| Dagger Board/Hull Repair (Minor) #167465 02/06/09 02:33 PM 02/06/09 02:33 PM |
Joined: Oct 2008 Posts: 35 Chesapeake Bay MD BlowBoater OP
Posts: 35 Chesapeake Bay | Ok guys, I posted a while back when I first got my NACRA and the help was awesome. Now that it's getting warmer around here this weekend I figure I should do some work on her. The dagger boards are a little banged up. ![[Linked Image]](http://inlinethumb04.webshots.com/22147/2778821980079449133S600x600Q85.jpg) ![[Linked Image]](http://inlinethumb27.webshots.com/23642/2844126110079449133S600x600Q85.jpg) -The whole leading edge is scraped up as well. Can I fill in the chips and recoat the entire boards? What would I coat them with? I'm clueless. Bottom of Hulls ![[Linked Image]](http://inlinethumb27.webshots.com/21082/2340024100079449133S600x600Q85.jpg) ![[Linked Image]](http://inlinethumb62.webshots.com/3581/2998282910079449133S600x600Q85.jpg) Looks like they coated the bottom with something, no idea what it is. It is rubbed through in one spot into the gel coat and there are smaller chips here and there. I'm guessing this is because they lived on the beach to protect it a little but I won't be doing any beaching and if I do it will just be to pull it up on the sand at little islands in the Bay. Any advice on smoothing this out? Maybe sanding down that coating they put on it?(The bottom looks thin, you can see light through when the sun is bright but it all feels solid, no soft spots, is that normal?) And what should I patch the chips with? Any help is much appreciated. | | | Re: Dagger Board/Hull Repair (Minor)
[Re: MD BlowBoater]
#167477 02/06/09 04:23 PM 02/06/09 04:23 PM |
Posts: 606 Maryland | Sweat equity into an abused beachcat. Been there. Done that!
You will become very proficient with gel coat finishing, Grasshopper, which can be very rewarding once you get the right equipment and practice. The brown/tan stuff looks like epoxy that is a repair from beaching and colliding with another object(s). If the tan epoxy is sound, fair it out with something like West Systems epoxy and build up the worn spots. If you are really compulsive, grind/sand off the tan epoxy to see what really lies beneath. Thereafter, shoot some gel coat. Goes on heavy (20mils?) per coat and requires prep sanding (150 grit?)to achieve a mechanical bond. I prefer to use non-waxed until my final coat to keep it tacky during build up via chemical bond between coats (I prefer 3 for you project and about 20 mins between coats).
Let it cure well (1-3 days depending upon humidity and temp). If need be, sand off any drips after curing with 220ish. Quick wet sand with 600 and then the magic. Rough cut polish (its like tooth paste consistency) with an electric grinder and buff wheel. Followed by regular marine polish with grinder and then hand paste wax and electric buffer.
I'll defer on boards.
Kris Hathaway | | | Re: Dagger Board/Hull Repair (Minor)
[Re: MD BlowBoater]
#167479 02/06/09 04:39 PM 02/06/09 04:39 PM |
Posts: 12,310 South Carolina | does that daggerboard have a wood core? It appears to have been cut off on the end. To my knowledge, wood cores were not used in Nacra factory boards.
Jake Kohl | | | Re: Dagger Board/Hull Repair (Minor)
[Re: Kris Hathaway]
#167480 02/06/09 04:48 PM 02/06/09 04:48 PM |
Posts: 57 | Sorry to Hi-jack but I am looking at doing the same thing on a Prindle 18 where the bottoms are worn thin. It's just worn through the gel coat I think and starting on the fiberglass. do I do the same thing with epoxy or do I need to layer on some fiberglass. I have never done this and have no clue but I am a do it yourself kind a guy and would really like to learn.
It there any step by step pages or books anyone knows about? What kind of sprayer can you spray on gel coat with? I have a spray gun that came with a compressor that I have never used. I would like to refinish/coat the entire hull as the current gel coat is pretty dull and faded.
I also may want to custom paint some with an airbrush but am not sure what paint to use for that and was wondering you can then put a clear gel coat finish over that?
[Re: HMurphey]
#167498 02/06/09 09:45 PM 02/06/09 09:45 PM |
Posts: 3,224 Roanoke Island ,N.C. | You should try to avoid gel-coating over Epoxy. It's do-able ,but has a less than perfect success rate.
[Re: DennisMe]
#167519 02/07/09 08:25 AM 02/07/09 08:25 AM |
Posts: 12,310 South Carolina | I don't have any videos (and I've neglected my website for a while), but there is some detail on my website about doing fiberglass work and bottom jobs. If you really want to go overboard with it, my first part of an unfinished two-part series is here: http://www.teamseacats.com/index.php?s=bottom+job http://www.teamseacats.com/index.php?s=bottom+jobEpoxy itself does not sand well and it makes a good filler only if you don't plan for it to be the last layer. Epoxy yellows quickly with exposure to sunlight leaving it looking pretty bad. Ideally, you want to fill minor imperfections with a body filler. There are marine specific versions but I've had good success with the premium bondo brand...make sure you use the premium. Body filler is not very durable and will definitely need to be top coated with gelcoat...but it's a really involved process to do all this and get a good result...and there's not much instruction on it. If you think you want to go this route, read that article and ask some questions - it might finally motivate me to complete part II!
#167522 02/07/09 08:45 AM 02/07/09 08:45 AM |
Posts: 5,525 | "...but it's a really involved process to do all this and get a good result"
Yes and no. What are you trying to achieve?
If it's perfection then Jake is right 100%!
If you just want a sound boat for recreational sailing, and you are going to be dragging the boat on the beach, you don't need to be nearly so fussy. You can even apply gel coat with a roller. . . or not at all!
I had an old H16 that was more beer drinking platform than racer. When the bottoms needed to be done, I only sanded the repair with 80 grit and left them unfinished. The boat sailed just fine, and after a couple of "hard" landings you couldn't tell what the bottom was finished with.
Pete Pollard Blade 702
#167524 02/07/09 08:55 AM 02/07/09 08:55 AM |
Posts: 5,525 | Do you have any shots of the blocks that serious racers put their boats on? That might help this guy decide which direction he wants to go.
[Re: ThunderMuffin]
#167530 02/07/09 10:47 AM 02/07/09 10:47 AM |
Posts: 3,224 Roanoke Island ,N.C. | Plus, strapping your loose hull to the sawhorse isn't a bad idea either.
[Re: ThunderMuffin]
#167547 02/07/09 05:12 PM 02/07/09 05:12 PM |
Posts: 35 Chesapeake Bay | Wow, those are some pretty hulls. I don't hope to achieve anything near that realm of repair. I basically just don't want it to sink on me and be fairly smooth so she glides through the water a little better. Once I take it apart and flip the hulls over I think I'll get a better idea of what needs to be done.
How hard is it to get a good finish when spraying on gel coat? Do you recommend being an experienced painter? Maybe down the road I'll restore the boat and get that nice gloss back to the entire hulls(maybe a different color? red, dark blue, would that work?)
[Re: MD BlowBoater]
#167561 02/07/09 07:55 PM 02/07/09 07:55 PM |
Posts: 1,911 South Florida & the Keys | Evercoat, polyester glazing putty. Sandable, primer freindly, marine product.... look iy up and see if it fits yer application. I think it does.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Dagger Board/Hull Repair (Minor)
[Re: arbo06]
#167650 02/08/09 11:44 PM 02/08/09 11:44 PM |
Posts: 757 japan | i had similar wear on the bottom of my nacra hulls
fortunately nothing had been done to them so i was able to clean them up nicely with 2 thick gel coat mixes brushed on with a paint brush, not perfectly fair but i don't race
if you've got a previous epoxy bottom job already on your hulls then you are probably best to continue with epoxy
something in epoxy inhibits the catalytic reaction in gelcoat, polyester resin, so it just stays tacky and either never sets or sets so weak that it peels off in next to no time
for your daggerboards, just clean them up with sandpaper and then give the bases a couple of coats of white gelcoat
for the leading edge chips/holes you could just fill them with 5minute araldite, or drip some white gelcoat in there a few times
[Re: erice]
#167715 02/09/09 01:52 PM 02/09/09 01:52 PM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | What Eric is refering to is the "Amine Blush" that occurs in the final stages of the epoxy curing (at least w/ WEST Epoxy). Also note that research has shown that epoxies bond better to "cured" polyester resins then fresh/new polyester resins do. But there are a few tricks ...
1) Surface prep is KEY ... 2) You can not rush ... curing times are critical. 3) Gelcoat is designed to cure WITH OUT AIR ... so unless you are using it in a mold you need to have the formule w/ parafin(wax) so it will harden 4) If spraying gelcoat w/ an "aircompressor", compressor oil droplets can cause the gellcoat to never harden. You must use air filters to eliminate the aerosolized (small droplets) oil. Or you can just brush the gelcoat w/parafin on and sand the heck out of it w/ wet/dry paper ... start w/180 grit to cut the wax off then 220, 320, 400, 600, 800, 1000, 1200, 1500, 2000, ... now polish w/ polishing compound and it will look like Jake's!!!
Now, you can accelerate the epoxy's curing w/ heat and UV light. The trick to "amine blush" to let it run it's course which take 3-4 days in a garage/inside .... if outside w/ strong sunlight/UV radiation that time can be reduced. Sand the cured epoxy up to 600 to make sure the repair is Ok ... then resand the repair w/ 220 wet/dry to rough up the epoxy repair so that the gelcoat will adhere to the epoxy.
It's been my observation that most people "rush" the curing times .... with predictable results.
First you need to determine how much is missing from the bottom of your daggerboard, as there are several option on how to do that repair ... 1/2" or 1" or 6" it will make a difference on the technic used.
Harry Murphey
2,543
guests, and 519
