Re: Carbon spreaders [Re: ] #175981
04/24/09 08:44 AM
04/24/09 08:44 AM
mikekrantz Offline
mikekrantz  Offline
I can't wait for mine to arrive.
I calculate the extra lift generated by the heli foil shape and increased righting moment from reduced weight aloft is going to give me an extra 5 degrees of pointing ability....
Re: Carbon spreaders [Re: mikekrantz] #175982
04/24/09 08:45 AM
04/24/09 08:45 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Whats it rate?
F18 USA 242
http://www.solarwind.solar
Re: Carbon spreaders [Re: ] #175983
04/24/09 08:58 AM
04/24/09 08:58 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
if you're going for cheap and light,
if you cant duct it, then .... it
Re: Carbon spreaders [Re: mikekrantz] #175984
04/24/09 08:59 AM
04/24/09 08:59 AM
andrewscott
andrewscott
Dont forget to include the increased speed your travler will enjoy (with your onedrop mclube) you will tack faster! NO ONE WILL EVER BEAT YOU!!!! EVER! (EVER)..
PS with all this brown-nosing... can i get a LayLine sponsorship? Say... free line and onedrop for life? smile
Re: Carbon spreaders [Re: ] #175990
04/24/09 10:39 AM
04/24/09 10:39 AM
mikekrantz Offline
mikekrantz  Offline
Come to our regatta next weekend and I'll give you a free Zhik hat, and one-drop your traveler...
http://www.llsc.com/database/RegattaNotice/2009-CincoDeMayo-NoR.pdf
In fact, everyone that attends our regatta next weekend will get a free one-drop treatment on their boat.
Re: Carbon spreaders [Re: mikekrantz] #175992
04/24/09 11:03 AM
04/24/09 11:03 AM
andrewscott
andrewscott
wahooooo! your the best!
Re: Carbon spreaders [Re: ] #175994
04/24/09 11:17 AM
04/24/09 11:17 AM
Mike, I am going to post the NOR to the Delta Pilot's web site, as there are quite a few in the Atlanta area, so maybe some will show up.
Re: Carbon spreaders [Re: Timbo] #175996
04/24/09 11:55 AM
04/24/09 11:55 AM
mikekrantz Offline
mikekrantz  Offline
Thanks Tim.
Re: Carbon spreaders [Re: Timbo] #176015
04/24/09 01:28 PM
04/24/09 01:28 PM
Or make them out of pre-preg carbon with a UV inhibitor already in the resin.
Re: Carbon spreaders [Re: phill] #176016
04/24/09 01:46 PM
04/24/09 01:46 PM
I think the bigger concern is the black carbon getting hot in the sun (VERY hot) and causing the resin to lose mechanical stiffness. The only way to help mitigate that is to cure the laminate at a high heat but that only makes it soften at a slightly higher temperature post cure.
Re: Carbon spreaders [Re: Jake] #176022
04/24/09 02:18 PM
04/24/09 02:18 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
There are resins that wont soften in the sun, but they need to be heat cured. Its easier just to paint critical parts white and use the room temp stuff.
Re: Carbon spreaders [Re: Jake] #176048
04/24/09 06:28 PM
04/24/09 06:28 PM
Jake,
If you use a higher temp pre-preg and ramp up the cure to 110 - 120degC in the last few hours of the cure cycle I expect the softening would not occurr.
1 registered members (vasil), 289 guests, and 39 spiders.
