| Re: self-tacking and/or roller furling jib???
[Re: pepin]
#175069 04/16/09 12:38 PM 04/16/09 12:38 PM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | Hi Pepin, You are correct as I kind of mixed your two sentences together in your first post. But I'm not sure if a new or re-cut jib would be reguired for the installation of a roller furler. Your advice about when having your jib secured w/ a tie strap when furled is exactly how I leave my TheMightyHobie18 over-night at a regatta ... but I do remove my jib if I'm not sailing the next day. Note I've lost count of how many times I've had to secure someone elses jib flapping in the breeze ... of course you have to remember to UNTIE the strap before leaving the beach (Don't ask me how I know ....) I could find nothing in the background of the H16 to indicate where the picture was taken ... the custom sails and all-aluminum mast (and your european location) lead me to believe that the picture was from Europe. But my comments about the comptip/spinacker are sound I believe. I could tell from the cars in the background that the H14's were located in the USA (also the lack of a front license plate indicates to me that one of the cars maybe from Pennsylvania, there are only 2-3 states that do not require both a front and back license plates) Do we know "where" those two H14's are from??? Virginia Beach area??? ... Dan Berger??? .... Dan had organized a nice little fleet of H14's w/ Hooters/Screechers racing in Va Beach several years ago. I don't think the installation of "Adjustable Spreaders" would be to difficult on a N5.2. They are availible through Annapolis Performance Sailing ie: APS at www.apsltd.comHarry | | | Re: self-tacking and/or roller furling jib???
[Re: HMurphey]
#175073 04/16/09 01:48 PM 04/16/09 01:48 PM |
Posts: 976 France | I could find nothing in the background of the H16 to indicate where the picture was taken [...] I could tell from the cars in the background that the H14's were located in the USA [...] You don't need to do as much detective work: as I said, those pictures are from Whirlwind, on their page there are captions locating the H16 on Long Island, New York and the two H14 in North Carolina. I've never had a comptip, when I was sailing my H16 in California it was an old model, with an all aluminum mast. | | | Re: self-tacking and/or roller furling jib???
[Re: saylor_nacra]
#175102 04/16/09 05:36 PM 04/16/09 05:36 PM |
Posts: 41 Tampa, Fl | I let the main go loose and pull the jib in tight, the G-Cat points so well that it appears to be sailing face on to the waves. It will hold this action as long as I need it to. I rake forward most of the time when I step. Neutral tiller load.
Deepsees
[Re: saylor_nacra]
#175299 04/20/09 03:33 AM 04/20/09 03:33 AM |
Posts: 757 japan | hobie say that square top sail is simply better all round The square top sail is remarkable because it provides significant advantages in nearly all sailing conditions with practically no compromises. The most noticeable difference of the square top sail is the additional sail area up high. In light winds the benefit is simple. More sail area means more power, but contrary to what you might think the additional sail area actually makes the boat more forgiving in strong or gusty wind. Old school thinking would believe that the extra sail area up high would tend to tip the boat over easier, but in reality the extra sail area causes the sail to twist more and cause the top of the sail to flatten out. The net result is the center of lift of the sail moves down and the over all drive of the boat increases with less tendency to tip over. This is done automatically which makes the boat easier to sail in gusty wind. The more subtle benefits are; >> The improved planform of the sail. The most efficient wing or sail is one with an elliptical planform. The square top sail more closely approximates an ellipse. http://www.hobiecat.com/sailing/sail_bravo.html wonder why they don't have them on the H16??? if i'm going to spend a $1000 it may as well be on a new sail as opposed to roller furling equip. or self tacking...
[Re: erice]
#175443 04/20/09 04:41 PM 04/20/09 04:41 PM |
Posts: 15 Clear Lake,Texas | I got a mast off of an Inter 17 with raked spreaders to replace the mast with straight spreaders on my 5.2. You would definitely have to cut/replace the overlapping jib. I hope to put a self-tacking jib on the newer mast and add a square-top main. I'm sure that I'll be wanting a spinnaker on it soon after, to improve my downwind speed.
Trey
Nacra 5.2 "Silver Bullet" #333 TCDYC | | | Re: self-tacking and/or roller furling jib???
[Re: erice]
#175446 04/20/09 04:48 PM 04/20/09 04:48 PM | DougSnell
| DougSnell
Unregistered | hobie say that square top sail is simply better all round The square top sail is remarkable because it provides significant advantages in nearly all sailing conditions with practically no compromises. The most noticeable difference of the square top sail is the additional sail area up high. In light winds the benefit is simple. More sail area means more power, but contrary to what you might think the additional sail area actually makes the boat more forgiving in strong or gusty wind. Old school thinking would believe that the extra sail area up high would tend to tip the boat over easier, but in reality the extra sail area causes the sail to twist more and cause the top of the sail to flatten out. The net result is the center of lift of the sail moves down and the over all drive of the boat increases with less tendency to tip over. This is done automatically which makes the boat easier to sail in gusty wind. The more subtle benefits are; >> The improved planform of the sail. The most efficient wing or sail is one with an elliptical planform. The square top sail more closely approximates an ellipse. http://www.hobiecat.com/sailing/sail_bravo.html wonder why they don't have them on the H16??? if i'm going to spend a $1000 it may as well be on a new sail as opposed to roller furling equip. or self tacking... I LOVED the square top I put on my H-17. I got a Pentex from Sabre that Bill Curry cut for me. In puffs the boat just MOVED!!! And as said, it was better in light air. Get one. Doug | | | Re: self-tacking and/or roller furling jib???
[Re: HMurphey]
#175456 04/20/09 06:26 PM 04/20/09 06:26 PM |
Posts: 921 Alachua, FL | there are only 2-3 states that do not require both a front and back license plates) SC, GA, FL for three off the top of my head
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: self-tacking and/or roller furling jib???
[Re: Mugrace72]
#175479 04/20/09 10:31 PM 04/20/09 10:31 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | there are only 2-3 states that do not require both a front and back license plates) SC, GA, FL for three off the top of my head Louisiana too. We so fast you only see us leaving!  Clayton | | | Re: self-tacking and/or roller furling jib???
[Re: Mugrace72]
#175526 04/21/09 07:23 AM 04/21/09 07:23 AM |
Posts: 623 Gulf Coast | there are only 2-3 states that do not require both a front and back license plates) Um, it's more like 20 states which don't require both plates: From Wikipedia: "In the U.S. states of Alabama, Arizona, Arkansas, Delaware, Florida, Georgia, Indiana, Kansas, Kentucky, Louisiana, Massachusetts (most plates issued prior to 1988 - see note below), Michigan, Mississippi, New Mexico, North Carolina, Oklahoma, Pennsylvania, South Carolina, Tennessee, and West Virginia, license plates are only required on the rear of the vehicle. Some vanity and specialty plates in Arizona and Kansas are issued in pairs, but only the rear plate is required to be displayed; the optional front plate is something of a bonus for paying an extra fee for the plate. Massachusetts is a unique case for license plate mounting. Before the introduction of the current "Spirit of America" base starting in 1986 for commercial vehicles and vanity plates and 1988 for all other vehicles, the state issued only a single green-on-white plate to be mounted on the rear bumper. With the current-issue base, two plates are issued, to be mounted on both the front and rear bumpers. Since all license plates issued since 1978 are currently valid, most passenger vehicles registered in Massachusetts display two plates, and those with the older green-on-white plates only display one." | | | Re: self-tacking and/or roller furling jib???
[Re: erice]
#175529 04/21/09 07:27 AM 04/21/09 07:27 AM |
Posts: 1,203 uk | hobie say that square top sail is simply better all round
There's someone thats never tried bearing off round the windward mark in a force on the H16 pinhead sail let alone a square top!
[Re: HMurphey]
#175553 04/21/09 10:01 AM 04/21/09 10:01 AM | andrewscott
| andrewscott
Unregistered | I have been living in FL for 14 years, there has been no front plate issued since i lived here. | | | Re: self-tacking and/or roller furling jib???
[Re: HMurphey]
#175591 04/21/09 01:13 PM 04/21/09 01:13 PM |
Posts: 330 | Please note that while there have been some "major" changes/upgrades to the H16 over the years (IMHO), most notable the re-designed front crossbar, the IHCA still claims it is operating a "One-Design" class. This is a "pet peeve" of mine as the TheMightyHobie18 and H17 have basically had no changes/upgrades since the day those models where first produced.
Harry
By redesign of the front crossbar, I assume you're refering to the integrated traveler tracks. Hobie did the exact same thing with the 17 rear cross bar (and later front cross bar) by integrating those tracks. The 18 already has an integrated traveller track. And each of the Hobies you mention (16, 17, & 18) have gone through changes to their respective hull lay-ups which have significantly altered the overall boat weights (either increase or decrease). Additionally, they have ALL had changes (minor & major) to the sail cuts since being introduced. So really, all of the boats have had major and minor changes throughout their 25 to 35 year existance...it's not just the 16. Sorry to drag the thread so far off topic. sm | | |
2,593
guests, and 166
