Re: Seeking Opinions on Gary's Solo Right [Re: DHO] #18095
04/04/03 01:05 AM
04/04/03 01:05 AM
jcasto1 Offline
jcasto1  Offline
There was a thread last summer called "Power righting pole on NA 6.0" that went into some detail. One reply (#9837) had a close up of the attachment point.
Gary & Rick have done a lot of work to make their systems really function well. If you haven't seen or used a righting pole, your first homemade attempt will likely be ineffective, defective, or both. My first attempt was actually laughable, and I'm lucky I didn't get hurt. Even if you copy one you've seen or used, in my experience, you need to take the time to try it out on dry land, then on the water with assistance. Or, just save yourself the time, and go buy their designs.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Seeking Opinions on Gary's Solo Right [Re: jcasto1] #18096
04/04/03 10:39 AM
04/04/03 10:39 AM
H
hobie1knobi Offline
hobie1knobi  Offline
H
I have tried both the power righting system by Rick White and the Gary's solo-right system and for my boat the Solo-right worked better. I also did not have to drill holes in my boat to attach it like Rick's system. Rick's system also stuck out a little behind the rear cross beam, which I did not like. I know you can cut the excess off but I needed the full length to make it work. Interesting that Gary's pole is shorter and seems to work better. I also like the fact that I can use the pole as a paddle. I was a bit skeptical before purchasing Gary's system that it would actually work but once I tried it I was sold, as it worked absolutely perfect. I do think Rick's system is great but it just turns out for me that Gary's system worked better for me.
Re: Seeking Opinions on Gary's Solo Right [Re: jcasto1] #18097
06/27/03 06:29 AM
06/27/03 06:29 AM
Cadiz, Spain
nearher Offline
nearher  Offline
Cadiz, Spain
I HAVE A NACRA 5.0. Will Gary's solo right fit my boat?
Thanks
Re: Seeking Opinions on Gary's Solo Right [Re: PRagen] #18098
06/27/03 08:56 AM
06/27/03 08:56 AM
St. Louis, MO
nova Offline
nova  Offline
St. Louis, MO
I have not seen either Gary's soloright or Rick's Power Pole used. However looking at the pictures, it seens that by being out so far, that upper hull is going to come down right on top of you. Apparently it doesn't, so how come?
Re: Seeking Opinions on Gary's Solo Right [Re: nova] #18099
06/27/03 09:39 AM
06/27/03 09:39 AM
Good question. I've never seen either one in use on the water, and I had never really thought about that before.
Re: Seeking Opinions on Gary's Solo Right [Re: Mary] #18100
06/27/03 09:57 AM
06/27/03 09:57 AM
Look in this picture and you can see that their feet are still on the lower hull. They are able to get their upper body weight out much further with the pole.
Re: Seeking Opinions on Gary's Solo Right [Re: nearher] #18101
06/27/03 10:52 AM
06/27/03 10:52 AM
Clearwater, FL
Jeffwsc17 Offline
Jeffwsc17  Offline
Clearwater, FL
nearher
I just got a soloright for my SC17. Like your 5.0, it is boardless and lipless. Gary swears it will work, but I haven't been able to try it yet....I have a distance race this weekend, hopefully I will have some time before hand to practice and set it up just right....I'll post the results here as soon as I get it setup and try it...
Re: Seeking Opinions on Gary's Solo Right [Re: PRagen] #18102
06/27/03 12:25 PM
06/27/03 12:25 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Here's a post by someone on the Yahoo Beachcats group site. He sails a Hobie 16 solo.
"I recently bought a solo-right from Gary and was able to try it out last week at the local lake. Thanks Gary, it works great. Could not right the boat without it the first time I tried it, just not enough weight (140lbs). Once I rigged the solo-right, I stood there for a moment and up she came!"
Jack Hoying
Fort Loramie, Ohio
Prindle 18
1990 H16 (for sale)
Re: Seeking Opinions on Gary's Solo Right [Re: Jake] #18103
06/27/03 01:56 PM
06/27/03 01:56 PM
Edmonton, Alberta, Canada
Al Schuster Offline
Al Schuster  Offline
Out of curiosity, any chance of either of these systems providing enough assistance for a 175lb person to right a tornado solo? (crew can't make it this weekend)
As far as the solo-right goes, will it work on the Tornado?
Al
Re: Seeking Opinions on Gary's Solo Right [Re: Al Schuster] #18104
06/27/03 05:14 PM
06/27/03 05:14 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Tordado testing has been repeatedly postponed. I expect to do it this summer. I expect positive results and would bet my life on being able to do it with two men and one SoloRight.
Details will be made public as soon as the trial occurs.
GARY
Santa Monica Bay
Re: Seeking Opinions on Gary's Solo Right [Re: Jeffwsc17] #18105
06/27/03 05:17 PM
06/27/03 05:17 PM
hobiegary Offline
hobiegary  Offline
Jeff,
As I remember it:
Jeff continually encouraged me to develop a model for his application. Once he offered to be a guinea pig (tester) for a new design, I sent him a SoloRight that might work on boardless, lipless hulls.
I await Jeff's news of his test results, along with a few other SC17 and N5.0 sailors.
GARY
Santa Monica Bay
Re: Seeking Opinions on Gary's Solo Right [Re: hobiegary] #18106
06/27/03 05:23 PM
06/27/03 05:23 PM
Al Schuster Offline
Al Schuster  Offline
I look forward to the results. So far, in real life testing, the two of us weren't quite able to right the boat when we needed to. If we hadn't been freezing to death at the time, we might have had more success (a friendly motor boat assisted us on that occassion).
0 registered members (), 21,948 guests, and 1,940 spiders.
Most Online23,915
6 seconds ago
