Page 2 of 3 1 2 3
Re: Battens tapered and CE [Re: Luiz] #183835
07/01/09 11:43 AM
07/01/09 11:43 AM
andrewscott
andrewscott
seems much easier to try to adjust the mast/rudders than to sand battens (you can't unsand)
Re: Battens tapered and CE [Re: Luiz] #183841
07/01/09 12:26 PM
07/01/09 12:26 PM
C
cooper engineer Offline OP
C
Originally Posted by Luiz
Take a look at my last post now that I edited to add pictures and a link.
Thanks Luiz
I have read the link indicated and i have understand that in order tu reduce the wearher helm and tiller tug i must accept that the rudders work with extra drag from turnig, and to achieve a straight course slows the boat.
I have understand that for the hobie the advantages to increase the mast rake are greater of the disadvantages to make to work badly the rudders.
This is not my case .... I want to reduce weather helm in order to make to work the rudders with the smallest drag.
cry
Re: Battens tapered and CE [Re: cooper engineer] #183843
07/01/09 12:51 PM
07/01/09 12:51 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
if you have weather helm and you need to pull the tiller, you create lift - something you need to go upwind. If your boat is neutral, this lift comes from the daggerboards and it will produce drag as well.
Cheers,
Klaus
Re: Battens tapered and CE [Re: Smiths_Cat] #183846
07/01/09 01:20 PM
07/01/09 01:20 PM
It really sounds like the sails dont fit the boat very well. Draft at 40% with a rotating mast dont have to be too bad, depending on the geometry. How full the sail is and what the profile looks like on the other hand makes a world of difference.
These sails that have been adapted to your boat.. Is the mainsail designed for the mast? If not, was the luff of the main re-cut to fit the mast? It just sounds like you have a mainsail that dont fit the rig or boat too well.
Any hope of pictures?
Re: Battens tapered and CE [Re: Rolf_Nilsen] #183848
07/01/09 01:51 PM
07/01/09 01:51 PM
C
C
The sail is designed for the mast .....
Re: Battens tapered and CE [Re: cooper engineer] #183850
07/01/09 01:58 PM
07/01/09 01:58 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Yikes!
Look at those wrinkles!
Any way to add more batten tension?
Re: Battens tapered and CE [Re: ThunderMuffin] #183852
07/01/09 01:59 PM
07/01/09 01:59 PM
Yikes!
X2
Re: Battens tapered and CE [Re: ThunderMuffin] #183854
07/01/09 02:06 PM
07/01/09 02:06 PM
C
C
Yikes!
Yes, wrinkles are monstrous ..... but this is an other problem for an other day ...... blush
Re: Battens tapered and CE [Re: cooper engineer] #183856
07/01/09 02:17 PM
07/01/09 02:17 PM
Do you have another picture where the mast is rotated properly?
The battens are not tied in as tight as they should be. The current setup will not help on your weather helm issue.
What cloth is the sail built from? Some sort of fiber reinforced mylar with taffeta?
How tight is the downhaul on in the picture? The wrinkles between battens should go away when you tighten them, but the large wrinkle from the downhaul and between batten #1 and #2 is a different matter. I just hope it disappears when you rotate the mast.
If you are going to do another pic sometimes, it would be helpful if you could lie down under the boom when shooting.
Re: Battens tapered and CE [Re: cooper engineer] #183857
07/01/09 02:18 PM
07/01/09 02:18 PM
andrewscott
andrewscott
wouldn't tightening the battens create more draft?
Re: Battens tapered and CE [Re: cooper engineer] #183858
07/01/09 02:19 PM
07/01/09 02:19 PM
RickWhite Offline
RickWhite  Offline
Just glancing at the sail, it appears the draft at the top two battens are too far aft, 3 and 4 look pretty good, but should not be moved forward, Then the rest of the bottom of the sail has the draft way too far forward which will cause a backwinding by the jib (overlapped or self-tacking makes no difference -- the jib is still throwing air across the mainsail down there.)
Rick
Rick White
www.onlinemarinestore.com
Re: Battens tapered and CE [Re: RickWhite] #183861
07/01/09 02:41 PM
07/01/09 02:41 PM
C
C
Thanks to all .....
I don't have a pic with mast properly rotated, the sail is in dracon, the battens are soft and if tightening create more draft;
In this pic no downhaul and sheet.
Re: Battens tapered and CE [Re: cooper engineer] #183867
07/01/09 03:30 PM
07/01/09 03:30 PM
that really doesn't look too bad. Iwouldn't try to move the draft any more forward....but even if you did try to fix it with battens, it wouldn't have too much effect. A sail with a bad draft position is just that...the battens won't change it an incredible amount..but again, that doesn't look too bad.
Re: Battens tapered and CE [Re: Jake] #183934
07/02/09 02:02 AM
07/02/09 02:02 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Jake is right IMO. Sail dosent look too bad I'm sure the winkle blow out especialy when you consider that it's Dacron. Battens simply hold the sail in shape it was designed.
Like the other guys said rake your rudders more under the boat. Think about it if you have a problem steering you should probably start with your rudders.
Aido
Viper 288
Re: Battens tapered and CE [Re: Aido] #183938
07/02/09 06:34 AM
07/02/09 06:34 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
"Think about it if you have a problem steering you should probably start with your rudders."
Count me FIRMLY in the sails and mast trim first camp! Whenever I have a problem steering it is always because I have too much tension on the main sheet or too little jib tension, too late.. But I have to admit I'm no expert on cats yet having gained most of my experience on mono's. By all means, check your rudders for normal trim, but I wouldn't be taking a file to them unless it was a last resort. Raking forward does not improve anything IMHO. It just masks a trim problem by adding more force in the opposite direction (AKA drag). Its a bit like "shooting the messenger", if you ask me. Ie: The rudder tells you something is wrong so you take a sharp tool to it and "make him an offer he can't refuse"!
Rick and Marys book has some excellent explanations of the theory behind it all on page 72 and 73.
Dennis
Re: Battens tapered and CE [Re: DennisMe] #183939
07/02/09 07:11 AM
07/02/09 07:11 AM
C
C
Dennis
I agree smile
Re: Battens tapered and CE [Re: cooper engineer] #183941
07/02/09 07:46 AM
07/02/09 07:46 AM
catman Offline
catman  Offline
I would agree with messing with rudders but since you used the word "prototype" I would ask if you have tried to sail the boat upwind without the rudders down? Is the front beam too far back on the hull? Does the main have too much roach? Are the boards in the right place? Good luck with your project!
Re: Battens tapered and CE [Re: catman] #183947
07/02/09 08:33 AM
07/02/09 08:33 AM
C
C
Front beam and boards are in the right place, what do you mean for "too much roach" ?
Re: Battens tapered and CE [Re: cooper engineer] #183953
07/02/09 08:58 AM
07/02/09 08:58 AM
Meaning the center of effort in the sail does not balance with the Center ofd lateral resistance on the boat and so you get weather or lee helm. More roach will give you more weather helm as more sail goes into the top aft portion of the sail. Pin head sails have little roach, the sail you show has a fair amount as it is a fairly "fat head" sail. Fat head sails have a LOT of roach. By adding more roach, you move the COE back.
A boat will exhibit weather / lee helm whet the boat is not balanced with the sails.
As I am sure you are aware this is because the center of effort / blanace of the sails does not balance where the center of lateral resistance of the hull is acting.
This can be for a number of reasons
1, COE of sail in in front or behind CLR of hull or visa versa
How do we fix this?
1.1 Rake the mast fore or aft to move the COE of sail
1.2, Change the shape of the sail by changing the camber position and thus COE. You get this to happen by adding more downhaul, but the sail also flattens. YOu are sailing with enough downhaul to remove most creases in the sail?????
1.3, Changing the shape of the sail by adding or removing cloth to move the COE
1.4, Moving the mast forward or backward on the platform (move beam(s))
1.5, Moving the position of the dagger/centerboards or skegs
1.6, changing the length of the hulls
1.7, Moving the position of the rudders further aft by adding gantrys (it's difficult to move them forward without removing hull!!)
2, Rudders are not correctly trimmed, with the tip in the incorrect fore/aft position
2.1 Adjust them via designed adjustments within the rudder system or get the files / wet and dry out or make the rudders bigger.
I would suggest that if your mast is vertical and you still have issues with weather helm you have the following possible problems
a, Dagger boards are in the wrong place - you state this is not the case
b, Mast (so front beam) is in the wrong place - you state this is not the case
c, Hulls are the wrong length
d, Sail is the wrong shape, too much roach maybe? (as stated above), too full too far back.
e, all of the above!
If you were to sail in "normal trim" and let go of the tiller, how long does it take to go head to in say 10 kts of wind?
Re: Battens tapered and CE [Re: scooby_simon] #183955
07/02/09 09:27 AM
07/02/09 09:27 AM
C
C
I think is the sail with wrong shape; the max draft is at 40% with 10% camber.
you have seen the pic?
you it seems too much roach?
"If you were to sail in normal trim and let go of the tiller, how long does it take to go head to in say 10 kts of wind?" 5/7 seconds.
Page 2 of 3 1 2 3
0 registered members (), 22,018 guests, and 518 spiders.
Yesterday at 04:54 AM
