Two Up on Trapeze #176747
05/01/09 04:15 PM
05/01/09 04:15 PM
zandercage Offline OP
I'm curious to know if anyone has ever gone two up? If so is there anything i need to look out for?
Re: Two Up on Trapeze [Re: zandercage] #176752
05/01/09 05:20 PM
05/01/09 05:20 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
I have a couple of times. Slows the boat a great deal. It went well in high winds. 15-20, but I only did it to give a couple of people interested in A-cats a ride so that they could see what they were about. I would worry about too much weight, placement on the platform and that is about it.
Tom Siders
A-Cat USA-79
Tornado US775
Re: Two Up on Trapeze [Re: zandercage] #176798
05/02/09 12:25 PM
05/02/09 12:25 PM
Lake Murray, SC,USA
Cary Palmer Offline
Cary Palmer  Offline
Lake Murray, SC,USA
ACAT has only one trapeze wire, you're gonna be mighty intimate hanging from the trapeze with someone sitting on top of you.
Can you say LAP DANCE??? We may need a new thread for this one . . ., it's bound to get out of control.
CARY
SEACATS
BOYER MARK IV in the front yard.
CARY
ACAT XJ Special
C&C 24
Re: Two Up on Trapeze [Re: Cary Palmer] #176837
05/02/09 09:43 PM
05/02/09 09:43 PM
Tornado_ALIVE Offline
My first cat was a Dolphin. One man, 16 foot, cat rigged Cunningham design which was the predecessor of the Quickcat and considered a training boat for the A Cats.
I took it out in a bit of breeze 2 up on trap and ended up tearing out the rear beam. One up boats are not designed for the sort of loads associated with 2 up trapeze sailing
and would recomend not pushing it to these limits.
Re: Two Up on Trapeze [Re: zandercage] #177015
05/04/09 02:35 PM
05/04/09 02:35 PM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline
I've tried double trapezing on my Marstrom A-class. The boat handled it nicely but the mast was too soft at the top so the sail went flat before we where powered up properly. We could fly a hull but not as early as we would with a better mast. We where around 130 kg together, I wouldn't do this with a heavier crew. Some A-class boats can handle this load but some will probably break.
They converted an Marstrom A-class (actually an M18 but that boat is identical to the A-class except for an increased beam) to an F18ht by adding 40 kg of lead to the mainbeam, switching to a higher mast, changing to M20 centerboards and adding double trapeze. The boat performed quite well but was a bit low on the water.
/hakan
Re: Two Up on Trapeze [Re: Hakan Frojdh] #177335
05/06/09 01:48 PM
05/06/09 01:48 PM
I guess my friends will just have to experience the thrill from the trampoline. This should be ok right?
Re: Two Up on Trapeze [Re: zandercage] #177433
05/07/09 12:04 PM
05/07/09 12:04 PM
LA
Acat230 Offline
Acat230  Offline
LA
I limit passengers on my A3 to 120 lbs and under and most of the boats should not be sailed with more than about 275 lbs total crew weight. The issue is not really the platform but the mast and standing rigging if you load the boat up. Girlfriends, wives, and kids are great fun to sail with.
0 registered members (), 407 guests, and 47 spiders.
