making an a frame under cover #173672
04/02/09 03:30 PM
04/02/09 03:30 PM
tedb Offline OP
tedb  Offline OP
I would like to make some sort of A frame under the tramp cover to spill rain. I was thinking of placing an upside down bucket but am concerned this would make a ring on the tramp. Any homegrown solutions?
Re: making an a frame under cover [Re: tedb] #173673
04/02/09 03:39 PM
04/02/09 03:39 PM
mast up or down?
Re: making an a frame under cover [Re: tedb] #173677
04/02/09 03:43 PM
04/02/09 03:43 PM
tedb Offline OP
tedb  Offline OP
Currently mast is down but It will stay up in about a month. Cover is the vinyl hobie one that fits flat over tramp area.
Re: making an a frame under cover [Re: tedb] #173679
04/02/09 03:49 PM
04/02/09 03:49 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Mast down = mast makes a good A frame.
Mast up = boom makes a good A frame.
I tend to over-simplify things however.
Re: making an a frame under cover [Re: ThunderMuffin] #173683
04/02/09 04:02 PM
04/02/09 04:02 PM
tedb Offline OP
tedb  Offline OP
Boom won't fit the cover is too taught. The cheap blue wal mart tarp I have as an extra sags too much to shed water effectively. (I can maybe get it to fit once and then the grommets blow out)
Re: making an a frame under cover [Re: tedb] #173687
04/02/09 04:11 PM
04/02/09 04:11 PM
pgp Offline
pgp  Offline
Beach balls under the cover?
Pete Pollard
Blade 702
Re: making an a frame under cover [Re: tedb] #173688
04/02/09 04:11 PM
04/02/09 04:11 PM
Tad's got it right if you have enough material to work with. Use bungee under the boat to get your blue tarp taught enough to shed water, and on the ends to keep the breeze from getting ahold of it.
Re: making an a frame under cover [Re: pgp] #173690
04/02/09 04:19 PM
04/02/09 04:19 PM
tedb Offline OP
tedb  Offline OP
Brilliant!!
Re: making an a frame under cover [Re: tedb] #173697
04/02/09 05:02 PM
04/02/09 05:02 PM
andrewscott
andrewscott
i use the walmart tarp too.... (but i get the heavy duty one).
Re: making an a frame under cover [Re: ] #173710
04/02/09 07:37 PM
04/02/09 07:37 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
With the mast down, I put 2 pair of sawed-off snow skiis across the mast- that reach just to the gunnels. Then about a quart of water in 4 orange juice gallon bottles, or a PVC bleach bottle hold them down and sheds rain water.
Dacarls:
Re: making an a frame under cover [Re: tedb] #173779
04/03/09 11:40 AM
04/03/09 11:40 AM
srm Offline
srm  Offline
Punch a pair of grommets or sew a small webbing strap to the center of the cover. When the mast is up, connect your main halyard to the center points and pull it up to raise the middle of the cover.
When the boat is on the trailer with the mast down, tie a line from the center point up to the mast to hold up the cover.
sm
0 registered members (), 264 guests, and 46 spiders.
