Tiller Grip. #173853
04/04/09 06:17 PM
04/04/09 06:17 PM
South Texas
Rockport Offline OP
Rockport  Offline OP
South Texas
Looking for ideas to prevent the tiller from slipping while wearing gloves. What do you hard core racers use to keep a
firm grip,(on the tiller). My son suggested reverse wrapping duct tape, sticky side up. This will, however get the glue all over the gloves which in turn get on to the sheets,sails, etc. Ideas?
79 Nacra 5.2 #1145
Re: Tiller Grip. [Re: Rockport] #173857
04/04/09 06:58 PM
04/04/09 06:58 PM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
just get a bicycle grip that appeals to you. don't mess with tape. you are right it will get messy. i've never had a problem of losing my grip on the tiller. cheers!
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: Tiller Grip. [Re: Capt_Cardiac] #173858
04/04/09 07:11 PM
04/04/09 07:11 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Rigging tape works well.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Tiller Grip. [Re: Capt_Cardiac] #173859
04/04/09 07:24 PM
04/04/09 07:24 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
I cover my "Hotsticks" w/ the same stuff that they use on "Windsurfer" booms. It's a 1/8" thick Neoprene varient and comes in various colors. It also is used on the gunwales of the boat for traction ... excellent stuff!!!!
Call Murray's (www.murrays.com or 800-786-7245) ... it is 4" wide and can be purchased per/ft. Doug @ ex27 will know what you are asking for ...
For a "Hotstick" you will need to trim it ever so slightly ... approximently 1/8".
Also when you have to beat the crew w/ a stick for "slacking" ... you won't leave any marks ..... (HAHahaha...)
Good Luck
Harry
Re: Tiller Grip. [Re: HMurphey] #173868
04/04/09 09:52 PM
04/04/09 09:52 PM
Dunedin Causeway, FL
David Parker Offline
Hockey stick tape. Nearly waterproof, thin and lightweight, and very cheap. It's hard to find in Florida, however.
Re: Tiller Grip. [Re: David Parker] #173869
04/04/09 10:03 PM
04/04/09 10:03 PM
Second that...regular old athletic tape holds up well on an aluminum tiller.
Re: Tiller Grip. [Re: Jake] #173887
04/05/09 08:03 AM
04/05/09 08:03 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I've never had a hard time with my hand slipping on the tiller. Perhaps if you're having that much trouble with it, you need to look at your mast/rudder rake and see if your rudders are giving you a lot of weather helm.
I have, however had a problem with the stupid extendable tiller hot sticks unlocking at the most inopportune times and nearly causing a mishap.
Re: Tiller Grip. [Re: ThunderMuffin] #173890
04/05/09 10:28 AM
04/05/09 10:28 AM
HMurphey Offline
HMurphey  Offline
I've had the same issue w/ the extendable tiller sticks .... but I spend alot of time sailing in really light airs in the summertime here on the Chesapeake which means I'm usually sitting on the front crossbar steering the boat. I still have my one-piece tiller sticks but they get hung up in the trap wires and on the shroud when trying to tack or gybe the boat. So I haven't found a better solution yet .....
Harry
Re: Tiller Grip. [Re: F-18 5150] #173894
04/05/09 11:02 AM
04/05/09 11:02 AM
+1 - I really like that stuff.
Re: Tiller Grip. [Re: John Williams] #173910
04/05/09 05:14 PM
04/05/09 05:14 PM
Southampton UK
NacraKid Offline
NacraKid  Offline
Southampton UK
Cheap way is to wrap a bit of string round your stick then stick tape over it.
Re: Tiller Grip. [Re: NacraKid] #173915
04/05/09 06:23 PM
04/05/09 06:23 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
I use some "o" rings with heatshrink over the top. 5 to 10cm between the "o" rings. Gives a physical barrier to pull and push against so can have a loose grip on the extension.
Darryn
Re: Tiller Grip. [Re: Darryn] #173917
04/05/09 07:03 PM
04/05/09 07:03 PM
cork ball on the end. prevents the end from messing up the deck alot (if you are lucky enough only to have the end hit the deck) mine came that way. Was Matt M's boat. maybe that is his secret:)
I live in fear of the tiller extension slipping on the 31. talk about an OH **** moment. bury the lee bow and PULL and slip! yikes.
Re: Tiller Grip. [Re: PTP] #173919
04/05/09 07:26 PM
04/05/09 07:26 PM
Darryn Offline
Darryn  Offline
Tried the cork ball, found it got in the way alot and the extra drag when tacking or steering with crossbar wasn't worth it. Also can be handy to sink the extension to move it behind the rudders post capsize.
Darryn
Re: Tiller Grip. [Re: Darryn] #173957
04/06/09 09:11 AM
04/06/09 09:11 AM
andrewscott
andrewscott
just hammer some 4" nails through the tiller all over the place.. they will provide plenty of "GRIP" and all the blood will help to lube the stick and keep it slick when trying to extend.
Re: Tiller Grip. [Re: ] #173960
04/06/09 09:17 AM
04/06/09 09:17 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
I don't advise this method if your sailing in salt water too much corrrosion. Glass shards and west system will produce the same result though.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Tiller Grip. [Re: F-18 5150] #173961
04/06/09 09:26 AM
04/06/09 09:26 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Hockey tape - We have hockey in Florida...mostly concrete hockey but some ice hockey...it's indoors though.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Tiller Grip. [Re: TheManShed] #173968
04/06/09 09:44 AM
04/06/09 09:44 AM
catman Offline
catman  Offline
Rigging tape good. A little cheaper and just as good, I found at home depot a clear (translucent) silicone tape in the plumbing dept used for pipe leaks. Works just like rigging tape.
Re: Tiller Grip. [Re: TheManShed] #173970
04/06/09 09:47 AM
04/06/09 09:47 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
And Dennis Palin says:
(everyone is listening in a hush right now)
that you rarely 'grip' the tiller, rather, you lightly touch it, and 'will' it where it needs to go.
As has been said, if your helm is that hard to steer, definitley need to rake in your rudders!
Heavy on the helm = SLOW
F-18 Infusion
#626- SOLD it!
Re: Tiller Grip. [Re: Todd_Sails] #173979
04/06/09 11:42 AM
04/06/09 11:42 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
This is very true on a well balanced boat. The T only needs very slight thumb & index finger movements to hold course.
I like to be able to let go of the tiller breifly (when needing two hands to yank on the mainsheet for example)...so being able to place the tiller on the deck without it sliding away out of reach or just moving at all is very important. I've used rigging tape on the tiller extension and yes it works. But, over time is does get chewed up and lumpy (not good when I toss the tiller over the rear beam during spinny runs), plus a roll of this tape runs about $15-$25 bucks for something like 15 ft....so renewing is regularly gets expensive.
I much prefer the thin grip foam from Murray's...use a good contact cement to adhere it (comes with a small can). You can sand off (I used a dremel with a sanding drum) any overlapped sections after it's stuck down. This stuff lasts for 5+ years per application. The surface is very smooth yet it is easy to grip. I can place the tiller on the deck and it stays put quite well. I can toss the tiller over the rear beam and not get much drag off the waves.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Tiller Grip. [Re: Tornado] #173980
04/06/09 11:49 AM
04/06/09 11:49 AM
I'll second the heat shrink tubing, that's what Hobie started putting over the standard glass H16 stick.
Whatever that black stuff is named, designed for baseball bats, turns into a soggy mess when it gets wet...don't ask me how I know frown
0 registered members (), 703 guests, and 47 spiders.
