Re: Vacuum Pumps [Re: Gato] #175496
04/21/09 01:59 AM
04/21/09 01:59 AM
Dont drop out on us on your projects, I love seeing the pictures of homebuilt stuff! Foam carbon mast, now that is a _wildly_ interesting project. Also, you never told me how you made the mast track, or did you?
That's exactly what it is, to primitive for a lot of freaks...
As long as it does the job and is cheap.. Who cares.
Where do you buy stuff like peel ply, vacuum tubing etc?
Re: Vacuum Pumps [Re: Rolf_Nilsen] #175501
04/21/09 02:56 AM
04/21/09 02:56 AM
Finland
Gato Offline
Gato  Offline
Finland
No intention to drop out. Peel ply well from the dressmaker or from your supplyer of epoxy, glass carbon etc.
Plastic tubing? For the bagging of spars just ask the guy who sell the Peel ply to give you some extra of the "tubes"he uses for packing the stuff he is selling you.
The blue tubing seen in the pic you get from the store where they sell pneumatic stuff (about 50 cent/m)
Re: Vacuum Pumps [Re: Gato] #179069
05/20/09 03:16 PM
05/20/09 03:16 PM
pgp Offline
pgp  Offline
"There may be a minor leak in the pleats and folds of the bag that is nearly impossible to find. "
Buy a cheap stethoscope, the leak will sound like a freight train. With a little practice you can "see" the leak as the surrounding area will not be pulled down as tightly as the rest.
Pete Pollard
Blade 702
Re: Vacuum Pumps [Re: pgp] #188395
08/18/09 10:08 PM
08/18/09 10:08 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
This is good post to back and read now after the first bagging job.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Vacuum pump question [Re: TheManShed] #193800
10/17/09 01:15 PM
10/17/09 01:15 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Ok, so I got a vacuum pump from ebay. An oil rotary thing, label says it pulls full vacuum (0.0001 tor), 2 cubic meters per hour.
Unfortunatelly the motor is 3 phase 380 Volts, 1360RPM. I only have 1 phase 220 Volts connection so I was thinking of replacing the motor with a 220v one. The motor is physically very easy to replace, it has a flexible coupling to the pump shaft and 4 screws securing it to the frame.
Question: what happens if I put a faster motor on it ? Say 2000-3000rpm instead of 1360rpm as the old motor. Will it suck more air per hour (faster) or will it fry the oil and the internals ? Also what type of oil to use with it ?
Thanks guys.
Regards
Florin
Re: Vacuum pump question [Re: isvflorin] #193861
10/18/09 02:26 PM
10/18/09 02:26 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Problem solved, sold the pump. Got another one.
Florin
Re: Vacuum pump question [Re: isvflorin] #193881
10/19/09 01:23 AM
10/19/09 01:23 AM
You are moving fast these days.
Did you find out what oil it was filled with?
Re: Vacuum pump question [Re: Rolf_Nilsen] #193882
10/19/09 02:22 AM
10/19/09 02:22 AM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Well , did some reading:
you are expected to use only vacuum pump oil for vacuum pumps (imagine that). Unless you are a chemist don't put anything else in there if you care for the life of the tool and the final vacuum level.
Vacuum pump oil is graded for different types of pumps, different speeds and different vacumm levels, so it is tricky business, your manufacturer will supply those.
Also if you're in doubt about the oil you have - if it is yellowish or any other colour - don't use it. The good vacuum pump oil must bea clear/transparent.
Also Shell makes something that appears to be general use vacuum pump oil - SHell Corena V
Florin
0 registered members (), 20,439 guests, and 536 spiders.
18 hours ago
