbohannon]
#165692 01/22/09 10:43 AM 01/22/09 10:43 AM |
Posts: 2,584 +31NL | IMHO this the the best starttimer around: http://www.sailingclothingstore.co.uk/Sailing_Watches/pr28055_sc343.aspxIts got big digits, its loud, straps around the boom and flips over easily. very easy to use, has presets, big buttons, sync, last 10-sec beep countdown, etc. I also have a Suunto Mariner for everyday watch which is also good as a timer but I prefer to have one on the boom for the crew to operate.
[Re: Tony_F18]
#165697 01/22/09 11:14 AM 01/22/09 11:14 AM |
Posts: 3,293 Long Beach, California | Tony, no doubt that is a good timer. I have one, too. But it is absurdly expensive and you can't set to 3- or 6-minute sequences. And it is absurdly expensive. And, for the electronics involved, it is absurdly expensive. It costs too much, too.
[Re: Tornado]
#165704 01/22/09 12:34 PM 01/22/09 12:34 PM |
Posts: 5,590 Naples, FL | since we're brainstorming..
Why not build the watch into your sunglasses, with a "heads up display" in the lower corner showing countdown timer. The "brains" of the unit could be similar to a cell phone somewhere in the boat, and connect via bluetooth (or some other technology) to the glasses.
Vibrating feature would be nice, or some kind of earpiece off the glasses.
Once the countdown is complete, the display could be user-programed to switch display to VMG, COG, heading to next waypoint, etc. just like a handheld GPS.
If it's not integrated into the sunglasses themselves, maybe it could be a "flip up" type semi-transparent display that goes over (or under) an ordinary or perscription lens.
[Re: waterbug_wpb]
#165783 01/22/09 07:30 PM 01/22/09 07:30 PM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | How about a watch that counts out loud so i don't have to keep telling my crew how much time is left??? how much time? how much time? how much...damn were late...
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: DIY Sailing watch specs wanted
[Re: Capt_Cardiac]
#165789 01/22/09 08:18 PM 01/22/09 08:18 PM |
Posts: 12,310 South Carolina | How about a watch that counts out loud so i don't have to keep telling my crew how much time is left??? how much time? how much time? how much...damn were late... Ding ding ding!!!! we have a winner!
Jake Kohl | | | Re: DIY Sailing watch specs wanted
[Re: waterbug_wpb]
#165790 01/22/09 08:19 PM 01/22/09 08:19 PM |
Posts: 12,310 South Carolina | I actually experimented last week with my Garmin Foretrex on the edge of my hat bill off to the side and it was still too close to read.
#165794 01/22/09 08:30 PM 01/22/09 08:30 PM |
Posts: 3,224 Roanoke Island ,N.C. | I actually experimented last week with my Garmin Foretrex on the edge of my hat bill off to the side and it was still too close to read. God, your a geek!
[Re: Team_Cat_Fever]
#165799 01/22/09 09:20 PM 01/22/09 09:20 PM |
Posts: 12,310 South Carolina | I actually experimented last week with my Garmin Foretrex on the edge of my hat bill off to the side and it was still too close to read. God, your a geek! Yeah...I would accept that if it had worked and I showed up at the next regatta with a carbon mount for it on my hat!
#165801 01/22/09 10:08 PM 01/22/09 10:08 PM |
Posts: 3,224 Roanoke Island ,N.C. | I meant that in a good way.
Carbon mount? Just make a carbon hat.
#165804 01/22/09 10:21 PM 01/22/09 10:21 PM | Scarecrow
| Scarecrow
Unregistered | A lot of mobile phones (I phone etc) can now tell which way you're holding them and adjust the display to suit. Could you make a display that inverts automatically when the unit is upside down (ie after being twisted around the boom). | | | Re: DIY Sailing watch specs wanted
#165835 01/23/09 08:18 AM 01/23/09 08:18 AM |
Posts: 12,310 South Carolina | I meant that in a good way.
Carbon mount? Just make a carbon hat. Carbon hat? you may have something there!
#165864 01/23/09 10:41 AM 01/23/09 10:41 AM | andrewscott
| andrewscott
Unregistered | How about a watch that counts out loud so i don't have to keep telling my crew how much time is left??? how much time? how much time? how much...damn were late... Ding ding ding!!!! we have a winner! This one would be very audable.. but only on the 1/2 and 1/4 hour | | |
4,150
guests, and 655
