| Brion Toss on high modulus line #169723 02/27/09 10:24 AM 02/27/09 10:24 AM |
Posts: 623 Gulf Coast | | | | Re: Brion Toss on high modulus line
[Re: tami]
#169754 02/27/09 12:35 PM 02/27/09 12:35 PM |
Posts: 5,525 | I'll bite. What's a high modulus line?
What's a modulus?
Can we do two tests at once?
"You're in a desert, walking along in the sand, when all of a sudden you look down... "
Pete Pollard Blade 702
[Re: mikekrantz]
#169781 02/27/09 04:02 PM 02/27/09 04:02 PM |
Posts: 41 Tampa, Fl | Hey Mike, I do load tests too... up to two million lbs force. We pull steel in half also. with some of the steel being HY... it always sounds like a bomb going off. Three inch diameter rebar too.
Doing load tests on ships too. Cranes and pad eyes... it is always interesting... because a test has two possibilities.... one of them is scary.
Deepsees
[Re: tami]
#169814 02/27/09 07:58 PM 02/27/09 07:58 PM |
Posts: 1,200 Vancouver, BC | I for one will never go back to cable trapeze. I've had the same 1/8" spectra trap lines on my boat for 4 years now...still going strong.
[Re: Tornado]
#169830 02/27/09 10:22 PM 02/27/09 10:22 PM |
Posts: 263 SC | Ha!
Mike Deepsees' punisher is bigger than yours!
Couldn't resist.
Always borrow money from a pessimist. He won't expect it back.
[Re: tami]
#169929 03/01/09 06:06 AM 03/01/09 06:06 AM |
Posts: 1,449 | Tami, Thanks- a good read.
| | | Phill!
[Re: phill]
#169998 03/02/09 09:45 AM 03/02/09 09:45 AM |
Posts: 623 Gulf Coast | Hi Phill,
Not that you're near that point ;-)
but we've had PRÉCOURT made shrouds on our Fboat for three years now. She doesn't stand rigged up, since she lives on her trailer.
But, that said... we just got our rig back from PRÉCOURT. We sent the shrouds to him for to check and replace if necessary. That because we'd noted some chafing on the lower ends near the deadeyes. Erik respliced them for us, saying that since there was enough to retuck, he would just tuck back most of the chafed bit and that the shrouds should last several more YEARS. When we got the boat the shrouds were already aboard, I have to assume for at least two years before us?
Frankly, I'm impressed with the durability. That said, we do take good care of the shrouds. When we rig down we are always VERY sure to thoroughly rinse the rigging in fresh water. Although I've never seen it documented, it seems to me that salt crystals in the fibres would chafe and cut, as they do in sails.
I've gone to PRÉCOURT rigging for my Square as well. Wow, it sure is nice to stow and deal with nice lightweight fibre rather than heavy 'have to stow it just so' wire (gotta avoid that stainless memory bending issue). I can't speak too much to how it's behaving on the Sq because I've been sailing the Fboat so much the Sq is rather bereft. Fibre shrouds have a bit more windage but I would imagine the weight aloft savings wins that battle.
Phill, if you've joined the Fboats yahoo list. One of the moderators is doing his own tests of UV degradation on textile rigging. Of course results take years ;-)
Now, I must say, after tooting the proverbial horn about fibre rigging... a couple of interesting notes: 1. Smyth is all wire-rigging on his F25C. I'm not sure why, but I do know he stores the boat mast up on a lifting rack behind his house. Which may well have something to do with his rig choice. 2.Scharl (GAMERA, arguably the second fastest F25C in the US) has moved from a textile canting rig back to all wire static rig. His crew Mark (Zaranski, or "Z") has recently posted at the Fboats list to elaborate why. It's a good read, I'll go search it up if you like.
To my knowledge, I don't think Smyth has ever canted his F25C, although I do believe the 31-1D that he was racing on (ROCKETEER) did cant, but then the 1D came stock with canting. IIRC. | | | Re: 'Mark Z' from Fboat discussion list
[Re: tami]
#170009 03/02/09 10:24 AM 03/02/09 10:24 AM |
Posts: 623 Gulf Coast | Mark Z on canting rigs, from the Fboats discussion:
"Canting became de rigeur for 31 1Ds.
We ran a doubled 3:1 (two lines pulled simultaneously) in Precourt eyes that were pulled by a 4:1 that was run along the top of the float (s) to behind the aft beam where the adjustable end turned to a clutch mounted on the aft surface of the beam close to the inboard end. I am pretty sure the final (ignoring the massive friction) mechanical advantage was 12:1.
Ira's posted pics of Rut Row's system are roughly similar to what we had.
To tack we would ease the rig down to leeward (awkward in every way) and pull up the soon-to-be windward side. Then tack. We never pulled the rig to weather while loaded.
Jib cars had to be moved aft (w/rig canted) to compensate for a) the narrower slot and b) the "less raked" position of the stick while canted.
The forestay stayed the same length, so canting the rig to either side would move the hounds in an arc... the farther away from center, the farther forward the hounds moved (taking the top of the mast even farther forward). This change dramatically effected the helm, making it quite neutral compared with the normal weather helm we have/had with the rig centered.
We worked it hard for two years, and I can't say (sorry all you pun averse) we ever found the canting system to be worth (in speed or point or feel) the complexity it added to our little boat with 2 or 3 crew program. Don't get me wrong, the system and the penalty we bore for it did not cause us to lose an event...it just never proved to be something that would allow us to win something we couldn't have won with a centered rig. We did lose on corrected time a race to two other 25s in St. Joe in light air. We beat them across the line so had we not had the penalty we would have won that race, but our problems had to do with being on the wrong side of the beat, NOT our speed.
We are now back to sailing with (gasp!) STAINLESS SHROUDS with turnbuckles!!!! We trade weight for (less windage and)lack of creep, the rig stays centered. And the float top is free from annoyingly taut amsteel blue dental floss and harken double blocks. The extra 8 meters of line trying to tangle with the main/screacher/spinnaker sheets is not missed either, nor is the weight (of the two clutches, 4 harken doubles *2 w/becket*, 4 precourt deadeyes, lots & lots of line, fasteners, etc.).
Like it or not, 3 sec/mile is almost non-existent on a course of a few miles. On a 300 mile course its a different story. None the less, we did not suffer from the approximately 15 minute penalty we carried for the Mac race in the two years we raced with the canting system. Do I honestly think the canting system improved performance over the entire course enough to cancel-out the rating penalty?
No.
Mark Z crew on Gamera, 2000 to present" | | | Textile rigging
[Re: Rolf_Nilsen]
#170010 03/02/09 10:34 AM 03/02/09 10:34 AM |
Posts: 623 Gulf Coast | Rolf, Brion Toss is arguably one of the best riggers in the US. He has a pretty comprehensive website which includes a discussion list. Toss, as you can see from the article, thinks quite well of textile rigging. Have a look at the 'spartalk' discussions. The Cruising Forums also have a fair amount of discussion regarding textile rigging. Dynex Dux is made by Hampidjan and they have data at the Hampidjan website http://www.hampidjan.com/For my part, I believe what people describe as 'creep' is actually alignment of the textile fibres, which if the rigging is left up would be easier to account for than for instance in my case whereat I rig down after sailing. | | | Re: Textile rigging
[Re: tami]
#170011 03/02/09 10:38 AM 03/02/09 10:38 AM |
Posts: 5,525 | So what's your conclusion? Textile or SS?
I replaced the braided wire end of my jib halyard with something blue (don't remember what it's called), because I got tired of the "meat hooks" in the wire. But, I use the jib so rarely I can't say one is better than the other, except for the hooks.
| | | Re: Textile rigging
[Re: pgp]
#170012 03/02/09 10:40 AM 03/02/09 10:40 AM |
Posts: 623 Gulf Coast | Yes.
Absolutely for running rigging. Every line on both my boats are some flavor of Amsteel. I don't know whether I'd use textile standing rigging if I were to leave the rig up in the weather or on an unguarded beach (butt factor, some bastard redneck would be sure to cut your line, 'hey y'all, watch this!'.)
| | | Re: Textile rigging
[Re: tami]
#170065 03/02/09 01:36 PM 03/02/09 01:36 PM |
Posts: 571 Hamburg | Hi all,
I tested dyneema for the shrouds on my beachcat last season. The advantages are low price (dyneema vs. steel with swages), easy handling (can be spliced by myself, can be stored with small radius) and the theoretical adavantage of lower weight, if there is one. The disadvantages are creep in case of dyneema (I had to retension the rigg every time, although I pretensioned the shrouds 10x during testing), bad balance between steel forstays and fibre shrouds (this is very specific to my boat with double forestays) and this bad feeling, that Tami describes.
The boat was all the time mast up on the beach, exposed to UV radiation and storms. I used covered (double braided dyneema). I switched back to steel, because I wanted to sail more and re-tension the shrouds less. The boat felt not different during sailing. At the end there is no clear yes or no. In future there might be a fibre which costs less than steel (including swages) and will not creep. Then the decission will be clear.
Cheers,
Klaus | | | Re: Textile rigging
[Re: Smiths_Cat]
#170108 03/02/09 04:12 PM 03/02/09 04:12 PM |
Posts: 623 Gulf Coast | guten tag Klaus,
don't give up on textile rigging. You should try Dynex Dux for your rigging, here's a quoted (from Navtec) nutshell why:
"...If you Anneal (cook while stretching) Dyneema, you make DUX. The strength goes up by 30-40% (depending on line size) and the stretch and creep drop to almost nothing. The line still has the same great UV and abrasion resistance as Dyneema, but now you have as low stretch and high strength as PBO. The line is also lighter and it doesn't absorb water, as compared to Vectran. The other positive about DUX is that it is only slightly more expensive than Vectran or Dyneema, vs. PBO which is incredibly expensive.
The only downside to DUX is that it is quite stiff when new, and will take a few days of sailing to soften up.
Uses for DUX include: Halyards, sheets, afterguys, outhauls, strops, standing rigging and any other low stretch/high strength applications.
DUX really is the new "Super Rope.""
21,588
guests, and 1,711
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,788 Yesterday at 09:11 PM | | |
