| Re: Prindle owners - has anyone tried this
[Re: Ventucky Red]
#182275 06/17/09 03:30 PM 06/17/09 03:30 PM |
Posts: 284 Norfolk, VA | I have tried it on my old 18-2 and I thought it was better--especially downwind when you have all your weight forward and your rudders are barely in the water. It adds drag, but it works. If you have a lot of helm, I would check out the rake of the rudders, first.
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: Ventucky Red]
#182283 06/17/09 05:19 PM 06/17/09 05:19 PM |
Posts: 851 US Western Continental Shelf | I replaced the stock rudder set up on my Mystere 6.0 with that of a Prindle 16/18. They worked better than the stock rudders.....until one snapped sideways (rudder and casting both) when a swell passed under me at sea. I'd recommend giving it a try. After all, it is a simple un-bolt, re-bolt blades only, swap-over isn't it?
By the way I have never regretted the breakage because it was the heart of a fantastic adventure/story.
I'll bet your trouble with heavy helm can be solved with tuning.
Gary
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Prindle owners - has anyone tried this
[Re: Ventucky Red]
#182286 06/17/09 05:40 PM 06/17/09 05:40 PM |
Posts: 1,203 uk | C'mon fess up......... have you been mucking about with the sails????
[Re: TEAMVMG]
#182292 06/17/09 06:34 PM 06/17/09 06:34 PM |
Posts: 1,403 | I'll bet your trouble with heavy helm can be solved with tuning. Have done all the mast rake and rudder rake configurations possible, still have a heavy helm. Problem on this boat is you don't want to neutralize the helm with raking the rudders under; which I have done and doesn't solve the problem. Wanna tell us how you broke that rudder and casting? Those things are almost bullet proof C'mon fess up......... have you been mucking about with the sails???? I know we both speak the queen's English, and I fess up to just about anything if I knew what you were talking about  | | | Re: Prindle owners - has anyone tried this
[Re: Will_R]
#182301 06/17/09 09:01 PM 06/17/09 09:01 PM |
Posts: 1,403 | This is my second Prindle 18-2, and I didn't have the issue either; however, that had the stock Dacron sail. this one has an upgrades sail.
But I am thinking that maybe my upper forestry may be from a P19 therefor not allowing me to fully pull the mast forward to alleviate the heavy helm
Your new day of hope, any idea's?
[Re: Ventucky Red]
#182303 06/17/09 09:57 PM 06/17/09 09:57 PM |
Joined: Nov 2006 Posts: 30 Lake Norman, NC Doug_P182_LKN
Posts: 30 Lake Norman, NC | I sail an 18-2. You shouldn't have hard helm if the rudder rake is set properly. When set right, mine is two-fingers-on-the-tiller smooth. The P-19 has 18 inches more of mast and I believe a different forestay. An easy way to check is to see how many holes down on the stock shroud adjusters you go to get a tight rig. If you have an 18-2 forestay, 6 holes down should be tight but allow mast rotation. 7 is way tight and anything more than should be near impossible. If you can get your shrouds pinned near the bottom holes, your mast is raked way too far aft which means your forestay is too long. The pic below is almost square on and you can see the degree of mast rake on the rig with unloaded downhaul and mainsheet. I would check to make sure that you don't over-tighten your gudgeon to tiller crossbar bolts too much. Have you bought the extensioner kit with springs? If not, you should along with the plastic shims to take out the slop. Cheap and easy. Should be tight, but easy enough to move the rudders with one finger. Also, make sure you're not accidentally running your mainsheet from the traveler car over the tiller crossbar down to the tie-off. That'll add tighten it up a bit. Really hard helm or nasty lee helm usually means the rudders are raked too far aft. Turn the lockdown bolt so that when down, they're about 2 inches forward of the transom line. Use a yardstick against the stern of the transom. Bottom fore tip of the rudder should be about 2 inches forward of this line. Hope this helps. Doug
Doug Bernstein Prindle 18.2 'Special Treat' #590 Lake Norman, NC
[Re: Ventucky Red]
#182305 06/17/09 11:04 PM 06/17/09 11:04 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | My 18-2 had a dacron jib and mylar main with the old "square" rudders.
Not to ask a dumb question, but you are getting them locked all the way down right?
2012? Yeah, anybody other than what we have now or what we had before.
[Re: Ventucky Red]
#182317 06/18/09 02:51 AM 06/18/09 02:51 AM |
Posts: 1,203 uk | Sorry about that old chap, i will re-phrase.
have you changed the mainsail from stock - maybe to something with a bigger roach?
[Re: TEAMVMG]
#182341 06/18/09 08:51 AM 06/18/09 08:51 AM | andrewscott
| andrewscott
Unregistered | probably obvious but on my cat, .01mm off and i have wicked helm... now that i have them set perfectly i have almost no helm .
I have used a sharpie to mark the exact spot they work best (as they seem to slip around a little with use) | | | Re: Prindle owners - has anyone tried this
[Re: Ventucky Red]
#182385 06/18/09 03:03 PM 06/18/09 03:03 PM |
Posts: 30 Lake Norman, NC | Doug:
Can you measure your upper forestry and let me know what that length is? And, I am it six holes down, how far out is your forestay turnbuckle; are you butt to butt or is there some thread showing?
I'm getting some nasty weather helm that is you let go and the boat turns right up to the wind
Ok so here is where I am at now, forestay is adjusted all the way in (I'll have the rake measurement shortly). I have about an inch of forward rudder rake and can't get any more than that.
The sails are Danger, and I have spoken to Jay Glaser who had sent me the Prindle 18-2 tuning guide (which I will send to you BTW) which give a great point of reference to start.
I'll measure all elements of my forestay this weekend and let you know. I'll take pictures of my rudder settings as well. Ideally, the boat should have neutral helm and fairly light helm at that. The stock rig when tuned should give you this. Something's wrong if you have severe weather helm. Are you using the stock downhaul or an after-market? That was one of the first things I replaced on my boat. Sounds like we have the same mylar main/dacron jib Danger sails. And thanks, but I already have that Prindle 18-2 tuning guide.
[Re: HMurphey]
#182397 06/18/09 03:43 PM 06/18/09 03:43 PM |
Posts: 1,200 Vancouver, BC | Not sure how exactly mast rake is measured on the prindle using the main halyard.
On the T we take a trapeze forward, tie a bit of extenston line to the trap handle and with the mast straight front-to-back, we pull the extension line & trap taught at the inner gunwale bridle tang. We mark/grip the line at the intersection point with the tang at gunwale (forward edge)...then walk back to the transom keeping the trap taught to check where the mark intersects the outside gunwale. Pre-spinnaker days (classic rig very similar to Prindle 18-2 & 19) the recommended location was 10 cm behind the rear beam. With spinny, we now run it typically right at the top/outer corner of the transom for most conditions...sometimes 2-10 cm down the transom below deck line.
[Re: HMurphey]
#182464 06/19/09 12:57 PM 06/19/09 12:57 PM |
Posts: 1,403 | OK gents, here is what we have:
Rudder Rake = 1" forward using the straight edge transom method as outline in the Prindle owners manual and Jay Glaser's 18-2 Turning Tips worksheet. To note, there is no room left on the adjuster bolt to get any more forward rake. Mast Rake (used two methods)
A.) Trap Line - ran rope to the bridal tang that move after to where the mark intersected the the sheer edge of the boat. This was 5" aft the rear cross beam. This is suppose to fall about half way between the shroud plate and the rear beam
B.) Did the tape rule/main halyard method as outlined in Jay Glaser's Prindle 18-2 Tuning tips and this was 28' 6" the minimum for this is 28' 9.5" and the maximum is 28' 11" which would be too little rake.
Both of these are telling me I have too much mast rake, which explain the heavy weather helm and why the boat wants to turn right up the minute I let off of the helm. And here is the problem; my forstay adjuster is already adjusted all the way in with no further adjustment left to move the mast forward.
So the only other conclusion I have is that my upper forestaty or something else on my rigging is not right, or it is and I need to shorten something to get the rigging to where I can get into the ball park for adjusting.
Any other ideas?
Thanks for you help gents, appreciated
2,362
guests, and 286
