| Re: Carbon spreaders
[Re: mikekrantz]
#175982 04/24/09 08:45 AM 04/24/09 08:45 AM |
Posts: 3,906 Clermont, FL, USA |
[Re: mikekrantz]
#175984 04/24/09 08:59 AM 04/24/09 08:59 AM | andrewscott
| andrewscott
Unregistered | I can't wait for mine to arrive.
I calculate the extra lift generated by the heli foil shape and increased righting moment from reduced weight aloft is going to give me an extra 5 degrees of pointing ability.... Dont forget to include the increased speed your travler will enjoy (with your onedrop mclube) you will tack faster! NO ONE WILL EVER BEAT YOU!!!! EVER! (EVER).. PS with all this brown-nosing... can i get a LayLine sponsorship? Say... free line and onedrop for life?  | | | Re: Carbon spreaders
[Re: ]
#175990 04/24/09 10:39 AM 04/24/09 10:39 AM |
Posts: 712 | Come to our regatta next weekend and I'll give you a free Zhik hat, and one-drop your traveler... http://www.llsc.com/database/RegattaNotice/2009-CincoDeMayo-NoR.pdfIn fact, everyone that attends our regatta next weekend will get a free one-drop treatment on their boat.
[Re: mikekrantz]
#175992 04/24/09 11:03 AM 04/24/09 11:03 AM | andrewscott
| andrewscott
Unregistered | | | | Re: Carbon spreaders
[Re: ]
#175994 04/24/09 11:17 AM 04/24/09 11:17 AM |
Posts: 6,049 Sebring, Florida. | Mike, I am going to post the NOR to the Delta Pilot's web site, as there are quite a few in the Atlanta area, so maybe some will show up.
Blade F16 #777
[Re: Timbo]
#175996 04/24/09 11:55 AM 04/24/09 11:55 AM |
Posts: 712 | | | | Re: Carbon spreaders
[Re: Timbo]
#176015 04/24/09 01:28 PM 04/24/09 01:28 PM |
Posts: 1,449 | Or make them out of pre-preg carbon with a UV inhibitor already in the resin.
[Re: phill]
#176016 04/24/09 01:46 PM 04/24/09 01:46 PM |
Posts: 12,310 South Carolina | I think the bigger concern is the black carbon getting hot in the sun (VERY hot) and causing the resin to lose mechanical stiffness. The only way to help mitigate that is to cure the laminate at a high heat but that only makes it soften at a slightly higher temperature post cure.
Jake Kohl | | | Re: Carbon spreaders
#176048 04/24/09 06:28 PM 04/24/09 06:28 PM |
Posts: 1,449 | Jake, If you use a higher temp pre-preg and ramp up the cure to 110 - 120degC in the last few hours of the cure cycle I expect the softening would not occurr.
619
guests, and 36
