Aluminum Alloy used in Hobie Masts? #16608
02/24/03 03:14 PM
02/24/03 03:14 PM
MauganN20 Offline OP
In my perpetual list of things to fix on my boat, I need to repair my punctured mast from last season. I have found an aluminum welder in the area that said he could fix it, however, he needs to know the type of alloy used in the mast extrusion so he can make sure he has something that will not only bend around the curve of the mast, but something that will mate with it and not crack when cooling down.
Anyone know off the top of their heads.. or will I have to give Alter a ring?
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16609
02/25/03 08:41 AM
02/25/03 08:41 AM
PSAILOR Offline
PSAILOR  Offline
I don't know the alloy, but was thinking that if you could get a piece of a broken hobie mast to use as the patch pannel the alloy should be the same. I don't know if the alloy would be needed to select the filler rod though.
I think I still have a section of a broken mast if you need a piece.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16610
02/25/03 08:45 AM
02/25/03 08:45 AM
Houston
carlbohannon Offline
Houston
I has been a long time, I believe Hobie uses 6061 T6
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16611
02/25/03 09:51 AM
02/25/03 09:51 AM
deseely Offline
deseely  Offline
Before you weld it you might want to talk to one of you local rigging shops. Most aluminum alloys goes through a heat treatment or work hardening process to increase the strength. The heat from welding will soften the aluminum significantly. 6061 will have about 3 times the strength in the 6T condition as it will in the soft state. It might be better to rivet a plate over the damaged area with some bonding agent between them.
Re: Aluminum Alloy used in Hobie Masts? [Re: deseely] #16612
02/25/03 11:18 AM
02/25/03 11:18 AM
I was thinking about riveting the plate, but the damage is right near the bottom of the mast, below the sail track, where, I'm assuming, compression loads are high. I don't know if I'd want to trust rivets for that.
Thanks for the response though on the 6061, I had thought I'd seen 5051 on one of the H14 parts diagrams, but I guess I'm wrong.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16613
02/25/03 02:43 PM
02/25/03 02:43 PM
C
catnip Offline
catnip  Offline
C
assume 6061-in a t4 condition.
the welded area will be as stiff, but not as strong.
in general, 6063 is a lower cost extrusion alloy with less strength, but same stiffness and better finish/corrosion resistance.
Hobie is in Oceanside California. You could call them.
Re: Aluminum Alloy used in Hobie Masts? [Re: catnip] #16614
02/25/03 02:55 PM
02/25/03 02:55 PM
Do you think it will be strong enough to handle the loads placed near the base of the mast on a H17 (sometimes with jib)
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16615
02/25/03 02:57 PM
02/25/03 02:57 PM
FL
sail7seas Offline
sail7seas  Offline
FL
Checkout this website:
http://www.durafix.com/
Re: Aluminum Alloy used in Hobie Masts? [Re: sail7seas] #16616
02/25/03 03:35 PM
02/25/03 03:35 PM
That looks good, and a lot better than the $150 I was quoted from the aluminum welder!
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16617
02/25/03 05:14 PM
02/25/03 05:14 PM
Yeah - but that's simply brazing a joint just like with copper plumbing...I ~might~ believe their claim to "be stronger than the metal" in a tight tolerance bonding situation but I really doubt it will be in a gap filling scenario.
Re: Aluminum Alloy used in Hobie Masts? [Re: Jake] #16618
02/25/03 11:52 PM
02/25/03 11:52 PM
well I'm not going to fill the gap, I'm going to weld a bracing plate overtop the puncture with the same profile as the mast so it fits flush.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16619
02/26/03 09:14 PM
02/26/03 09:14 PM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
i have used those brazing rods before. as i recall, the brazing material is rather brittle and will most likely crack under the stress
Re: Aluminum Alloy used in Hobie Masts? [Re: dave taylor] #16620
02/27/03 12:19 AM
02/27/03 12:19 AM
alright.
Well this is turning out to be more of a headache than I anticipated.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16621
02/27/03 06:32 AM
02/27/03 06:32 AM
If you're going to do a job that's worth doing, it's worth doing right (man, I sound like my father).
Seriously though - if you call Hobie, they will advise you against welding on the mast because of the liability. The heat treating process on aluminum is particular and the material properties will be changed for the worse by welding. If you MUST - you should really consider cutting the damage off and riveting a sleeved section back on.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16622
02/27/03 07:25 AM
02/27/03 07:25 AM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
If you are going to effectively use a sleeve why not glue and rivet it on,
If it works for aluminium sports cars!
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16623
02/27/03 09:55 AM
02/27/03 09:55 AM
Houston
Houston
I saw a neat trick for reinforcing aircraft structure. This might apply.
1) wrap the spar with release film (wax paper, 2-3 layers)
2) right on spar build up your reinforcing sleeve from carbon/epoxy. Use an undamaged part of the spar for the mold Either vacuum bag it or squeeze out the excess epoxy. For a mast the sleeve would go a couple of inches above and below the damaged area and 3/4 around the mast. You would need 5-8 layers 5 oz cloth. You could probably use 10-layers of fiberglass
3) when hard, slide it off, square the edges and clear coat it.
4) Apply glue to the mast, slide the sleeve on and tape it down to dry. I would probably use a 1 part polyurethane glue (Gorilla Glue) I found this works best for carbon/Al bonds
This is for reinforcing, distributing a load, or just sealing a hole.
Re: Aluminum Alloy used in Hobie Masts? [Re: carlbohannon] #16624
02/27/03 10:51 AM
02/27/03 10:51 AM
I'd probably rivet it on as well, just to be safe.
Thanks for all the suggestions guys. When it comes down to it, I've got two masts. One is this punctured one. The other one is the one I use, its got a slight dent and bend just below the tang. It straightens out under shroud tension, but if I can repair the damaged punctured one, I'd rather do that, because its straighter.
Again, thanks for the suggestions. When I called hobie, they wanted to sell me a new mast.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16625
02/27/03 06:38 PM
02/27/03 06:38 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Well, I'm surprised no one's mentioned it yet but it's quite common to have tapered Aluminum masts that are purposely cut and welded back to provide the taper. Admittedly this is common at the top of the mast (like on the 30' Sori wingmast I have on my old woodie A-cat from the 80's) where the loads may be lower but that also needs to be the most flexible and still be strong. Don't know where you are but you might try looking for a welder familiar with that technique (there are also some good marine grade welders who fabricate the fishing towers for powerboats or aluminum frames for tops, also some good welders who fabricate/repair the expensive bikes- I know, they are all CF now but the skills should still be around) - Just a thought-
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
Re: Aluminum Alloy used in Hobie Masts? [Re: Kirt] #16626
02/28/03 01:46 AM
02/28/03 01:46 AM
I've already inquired at an aircraft welder. He said he'd charge no more than $150 for it, and that'd be including the material he would use to patch it.
Re: Aluminum Alloy used in Hobie Masts? [Re: MauganN20] #16627
02/28/03 08:48 AM
02/28/03 08:48 AM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
If he's a certified aircraft welder, and they trust those welds in airplanes- Don't you think they'd be adequate on a sailboat where if the weld fails you might get hurt or your day would be ruined (vs if they fail in a plane more than the rest of your day will likely be ruined!).
Kirt
0 registered members (), 2,548 guests, and 500 spiders.
Yesterday at 10:10 AM
