Repairing hull 'flex' #176085
04/25/09 10:19 PM
04/25/09 10:19 PM
M
Matthew Dawson Offline OP
M
Hi Guys,
I hope you don't me mind asking a question about my Cobra ...
I have an old plywood boat and the hulls 'flex' a bit when you push them with your hand. They do this on the inside walls of the hulls, near the centreboard - about where you would stand on them if you were righting the boat after capsising.
I am assuming that they should not flex like this ... any suggestions on how I can fix them?
Thanks
Matthew
Currently between boats
Previously …
Cobra 570
Cobra 581
Mosquito 126
Arafura Cadet 738
Re: Repairing hull 'flex' [Re: Matthew Dawson] #176091
04/26/09 01:44 AM
04/26/09 01:44 AM
greymatter Offline
greymatter  Offline
dont know much about cobras, but on a mossie we try to right them from the main beam, most timber mossies have a double skin at the main beam or double frames. so dont flex to much.
on my boat i think you would put your foot through the boat if you were to try and right the boat with your feet between the centre board and the deck.
Re: Repairing hull 'flex' [Re: greymatter] #176093
04/26/09 01:59 AM
04/26/09 01:59 AM
M
M
Hi Greymatter
Yes, I right the Cobra from the main beam too. The problem is that it looks like someone may have been putting their weight on the inside wall between the two beams in the past and the hull seems to have a 'weak spot' there.
I have only had the boat for 6 months.
The question is - how do I fix it?
Matthew
Previously …
Cobra 570
Cobra 581
Mosquito 126
Arafura Cadet 738
Re: Repairing hull 'flex' [Re: Matthew Dawson] #176094
04/26/09 02:10 AM
04/26/09 02:10 AM
Peter_Foulsum Offline
Matthew,
As Rob says, right the boat from the main beam which would be in line with your righting rope anyway. grin There should be a frame at the front of the centreboard case. Does it flex at that frame point too ?
And apart from that try to stand as close to the keel line to get the maximum leverage.
Fixing the flex would involve adding more stiffeners and you really don't want to do that (more weight). frown Just try standing on points of maximum strength and avoid obvious weak areas. cool
Peter
Mosquito 1814
Macka Mozzie
Re: Repairing hull 'flex' [Re: Matthew Dawson] #176095
04/26/09 02:39 AM
04/26/09 02:39 AM
Matthew.
The best way would be to take the deck off in that area and fix the stringers which may have broken away (assuming that there are strigers). If you use a router set at the deck ply thickness then that would give you easy access to see how big the problem is and get access for the repairs. Are you able to see through from the inspection hatches or feel if there is any damaged stringers ?
If there are no stringers and too much flex then you may have to add some stringers.
Naturally you will need a new section of ply for the deck after the repairs.
Peter
Mosquito 1814
Macka Mozzie
Re: Repairing hull 'flex' [Re: Peter_Foulsum] #176102
04/26/09 05:13 AM
04/26/09 05:13 AM
M
M
Thnaks for the suggestions Peter - I'll see what I can find.
Matthew
Previously …
Cobra 570
Cobra 581
Mosquito 126
Arafura Cadet 738
Re: Repairing hull 'flex' [Re: Matthew Dawson] #176103
04/26/09 05:23 AM
04/26/09 05:23 AM
Matthew,
There is some information on this forum for deck removal etc. as the link below shows:
Mossie Repair and Deck Replacement
Hope it helps.
Peter
Mosquito 1814
Macka Mozzie
0 registered members (), 377 guests, and 35 spiders.
