| Re: Tiger tramp attachment
[Re: davefarmer]
#175615 04/21/09 05:46 PM 04/21/09 05:46 PM | Scarecrow
| Scarecrow
Unregistered | Dave the short answer is as much curve as possible. work out how far outboard you can get the lacing points on the beams and then assume the tramp will be level with the hull side at the apex of the curve (because of stretch it will end up overlapping a bit). | | | Re: Tiger tramp attachment
[Re: Karl_Brogger]
#175626 04/21/09 08:10 PM 04/21/09 08:10 PM |
Posts: 1,430 california | My tramp has 2 tie down points on the side of the tramp that tie to the hull. I'll try to get a pic.
[Re: Karl_Brogger]
#175658 04/22/09 04:11 AM 04/22/09 04:11 AM |
Posts: 2,584 +31NL | On the Tiger the "tie down" is just an eye with a screw going directly into the hull, if you can handle a screwdriver this is very easy to make. I have sailed on all the current F18 models and I dont think the Tiger tramp is any softer than others, maybe the ones before 2003 (old style tramp) where though. Something I dont like about the Infusion/Tornado style tramp is the amount of screws sticking out of the hull just waiting to rip though your suit. If you want the tramp to be really tight you could splice a thimble to the end of the line going through and use the mainsheet to tighten the whole thing up. | | | Re: Tiger tramp attachment
[Re: Tony_F18]
#175671 04/22/09 07:01 AM 04/22/09 07:01 AM |
Posts: 12,310 South Carolina | On the Tiger the "tie down" is just an eye with a screw going directly into the hull, if you can handle a screwdriver this is very easy to make. I have sailed on all the current F18 models and I dont think the Tiger tramp is any softer than others, maybe the ones before 2003 (old style tramp) where though. Something I dont like about the Infusion/Tornado style tramp is the amount of screws sticking out of the hull just waiting to rip though your suit. If you want the tramp to be really tight you could splice a thimble to the end of the line going through and use the mainsheet to tighten the whole thing up. Perhaps it's the method of tightening it - but I've sailed on three different Tigers and felt that the trampoline was mush on all of them. While it may appear that the mushroom screws would lend themselves to snagging things, I've never experienced this and think they make a good clean and very tight connection.
Jake Kohl | | | Re: Tiger tramp attachment
#177061 05/04/09 08:57 PM 05/04/09 08:57 PM |
Posts: 4,119 Northfield Mn | This weekend was clean/wax/fix stupid stuff on the boat weekend.
All right, I'm on the verge of giving up, or just need a more realistic expectation. Switched the sides to 1/8" spectra. Had to re-lace the back with some 3/16", (more like 5/32") line, cause its all I had, and the original 1/8" stuff broke in round two of tightening. I think I'll switch that out to some 1/8" or 3/32" spectra too next time I order something.
The truckers hitch that I use at the front of the tramp I hooked my main blocks onto that loop and pulled it tight. Any tighter I think I'll be ripping crap out. There is hardly any deflection when you try to squeeze the lines at the front at an angle.
I went through the back lacing with a couple of prybars and pulled loop by loop to get it tight. Went through it probably four times, including the just lacing it part.
I think I could get the back a bit tighter, but not much. The result is much better than what it was, but its still spongy. I had a H14 with a new solid vinyl tramp and I got that baby literally drum tight. | | |
641
guests, and 43
