| Re: Jib Battens on a Nacra 6.0
[Re: SoggyCheetoh]
#16700 02/25/03 12:38 PM 02/25/03 12:38 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | I assume the battens are the same as those on a Prindle 18. On my jib, I removed the pockets and sewed them back on at a 45 degree angle. I know others who have used this same method with good success. (HobieGary on his Mystere 6.0, for one). The jib rolls up easily after this and it doesn't seem to effect performance. Here's a photo Jack Hoying Fort Loramie, Ohio Prindle 18 #1645 http://www.bright.net/~jmhoying/sailing/prindle.htm
Jack Hoying
Fort Loramie, Ohio
[Re: SoggyCheetoh]
#16701 02/25/03 01:53 PM 02/25/03 01:53 PM |
Posts: 25 Nevada/Lake Tahoe | Yes, the battens will cause the sail to not roll up cleanly and will eventually do damage to the pockets and maybe the sail. I've switched to vertical battens and have been happy. I don't sail in the 6.0 class though so you may want to check class rules if that is important to you. Tim Dry Nacra 6.0 #32 http://www.catamaranracing.org | | | Re: Jib Battens on a Nacra 6.0
[Re: tdry]
#16702 02/25/03 03:49 PM 02/25/03 03:49 PM |
Posts: 2,844 42.904444 N; 88.008586 W | The stock sail, roller furled, will work, and work well. It's not optimal, but few things are.
The Inter 20 jib battens are already angled, I assumed for this reason, to furl cleaner.
Don't just cut them out! Your leach will flap all the time!
Easiest way-leave them alone. I wouldn't store it furled to the forestay however more than a night!
The angled modification is a good idea also.
I roller furl my jib, with the stock batten set up, it works.
F-18 Infusion #626- SOLD it!
[Re: Eric Anderson]
#16704 02/25/03 05:05 PM 02/25/03 05:05 PM |
Posts: 12,310 South Carolina | What are the other 6.0 owners using for roller furling drums if that Harken hi-load is so marginal?
Jake Kohl | | | Re: Jib Battens on a Nacra 6.0
[Re: Eric Anderson]
#16705 02/26/03 07:56 AM 02/26/03 07:56 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | A couple things.When your jib battens are angled the sail will furl better however if your used to rolling your sail up when you take it down the angled battens wont roll up neatly. I used to use a lenght of PVC to roll the jib up on. Now it has to be folded a certian way before it can be rolled.
The tip for furling is to head deep down wind and let the main blanket the jib before furling. Take the load off the jib and it will roll up nicely.
I'm using a furler system off a Hobie 18 on my Mystere 6.0. Almost 2 years of heavy use and no problems.
[Re: Eric Anderson]
#16707 02/26/03 10:40 AM 02/26/03 10:40 AM |
Posts: 12,310 South Carolina | I want to furl just to relax more in between races!
[Re: MauganN20]
#16709 02/26/03 03:00 PM 02/26/03 03:00 PM |
Posts: 12,310 South Carolina | doesn't that c-clip only hold it together when it's not rigged? My Hobie 18 (granted - different drum) below bridle furler has the same problem.
Jake Kohl | | |
301
guests, and 39
