| Spinnaker sheeting point #169240 02/23/09 07:07 PM 02/23/09 07:07 PM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | Guys,
On the ARC21 trampoline there are grommets that run parallel to the tramp track. Can I use these grommets to mount a block for spi sheeting or will I pull out the tramp track?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Spinnaker sheeting point
[Re: davefarmer]
#169293 02/24/09 10:13 AM 02/24/09 10:13 AM |
Posts: 976 France | Eric, On Flight Risk I've got a vectran line run between the main beam and rear beam, with a loop tied in it where the turning block is located. It can be adjusted to move the sheeting point fore or aft.
Dave And if you rig the line below the trampoline and pull the loop out via one of the existing grommet, you have the perfect setup: at the right place, and it cannot tear your trampoline. | | | Re: Spinnaker sheeting point
[Re: pepin]
#169296 02/24/09 10:35 AM 02/24/09 10:35 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Maybe the designer will post?
He used to post all the time, where did he go?
I agree with several options that have been stated. Lee's 'shroud' suggestion, is where I put the block to sheet my high aspect spin to on my former N6.0. It'll hold, it's already there, etc.
F-18 Infusion #626- SOLD it!
634
guests, and 344
