Re: gcat rudder systems [Re: Darrin D] #164219
01/06/09 08:20 PM
01/06/09 08:20 PM
Tarpon Springs, FL
Darrin D Offline OP
Darrin D  Offline OP
Tarpon Springs, FL
IS 1100 $ a good price for a whoe new system?
Re: gcat rudder systems [Re: Darrin D] #164225
01/06/09 08:56 PM
01/06/09 08:56 PM
JACKFLASH Offline
JACKFLASH  Offline
Sounds like alot of money when you can build a system from Hobie parts for probably under 300 bucks if you use used parts.
Collin Casey
Re: gcat rudder systems [Re: Darrin D] #167652
02/09/09 02:08 AM
02/09/09 02:08 AM
Dotan Offline
Dotan  Offline
Originally Posted by Darrin D
I keep braking one of the blades. And have been through a housing the boat has been sailed hard. I sail in a shallow area north of Tampa blades kick up and you have no steering. Dotans are either all the way up or all the way down. I have been looking for an old gcat in ok condition.
Dotan rudders have 3 positions:
1. UP - To lift the rudder blade and secure it in the upright position - tiller up and momentarily return it to the original position.
2. DOWN - Repeat the move to bring the rudder blade down.
3. IN-BETWEEN - Keep the tiller up for midway position in shallow water.
You can easily adjust the rudder to kick up at various pressures with a 3-position rubber stopper (located on the inside of the rudder box). Extensive information you may find here: Adjusting the Pressure under which the Rudder Kicks Up
While you are learning how to sail, it really will be wise to use different rudders that are not so prone to abuse because of negligence.
Dotan kick up rudder systems for dinghy and catamarans http://www.dotan.com
Re: gcat rudder systems [Re: Dotan] #167681
02/09/09 10:50 AM
02/09/09 10:50 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
This is the first time I have really studied a Dotan system.
The blade and casting shape are very similar to my old N6.0.
The casting, rudder release, etc, looks far superior on the Dotan. (Dotan much better)
How do these work in the real world, and are they standard on any Cats?
F-18 Infusion
#626- SOLD it!
Re: gcat rudder systems [Re: Todd_Sails] #167760
02/09/09 08:28 PM
02/09/09 08:28 PM
catman Offline
catman  Offline
I have had a set (Dotan). I have a Nacra system now. Without a doubt the Nacra system is better. It's simple, stronger and has less parts.
If you live on a deep lake (never hit the bottom or have to deal with surf) then you might like the Dotan system.
my .02
Re: gcat rudder systems [Re: Mary] #167907
02/10/09 11:24 PM
02/10/09 11:24 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Do have parts of the old rudder system?
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: gcat rudder systems [Re: TheManShed] #167908
02/10/09 11:28 PM
02/10/09 11:28 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
I have an old G-Cat 5.7 and I use to go through rudders until I had plates welded in the rudder housing to stiffen it up.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: gcat rudder systems [Re: Mary] #169475
02/25/09 01:53 PM
02/25/09 01:53 PM
Tampa, Fl
deepsees Offline
deepsees  Offline
Tampa, Fl
I talked to Hans about this too. About using lexan and forming it. He told me he had tried to do that too... but even lexan broke. The rudders themselves are foam cores with lamination. The metal parts are easy enough to construct, the glassing has to be done under vacuum to get that really complete bond.
The eleven hundred is not a bad price considering the aluminum welding and glassing. I bought just the glassed rudder from him for a hundred. Metal not included. He wanted 200... he will negociate.
Deepsees
1 registered members (JesperS), 754 guests, and 39 spiders.
