Mossie Trailer #176062
04/25/09 05:14 AM
04/25/09 05:14 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
OK, So I have purchased a new boat - No Trailer. Maybe I will buy the one on the Mossie web site. So I send off an email - Sold last week frown
I decided I had better build one , so here are some manufacturing pictures after todays efforts.
The trailer is the right way up and shackle hangers for the springs are on.
IMGP0424 small.jpg (713 downloads)
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Mossie Trailer [Re: Trevor] #176063
04/25/09 05:16 AM
04/25/09 05:16 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
And another pic - same angle but more of it seen
IMGP0423 small.jpg (702 downloads)
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #176084
04/25/09 09:18 PM
04/25/09 09:18 PM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
looks good trev, i could be wrong but your axle set up looks a bit far forward? i have built many trailers for boats over the years, i am sure you have done many yourself, i have always welded the shackles on to a fairly solid piece of angle iron each side. this allows the axle set up to be moved forwards and backwards along the trailer to adjust the weight on the hitch, once you have settled on the position of the boat. this helps if you are travelling long distances, i.e. more than 45 mins and speeds greater than 80km/h you will need to move the axle further back, the higher the speed the further back the axle goes to stop the trailer swaying in the breeze. trev, i apologise if you know all this, maybe someone else will read and they might find it handy
cheers mate and good luck!!!!!
p.s. dont be shy on the cold galv!!!!!!
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: Mossie Trailer [Re: Brian P] #176096
04/26/09 03:18 AM
04/26/09 03:18 AM
twicebitten
twicebitten
Hi all,
I think I could fairly say that I have towed cats more K's than most sailors in recent years. Too much weight on the hitch is one of my pet hates. I don't think having the axle along way back is neccessary for a good towing trailer.
My last 2 trailers I could pick up with one hand at the hitch, actual trailer weights where light also and they towed great at speed, even when double decked. Plenty of attention to trailer stiffness and no slop in suspension bushes and bolts seemed to do the trick.
Re: Mossie Trailer [Re: ] #176099
04/26/09 04:11 AM
04/26/09 04:11 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Fair point Gary but too far forward is dangerous
regards Jeff
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Mossie Trailer [Re: JeffS] #176101
04/26/09 04:38 AM
04/26/09 04:38 AM
greymatter Offline
greymatter  Offline
As Brian has said all of my trailers have had axles that can be moved, on a sliding angle iron, with u bolts to hold in place,this alows the axle to be moved to the right position after everything is set in place. you never know when you need to move the axle forward to comensate for an extra box on the trailer
Re: Mossie Trailer [Re: greymatter] #176107
04/26/09 06:42 AM
04/26/09 06:42 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
Placement of the axle was a bit of a concern, as I dont want anything more than about 15Kg on the tow ball. The way I load going to a regatta has a full esky on the drawbar in front of the coffin that puts the weight up to about 45 - 50 Kg and that is where most of the km's are done.
Done some more work today, as well as finding wheels up at Pick a Part ($28 for 2 with good tyres). Mud guards are on and all welds finished on the top, coupling attached.
Unfortunately my real job will get in the way until next weekend cry
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #176108
04/26/09 06:55 AM
04/26/09 06:55 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Oh, forgot to mention, the axles are 3300 back from the hitch, or 1700 from the back which is 50mm behind the rear beam - I hope eek
Trevor
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #176175
04/26/09 06:16 PM
04/26/09 06:16 PM
Brian P Offline
Brian P  Offline
no worries trev, it must be the aspect of the photo not doing it justice, second pic looks good, mudguards are flash!
gary, i agree, too much weight on hitch is a pain in the freckle, however i was concerned about the distance from the hitch to the axle. the balance of the boat weight over the axle is different to the distance from hitch to axle. that is the concern to stop the trailer "fishtailing" down the road at higher speed
cheers guys
Brian Partridge
Re: Mossie Trailer [Re: Brian P] #176848
05/03/09 06:13 AM
05/03/09 06:13 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Next Update:
Trailer is on its wheels, and painted underneath. Wiring is in and the boat support frames are on. I am going with a beam support at the front and hull cups at the back with a post keeping the whole thing on. This will allow me to use a single tie down for the whole thing... At least that is the plan!.
eek
Trailer 31.jpg (574 downloads)
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #176906
05/03/09 08:22 PM
05/03/09 08:22 PM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Keep those photos coming!
Do you have a running list of the costs of the various bit so far. It would be interesting.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Mossie Trailer [Re: Tim_Mozzie] #177399
05/07/09 07:31 AM
05/07/09 07:31 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
Another small update - The work has been going slowly due to mid week 'other' work happening...
I have made redone the front supports as they looked a bit frail in the 30mm square. I had enough 50 x 50 5mm from the axle so I used that. I dont think it will ever break grin
Mast support and beam brackets are on. rear supports are made and ready to bolt on.
Costs so far:
Axles $40
Wheels and Tyres $28
Hub Assemblies $84
Coupling $25
Steel $260
Lights, Cables, bolts, paint, bits, etc $150
Springs $44
U Bolts, Shackles, plates, reflectors etc $42
So all up about $700, plus $100 or so for a marine ply coffin big enough for a spinnaker pole and camping gear
Also, things like grinder discs, welding rods, cut off discs, surprisingly add up - Who would have thought confused
Trevor
trailer 4.jpg (541 downloads)
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #177904
05/12/09 06:31 AM
05/12/09 06:31 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
It Works grin
Picked up the boat on the trailer Sunday night (Thanks Peter!).
Only needed to make a small adjustment on the rear cups. They are made from 240mm downpipe and needed some warming and bending over the BBQ to fit the hulls. Excellent idea, but if you use 300mm downpipe it has the same shape as the rear of the hull - just cut and use cool
There is so far only 1.5 coats of paint on it so it needs more, and the box and spare needs to go on. Then we are pretty much done for the moment.
I have already thought of a couple of refinements but they may have to wait for a bit. I am itching to play with the boat part of it all laugh
I will post some pics of the boat sitting on it next weekend, and if anyone wants measurements I will do a drawing at some stage.
Trevor
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #177998
05/12/09 07:07 PM
05/12/09 07:07 PM
Brian P Offline
Brian P  Offline
peter, are you using pvc tube, you are saying downpipe? surely 240mm downpipe is only available in ingham in qld! lol. is it sewer or stormwater? different wall thickness.
Brian Partridge
Re: Mossie Trailer [Re: Brian P] #180343
05/31/09 07:42 AM
05/31/09 07:42 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hey all,
It is stormwater, I think, 7mm wall thickness.
The whole thing is together now box on etc, about 12 - 15 Kgs on the ball.
I guess most of you will see it on the weekend, but I will get a photo up shortly.
Cheers All
Trevor
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #180442
06/01/09 06:10 AM
06/01/09 06:10 AM
G
Got Wood Offline
Got Wood  Offline
G
Hi Guys
The PVC covers Telstra use now, instead of the concrete looking covers are the go. If you know someone who works for Telstra, of course. About 5 mins in the oven, on a very low setting does the trick.
Farmer
Taipan AUS329 'Got Wood'
Mosquito 752 'Sticky Finger'
HARDWOOD RACING TEAM
Re: Mossie Trailer [Re: Trevor] #189044
08/26/09 07:31 AM
08/26/09 07:31 AM
McLaren Vale, SA
Rebel without a Clew Offline
McLaren Vale, SA
Hi Trevor,
I am building a new trailer similar to yours as the old one has metal fatigued itself past it's use-by date [approx 20years old]. I am using 75 x 50 as 75 x 38 is not a stock size in SA, have you set yours up with double decking in mind?
Cheers,
Roy,
1770 Aquarius
Re: Mossie Trailer [Re: Rebel without a Clew] #189155
08/27/09 04:42 AM
08/27/09 04:42 AM
Matt_Stone Offline
Matt_Stone  Offline
hey,
im also building a trailer different than whats on here, and its going to be a double decker, ill post photos soon
matt
Re: Mossie Trailer [Re: Matt_Stone] #189165
08/27/09 06:22 AM
08/27/09 06:22 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi Roy,
While I didnt set out to double up, I didnt like the forward supports when I made them so I redid them using 50 x 50 x 5 mm and added aft bracing.
They are capped with expanding foam so easily able to make some forward beam supports slip them in and go. (Laziness has stopped me making a drop 'gate' rear support that can double!) grin
Have fun with it - It took me 3 times longer than I originally thought to complete down to the coffin. cry
Trevor
Mozzie 1828
Melbourne
Re: Mossie Trailer [Re: Trevor] #189173
08/27/09 07:27 AM
08/27/09 07:27 AM
McLaren Vale, SA
McLaren Vale, SA
Hi Trevor,
Unfortunately, I have given myself a deadline, SA Mossie Assn have a boat measuring day at Adelaide Sailing Club September 5th and I can't use the old trailer having cannabalised it for the springs,wheels.axle etc so the whip is out for the new one! I haven't quite worked out how to put images up yet, how is it done? It does take longer to build than initially thought, recycling parts off the existing trailer saves coins but adds to the time factor.
Life too dull?.......drop an axle on your foot!
Cheers,
Roy.
0 registered members (), 2,638 guests, and 277 spiders.
