| N 6.0 masts: #16713 02/25/03 03:55 PM 02/25/03 03:55 PM |
Joined: Jul 2001 Posts: 2,844 42.904444 N; 88.008586 W Todd_Sails OP
Posts: 2,844 42.904444 N; 88.008586 W | OK, carrying over a concept/event posting about the 'inversion' of a 6.0, alum mast!
It seems it's a result of spin flying, etc.
You know, it's FUNNY! The Tuning Tips for the 6.0, state NOT to release the main before the jib in a heavy puff!! Is this why, torques the mast?
How often, anytime, do you and the crew you're sailing with, release the jib BEFORE the main in a puff?
My question is: Has nayone had an inversion-static(stayed inverted with the sail and mast down), and re-tweaked it back to a raked position, permenantly?
Thanks for your replies.
F-18 Infusion #626- SOLD it!
| | | Re: N 6.0 masts:
[Re: Todd_Sails]
#16714 02/26/03 02:18 PM 02/26/03 02:18 PM |
Posts: 2,844 42.904444 N; 88.008586 W | kinda strange,
People talked about this on the old forum, I was concerned, so I post it over here, and nada.
c'mon guys
| | | Re: N 6.0 masts:
[Re: Eric Anderson]
#16716 02/26/03 05:19 PM 02/26/03 05:19 PM |
Posts: 9 Tampa Bay, FL | another reason for dumping the jib prior to the main in high winds is the high presure going around the back of the mast and main... if you keep the jib sheeted, all that pressure gets really screwy around the mast and can stress it pretty good fom what I've heard. Another thought on the 'inversions' is simply dropping the mast one too many times the wrong direction  My old mast had 2 or 3 spills and was never the same from the tang upward... but alas, it's since snapped in half (failed spreader arm) and the new mast is "awfully perty" Ryan N6.0 137/391/TBD | | | Re: N 6.0 masts:
[Re: Eric Anderson]
#16717 02/27/03 10:01 AM 02/27/03 10:01 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Eric,
Thanks for the reply. Interesting how you DIDN'T mention the 16/1 purchase downhaul, which really changes the power settings very quickly on these rigs.
No Eric, It clearly stated that mast damage could result. It had nothing to do with falling off the wind in a puff because you eased the main too much and the jib stayed pressured. (That's when the downhaul is optimal). This warning had nothing to do with boat handling, and staying on course.
Ryan,
Waht are you saying?, That If a mast is dropped on the ground too many times, it will invert?
| | | Re: N 6.0 masts:
[Re: Eric Anderson]
#16719 02/27/03 11:17 AM 02/27/03 11:17 AM |
Thanks agian, BUT, this thread was really about the 6.0 masts.
People who have had this problem-inversion. HOw to prevent it-such as max spreader rake If it's happened-has it been corrected, or is the mast now a good flagpole?
Todd Bouton
| | | Re: N 6.0 masts:
[Re: Todd_Sails]
#16720 02/28/03 08:12 AM 02/28/03 08:12 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Finally, I've received an e-mail from someone, who described how they bent their mast back from an inversion. Any others still using a previously inverted mast?
| | | Re: N 6.0 masts:
#16722 02/28/03 07:09 PM 02/28/03 07:09 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Jake, You've got mail! For others, basicallly he said that it inverted, he loosened the dianmonds, and used a tree a a few people to ben the mast back. Increased rake and tension, so far OK. Not much use yet thoug  h.
2,869
guests, and 168
