| Re: Snuffer Dimensions
[Re: TeamChums]
#167552 02/07/09 05:49 PM 02/07/09 05:49 PM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | Thanks for the replies, BUTT, can one of you guys tell me the I.D. measurement that I would need based on the scrunched circumference of the spi?
Focus guys, focus.....
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Snuffer Dimensions
[Re: F-18 5150]
#167644 02/08/09 09:37 PM 02/08/09 09:37 PM |
Posts: 1,911 South Florida & the Keys | You put your right foot in, You put your right foot out; You put your right foot in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your left foot in, You put your left foot out; You put your left foot in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your right hand in, You put your right hand out; You put your right hand in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your left hand in, You put your left hand out; You put your left hand in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your right side in, You put your right side out; You put your right side in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your left side in, You put your left side out; You put your left side in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your nose in, You put your nose out; You put your nose in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your backside in, You put your backside out; You put your backside in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your head in, You put your head out; You put your head in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about!
You put your whole self in, You put your whole self out; You put your whole self in, And you shake it all about. You do the Hokey-Pokey, And you turn yourself around. That's what it's all about
[Re: arbo06]
#167646 02/08/09 09:46 PM 02/08/09 09:46 PM |
Posts: 3,224 Roanoke Island ,N.C. | UUUHHHHHHHH OK, Eric maybe you should wear a respirator when you work on your boat.
[Re: Team_Cat_Fever]
#167647 02/08/09 09:51 PM 02/08/09 09:51 PM |
Posts: 3,224 Roanoke Island ,N.C. | The mid-pole snuffer hoop on the I-20 is 11 3/16" (id) across, and it's a circle. I'd like to see a pic of the one with the roller,that's sounds pretty cool. Todd
1,019
guests, and 42
