Beaching in a Blow #176625
04/30/09 05:34 PM
04/30/09 05:34 PM
Chicago, Illinois USA
TEH Offline OP
TEH  Offline OP
What is the strategy for coming in to the beach on a run with a pretty good breeze behind you? Especially if its a beach with rocks/sand combo?
Blade F16 USA 725
Re: Beaching in a Blow [Re: TEH] #176626
04/30/09 05:43 PM
04/30/09 05:43 PM
pgp Offline
pgp  Offline
My only suggestion would be to come head to wind well short of the beach, dismount, get control of the bridles and let the boat drift in.
One sailor wrote that he routinely anchors his cat tracks just off the beach and loads/unloads the boat while it is still floating.
How is it going? Sounds like you're having fun! smile
Pete Pollard
Blade 702
Re: Beaching in a Blow [Re: pgp] #176629
04/30/09 05:58 PM
04/30/09 05:58 PM
TEH Offline OP
TEH  Offline OP
Having a great time, but I've come to the realization that I can't do d-day landings on the blade like I do on my hobie.
What happened last weekend is I let the main sheet out and tried to turn up, but the wind was still too much and flipped me right in. I didn't have much room to move as it was a pretty narrow harbor.
I'm thinking I could have centered the main to slow down and hopped in the water at the last minute holding on to boat and turned it head to wind.
Blade F16 USA 725
Re: Beaching in a Blow [Re: TEH] #176631
04/30/09 06:10 PM
04/30/09 06:10 PM
pgp Offline
pgp  Offline
Check your Pms.
Pete Pollard
Blade 702
Re: Beaching in a Blow [Re: pgp] #176664
05/01/09 02:44 AM
05/01/09 02:44 AM
You can't easily turn a boat head to wind with the main let out.
With our prevailing SW I (and others) regularly have to make downwind landings.
If it is less than about force 3, you simply round up just off the beach and drop in backwards.
If it is blowing hard then you round up a good couple of hundred metres or more off the beach and uptide. You have to sail the boat up into the wind and only dump the mainsheet when fully head to wind. Now you need to QUICKLY get the main down. I found that I needed to slightly alter my halyard hook so that it worked every time and changed the outhaul and downhaul so that they could quick release. I then usually drop the main until the top two battens are still in the mast track and with my now heavily reefed sail, simply sail in as normal and round up just off the beach.
It just needs a bit of thinking through and planning smile
Re: Beaching in a Blow [Re: Jalani] #176667
05/01/09 04:08 AM
05/01/09 04:08 AM
Tornado_ALIVE Offline
Re: Beaching in a Blow [Re: Tornado_ALIVE] #176668
05/01/09 04:16 AM
05/01/09 04:16 AM
Just take your main down, pop the kite and snuff it just before you hit the beach...... (I am joking)
Jalani has it
Re: Beaching in a Blow [Re: Tornado_ALIVE] #176669
05/01/09 04:33 AM
05/01/09 04:33 AM
Downwind landing on a concrete ramp with the Tornado, between two 100meter long piers filled with yachts and scant room to turn taught me the following technique. Go downwind with just one rudder in the water, sit ready to pop it. No other foils. When you get to the place you want to stop, pop the rudder and center the main/sheet it in. Boat will weathervane in a very limited radius and behave itself since it have very little "grip" in the water. Please try it out and see if it works for you before you head for "Omaha Beach". smile
Re: Beaching in a Blow [Re: Rolf_Nilsen] #176675
05/01/09 06:22 AM
05/01/09 06:22 AM
France
pepin Offline
pepin  Offline
France
Turn upwind 50m or so from the beach, remove the daggerboards and raise the rudders. Uncleat all the sheets, release the downhaul. Then go stand at the extreme bow of one hull. If you have a crew get him/her on the other bow. With the transoms out of the water, the bows way down and nothing to trip the boat over you're going to glide down straight backward onto the beach.
This method will work with any cat, in any condition as long as you can get the transoms out of the water. I've used it in Santa Cruz to get back to the beach in a swell with a hobie 16, surfing backward, I used it in Bandol where the harbour is narrow, long and right in the Mistral axis with a Hobie 14 and 18, and I used it two days ago to get back ashore with my Stealth at Datchet.
Make sure you are really upwind of the place you want to go to, because with this method you don't control where you are going, the wind is... Also, if you are alone, you need to figure a way to make your wheels accessible in the front of the boat. A Datchet I leave them on the pontoon, but you can also leave them anchored for easy access.
Re: Beaching in a Blow [Re: pepin] #176676
05/01/09 06:30 AM
05/01/09 06:30 AM
pgp Offline
pgp  Offline
Damn! I forgot all about that. blush
That technique is very handy. I once lost my mast just outside the surfline at Daytona. Daytona is notorious for breaking up cats! At any rate, the crash boat came over and helped me get the mess lashed down. Then several of the guys jumped in, hung onto the bows, and the waves took us back into the surf line. With the bows down and the rudders up, it was as soft a landing as you could imagine. No drama, nor further damage. Thanks again to Louie Adiano and the rest of his crew!
Pete Pollard
Blade 702
Re: Beaching in a Blow [Re: pepin] #176678
05/01/09 06:33 AM
05/01/09 06:33 AM
TEH Offline OP
TEH  Offline OP
Thanks. Great suggestions for a variety of situations I will no doubt face.
Given the limited area I had to turn, what Rolf suggests makes the most sense for what I encountered last weekend.
Blade F16 USA 725
Re: Beaching in a Blow [Re: pgp] #176679
05/01/09 06:37 AM
05/01/09 06:37 AM
TEH Offline OP
TEH  Offline OP
BTW, what Tornado_Alive jokingly suggests is closer to what I actually did. I didn't pop the kite, but I did go over. Very entertaining for those on shore.
Blade F16 USA 725
Re: Beaching in a Blow [Re: TEH] #176697
05/01/09 08:28 AM
05/01/09 08:28 AM
pgp Offline
pgp  Offline
http://www.juanaspagodas.com/RegattaNews.htm
This is a lot of fun if you can make it. Nice spot, very laid back. See you there maybe?
Pete Pollard
Blade 702
Re: Beaching in a Blow [Re: pgp] #176706
05/01/09 09:09 AM
05/01/09 09:09 AM
TEH Offline OP
TEH  Offline OP
I have heard its a great time, but I am saving my days for GC.
Blade F16 USA 725
Re: Beaching in a Blow [Re: pepin] #176711
05/01/09 10:23 AM
05/01/09 10:23 AM
I use this all the time and you can steer a BIT.....
When forward, crouch down and drag a foot in the water, this slows down the hull you are standing on and the boat will trun a LITTLE around it. Boats with deep V hulls or little volume up front can be saild at around 155 to true wind angle in lighter winds and a "few" degrees of DDW in big stuff. THe stealth that is alwost flat all the way along the underside of the bow cannot be steered much as there is little grip up front as I cannot sink the hull much!
It is enough to get around mooring bouys and not much more; I would NOT try it in surf as you want to stay Bows on to it.
It is critical to get all foils out and the downhaul off so the mainsail does not create too much power.
If you have a jib, you can take the jib sheets with you and hard back the Jib if strong enough - I've done 10kts backwards on a Hurricane 5.9 with this method.
Re: Beaching in a Blow [Re: Tornado_ALIVE] #176713
05/01/09 11:12 AM
05/01/09 11:12 AM
France
pepin Offline
pepin  Offline
France
All jokes aside (nice pic BTW!) never ever use the spin without a main or with a reefed main. The main is what supports the top of your mast. Without it the mast will invert under the spi pressure and you risk breaking it. So keep the mainsheet tight and keep you main up when using your spinnaker.
Re: Beaching in a Blow [Re: TEH] #176760
05/01/09 06:31 PM
05/01/09 06:31 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
If your singlehanded you are going to need some sand to land the boat on while you get the rollers.
I wait until a big set of waves have gone through, disconnect the tiller extension from the crossbar, fold the leeward rudder up until vertical then sail quickly towards the beach. When the water is waist deep I bring my windward rudder up to horizontal and when the water is 1 foot deep I grab the sidestay, jump off the boat and it rounds up. Float the boat onto some sand and drop the mainsail taking advantage of the larger waves that come through to float my boat up the beach, never dragging on the sand. In the time it takes to drop the main another set has usually come through and I am at the highest water mark, its now safe to get the rollers without the boat getting sucked back into the ocean by the waves.
I have done it this way for the last 10 years with minimal damage to my boat.
Darryn
Mosquito
1782
0 registered members (), 184 guests, and 47 spiders.
