Rating: 3
Re: spin pole construction specs? [Re: Todd_Sails] #18185
04/03/03 09:22 AM
04/03/03 09:22 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Thanks! Yes, it is a particulary nice sail! I may have to shop around for another one, though. As you found, I think it may be a bit small for the 20... Anybody got a used I-20 or Tiger spin they're looking to unload for cheap?
Another test-fit day pic attached...
Re: spin pole construction specs? [Re: Keith] #18186
04/03/03 10:03 AM
04/03/03 10:03 AM
http://www.geocities.com/f16hpclass/Tech_weight_and_cost_spi_setup.html
a alu pole will weight 1,6 kg's (=3,5 lbs) and a carbon pole of the same dimensions will weight 1 kg (= 2.1 lbs)
How much do you think 600 gram = 1,3 lbs is worth ?
The glass surfmasts I have are heavier than the aluminium pole. I bought the pole for the equivalent of 20 US$.
Re: spin pole construction specs? [Re: catman] #18187
04/03/03 08:01 PM
04/03/03 08:01 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
No can do fer Key Largo....I just ordered the Spin from Hank at Nauty Ventures, I don't think it will be here in time to rig and practice, so no real hurry. Butt, I have a new main that will arrive same time that I will use for Key Largo. "Watch out for the H-20 with dark teal hulls, new white sail #584......grrrrr
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spin pole construction specs? [Re: Todd_Sails] #18188
04/03/03 08:04 PM
04/03/03 08:04 PM
arbo06 Offline OP
arbo06  Offline OP
Beautiful!!!!
Thanx, don't ever change!
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spin pole construction specs? [Re: Keith] #18189
04/03/03 08:05 PM
04/03/03 08:05 PM
arbo06 Offline OP
arbo06  Offline OP
Those shots are perfect! Thank you very much, this really helps alot
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spin pole construction specs? [Re: arbo06] #18190
04/04/03 02:44 PM
04/04/03 02:44 PM
Austin, TX
spinakerjohn Offline
Austin, TX
Take a look at Wouter's link and the the spin hound link. Method 1 sure looks like the ticket. Very adjustable for different sails. Think I'll take my Nacra hound back. It requires 12 holes and 12 rivets and 12 leaks....
spinakerjohn
Re: spin pole construction specs? [Re: spinakerjohn] #18191
04/05/03 10:57 AM
04/05/03 10:57 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
This is the method I used. I was all jazzed about the purported ease of mast rotation, and it does work pretty good - but the reality is that because the spin halyard comes up through and around the hounds/stays/shrouds/etc. there is still some resistance to free movement. Still, a great method, seems robust from expereince, and no holes in the sealed section of the mast, and not rivets to start corrosion.
0 registered members (), 18,777 guests, and 920 spiders.
Most Online22,490
12 hours ago
