On plywood and glass #179912
05/27/09 02:23 PM
05/27/09 02:23 PM
Rolf_Nilsen Offline OP
Mixing ply and uni glass is not efficient. Ply has a stretch to failure of less than 1%. The uni is about 6%. So the ply has to fail completely before the glass is helping but about 17%. Better to use carbon with plywood in that case. Similar stretch to failure.
Something I had not thought about, but which explains my failed ply and glass foils smile
Re: On plywood and glass [Re: Rolf_Nilsen] #179916
05/27/09 02:34 PM
05/27/09 02:34 PM
pgp Offline
pgp  Offline
I was thinking about foils for my Blade. Could you just make a "boot"? Slip on slip off?
Pete Pollard
Blade 702
Re: On plywood and glass [Re: pgp] #179932
05/27/09 04:27 PM
05/27/09 04:27 PM
I did not quite understand the question. You consider new foils for your Blade, that I got. But where are the "boots" to go? Outside the current foils?
Re: On plywood and glass [Re: Rolf_Nilsen] #179946
05/27/09 04:53 PM
05/27/09 04:53 PM
pgp Offline
pgp  Offline
Attached to the rudders, anti-pitch device.
Pete Pollard
Blade 702
Re: On plywood and glass [Re: pgp] #180002
05/28/09 01:39 AM
05/28/09 01:39 AM
You could do it, but I think that would be more work than doing a custom set of rudders with the T foils.
Re: On plywood and glass [Re: Rolf_Nilsen] #180093
05/28/09 05:16 PM
05/28/09 05:16 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
So, what about the design of these T-Foils?
1. Symetrical, can they be fairly flat?
2. Near the bottom of the rudder.
3. How much surface area?
4. Triangle shaped? Rectangular? High Aspect?
5. Zero angle of attack with boat level. When is the boat level? Or zero when the transom is just clear of the water?
0 registered members (), 528 guests, and 47 spiders.
