| Re: Waxing hulls, how bad does it affect performance
[Re: malc]
#17603 03/24/03 12:07 PM 03/24/03 12:07 PM |
Posts: 833 St. Louis, MO, | Wax on, wax off, young son.  Seriously, I wax my H20 a couple of time a year. It keeps the stain off the boat. I've never noticed a performance difference. If anything I think wax is faster because it helps keep the road grime off the hulls. A good looking hull is a fast hull. Keep One Hull Flying, Mike Hill H20 #791
Mike Hill N20 #1005
[Re: carlbohannon]
#17605 03/24/03 06:34 PM 03/24/03 06:34 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Well your right the flow is laminar. But to have a good flow besides the abstence of scratchs and dings you need the proper boundry layer. Correct me if I'm wrong,that is the layer that holds the unmoving water. Remember the hull does not sit at a static attitude. It is constantly moving up and down. Wax repels water. That tends to introduce air in the area of the hull that is moving in and out of the water and disturb the laminar. Now that might seem like a small thing to worry about to some but when I spend the time on everything else to make sure it's in top shape I'm not going to smear wax all over my hulls.
Just point out the importance of the boundry layer, you might remember the 3M material called riblets that was applied to the bottom of Stars and Stripes. It was a textured material that held water,thus improving the boundry layer. I built custom sailboats and they are painted with Imron or awlgrip. Finishes which don't require wax. For a while I had a 100 grit finish on my boat and I swear it was the fastest.
If your coming by the causeway to race I encourage you to wax up real good. Have fun Mike
[Re: malc]
#17606 03/24/03 08:57 PM 03/24/03 08:57 PM |
Joined: Apr 2002 Posts: 170 Australia (Queensland) Berthos
Posts: 170 Australia (Queensland) | According to Frank Bethwaite (author of 'High Performance Sailing',18'skiff, tasar, 59er designer, father of Julian Bethwaite, 49er designer), who has done extensive testing of his claims, the more highly polished a surface is the less drag it has. Laminar flow has significantly lower co-efficients of drag that turburlent flow - this is why modern airliners can fly as fast and efficiently as they do, they use laminar flow foils. Any imperfections cause the flow to become turbulent thus increasing drag. In tests comparing highly polished centreboards with those sanded slightly to remove the shine, the highly polished boards came out in front every time. To read an article on this very subject by Frank see: http://www.bethwaite.com/bethwaite/publications/fastestfoils/fastestfoils_0987.htmCan waxing give a highly polished surface? If so then waxing would give a low drag surface, better than one that had been sanded. Frank found stainless steel polished to a mirror finish to be very low drag. Rob. | | | Re: Waxing hulls, how bad does it affect performance
[Re: malc]
#17611 03/25/03 11:15 AM 03/25/03 11:15 AM |
Posts: 41 Clearwater, FL | Malc
Here's my $.02 worth....
I bet the Kiwi's had someone committed to hull preparation, didn't much matter since their boat fell apart!
I sail a 1984 boat, I win some, I lose some.....and I'll bet you everyone who has responded not to wax loses races too. While I'm sure there is a definitive answer on the subject, waxing protects your boats finish and increases the longevity and value of the boat. Think about the REAL speed difference in waxing and not waxing. On a typical triangle (or even a distance course) I seriously doubt it would add up to the time lost by one blown tack or a misjudgment on downhaul/sheet tension, weight distribution, etc. Sail fast and sail smart....wax your boat and be proud of the way it looks, if you lose you can blame it on the shine even though you know it was really your blown tack or the fact that you went high on the course when the leaders went low, etc., etc. etc.
Jeff Worman SC17 Smokin' | | | Re: Waxing hulls, how bad does it affect performance
[Re: malc]
#17612 03/25/03 06:51 PM 03/25/03 06:51 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Ok, I see where the problem lies. Some of you think wax and polish are the same thing. One is a protective coating, the other smoothes the surface. Polishing compounds can and are added to wax. I never said sand your hulls,I said don't put wax on them if your racing. I assume that your hulls are polished and smooth.
Malc,I would say forget about the performance question for now. I would suggest you wax your hulls and see how long it takes before the hulls discolor. Now remember how much work you put in to waxing the hulls. Also wax does not nessesarly clean the discoloration on the hulls. This means you will have to use something like snobol first to clean them. Then once they discolor take the snobol wipe them down and see how long it takes for them to discolor again. Decide for yourself which type of maintenance leaves you more time to sail and is simplest and cheaper and....Oh yea, silly. I don't know how much you sail but my boat goes in on friday and stays in until late sunday and it takes about a month and a half before the discoloration gets to the point that I want to clean them. 10 minutes with snobol and they look like new.
The link offered has some incorrect info. Stars and Stripes, the 12 meter had a material that was applied in sheets that had a adheisive backing. Not a polish. Also any gain no matter how small can be important. I'll take 1 foot ahead over one foot behind at the finish line anyday. One of the Tornado sailers was helping another couple with the rigging on their boat in a effort to remove weight. He said they would work on the ounces and that would soon become pounds.
One more thing,orbital buffers that are used for waxing. Some quality orbitals have a very smooth action. Others are brutal. I would use caution vibrating the hull. It could cause a separation of the foam from the outer laminate.
Have Fun Mike
[Re: carlbohannon]
#17616 03/26/03 11:28 AM 03/26/03 11:28 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | From an engineering standpoint, I can see pros and cons both ways. I actually pulled out a couple of my Chem E books and did a little research, but.... I figure it helps keep the grime off the hulls, so a smooth clean hull is faster than a dirty one. But the real difference that I see depends on what part of the boat I put the wax on. If I wax the area around my or my crews feet, I tend to not do as well...I think it stems from my crew taking the stick out of my hands and beating me with it to show me his appreciation for the nice new wax job.  Will | | |
2,742
guests, and 394
