| Re: polishing hulls question
[Re: ejpoulsen]
#172321 03/19/09 01:15 PM 03/19/09 01:15 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | So should I be able to polish out the hull with the same Perfect-It or do I need to go to the Finesse? Eric, How'd your boat turn out? I think your boat is painted with Awlgrip. I wouldn't use heavy cut on Awlgrig. I'm speculating on your hull finish. I'd call Craig and ask him. Perfectit III will take out 800 grit scratches easily, I don't know about 100^^^.
[Re: ejpoulsen]
#172323 03/19/09 01:35 PM 03/19/09 01:35 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | So should I be able to polish out the hull with the same Perfect-It or do I need to go to the Finesse? When you polish surfaces you use the coarser compound first. Some people (most) will stop at that point. To do it right you need to go to the next step which is using a glazing compoud like the Finesse-it with a foam pad not the wool. This removes the fine scratcthes from the compound and truly polishes the surface. It's hard to tell on white however on something black you'd see the difference. If you don't glaze it the shine will seem to fade faster and stain easier. The finesse-it is a good product but the best that I've used is Meguiars #7 show car glaze applied with the foam pad at low speed.
[Re: catman]
#172333 03/19/09 02:08 PM 03/19/09 02:08 PM | andrewscott
| andrewscott
Unregistered | The wax is why your soo slow. I doubt the 1sq foot of wax area on my bow (that stu did while i wasn't looking) is whats slowing me down.... Wait i mean.. Yea, the wax must be why i am slower than you... | | | Re: polishing hulls question
[Re: SurfCityRacing]
#172356 03/19/09 04:07 PM 03/19/09 04:07 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen OP
Posts: 1,037 Central California | Jeremy, Craig just painted over some areas but didn't refinish the total boat. The boat mainly has gel coat, but it is very thin gel coat. Craig gave me the Perfect-It. So I'm just trying to spruce it up a bit more. Craig said I could polish with the stuff, but that seemed to thin out the gel coat (and paint) too much. It's perfectly functional just not boat-show-shine. I'm trying to figure out how to polish out the slightly matte finish I have on the bottom of the hulls without removing a lot of material.
The big work Craig did was fixing the leaking and cracked daggerboard wells and gluing the beams, which came out very nice. Can't find a nicer guy than Craig. Here it is a recession and the guy's shop has work bursting out of the doors. I was trying to do him a favor by doing the last bit of finishing work.
[Re: catman]
#172359 03/19/09 04:14 PM 03/19/09 04:14 PM |
Posts: 1,037 Central California | The finesse-it is a good product but the best that I've used is Meguiars #7 show car glaze applied with the foam pad at low speed.
Apply wet or dry? What is low speed? My machine goes down to about 200 RPMS.
[Re: ejpoulsen]
#172390 03/19/09 08:47 PM 03/19/09 08:47 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I've got a variable dewalt and on low it's 1000 rpm. Careful if you use a foam pad, to much pressure and you can over heat the surface causing small blisters. Don't ask me how I know  Thats using the meguiars. The # 7 is mainly a hand polish so it works best slower. No water. There's another product Aqua Blue. There's two grades coarse, fine. I use water with the fine only. Like it a lot. Geared more for gel coat.
272
guests, and 49
