| F18 Spinnaker luff length? #182331 06/18/09 07:47 AM 06/18/09 07:47 AM |
Joined: Oct 2007 Posts: 87 Charleston, SC, USA krona OP
Posts: 87 Charleston, SC, USA | Does anyone know the luff length of a typical F18 Spinnaker?
NACRA 570 #90308 Hobie 16 #68973
| | | Re: F18 Spinnaker luff length?
[Re: krona]
#182332 06/18/09 08:11 AM 06/18/09 08:11 AM |
Posts: 3,906 Clermont, FL, USA |
[Re: Tony_F18]
#182344 06/18/09 09:17 AM 06/18/09 09:17 AM |
Posts: 87 Charleston, SC, USA | I'm asking because I'm trying to figure out what Spinnaker I have on my N570. I suspect it's an F18 but I need to verify, I'm hoping my current spin is slightly larger than a typical F18 spin, blown out perhaps. I'm having problems getting my current spin setup with the right luff tension. So by getting an F18 spin I would solve my problem.
If an F18 is larger than my current spin I guess I need to look at an F17...
Does anyone know the luff length of an F17 spin?
[Re: krona]
#182350 06/18/09 09:33 AM 06/18/09 09:33 AM | andrewscott
| andrewscott
Unregistered | perhaps you can take your boat to a sail maker and rig it. this way you can find out what is the right measurement for your setup and perhaps order a custom spin.
I know several people who did this with great results.
you should have a bit of flexibility (on the luff size) with the possition of your pole and amount of prebend in it. When i used a f18 spin (on my 30' mast) my pole was Very high. Now that i have a Tornado spin.. it is pretty low, with minimal prebend.
[Re: krona]
#182351 06/18/09 09:34 AM 06/18/09 09:34 AM |
Posts: 976 France | Don't forget there are two size of rigs for F18 depending on crew weight. The small spi is 19m2 and the large one is 21m2. The aforementioned french F18 measurement certificates are there. | | | Re: F18 Spinnaker luff length?
[Re: pepin]
#182352 06/18/09 09:36 AM 06/18/09 09:36 AM |
Posts: 87 Charleston, SC, USA | Does the two different sizes of F18 spinnakers have different luff length? I thought they had the same length and just smaller size.
[Re: krona]
#182353 06/18/09 09:55 AM 06/18/09 09:55 AM |
Posts: 1,430 california | luff is 8.5 m leach is 7.1 m foot is 3.6 m If you want a nice spin the Jeremy at Surf City Catamarans is heving really nice ones cut. Stiched seams reinforced seams at the luff leach and foot. Really nice corners. On average a lot cheaper than Hobie or Nacra , he can have it cut to any custom dimention 2 or 3 hole ect. I'm verry hapy with my chute for the Tiger he had made.
[Re: F-18 5150]
#182358 06/18/09 10:14 AM 06/18/09 10:14 AM |
Posts: 976 France | luff is 8.5 m leach is 7.1 m foot is 3.6 m
Compared to the measured dimension of a wildcat spi, yours seems small: luff: 8.85 leach: 7.68 foot: 3.78 20.9945m2 source
[Re: pepin]
#182370 06/18/09 12:37 PM 06/18/09 12:37 PM |
Posts: 1,203 uk | Luff lengths are the same for both sizes of F18 spinny
[Re: TEAMVMG]
#182372 06/18/09 12:47 PM 06/18/09 12:47 PM |
Posts: 3,293 Long Beach, California | My Goodall chutes have different luff lengths - the small chute is about 4-inches shorter in the luff than the big one. Same sheeting angles for both, but slightly different hoist heights.
[Re: John Williams]
#182373 06/18/09 01:10 PM 06/18/09 01:10 PM |
Posts: 3,528 Looking for a Job, I got credi... | My Goodall chutes have different luff lengths - the small chute is about 4-inches shorter in the luff than the big one. Same sheeting angles for both, but slightly different hoist heights. John, THat's a bit poor; you are losing even more on the small kite by having a shorter luff!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: F18 Spinnaker luff length?
[Re: scooby_simon]
#182374 06/18/09 01:34 PM 06/18/09 01:34 PM |
Posts: 3,293 Long Beach, California | You have to cough up that sail area somewhere - the small kite is not slow, IMO. I raced for a season-and-a-half at 275 lbs (125 kg) on the small sail plan and found the field to be quite level. I might tend to even give the small sail plan and lighter crews the edge in everything up to about 12 knots of breeze, especially uphill. I miss sailing light (TIIIIIIINAAAAAAAAA!).
[Re: krona]
#182375 06/18/09 01:43 PM 06/18/09 01:43 PM |
Posts: 12,310 South Carolina | Does anyone know the luff length of a typical F18 Spinnaker? Remember too that you have a skeg hull so you're rake SHOULD be back more than a spinnaker boat since the center of side-resistance of your hulls is further back than a daggerboard boat.
Jake Kohl | | | Re: F18 Spinnaker luff length?
[Re: Chris9]
#182418 06/18/09 07:08 PM 06/18/09 07:08 PM |
Posts: 1,430 california | 8.45 luff 7.70 leach 3.77 m 2.89 mid = 76.65 20.63 total for the big one
3,236
guests, and 277
