Outhaul Setup #183998
07/02/09 06:55 PM
07/02/09 06:55 PM
Tasmania
daniel Offline OP
daniel  Offline OP
Tasmania
I Want to know what is a good setup for holding the sail close to the boom at the outhaul. I am currently using a rope loop arround the boom, want to know what others are using what works well. Have found this picture and would like to know what the traveller is. http://s51.photobucket.com/albums/f...=view&current=riggin_2006_0917AX.jpg
From Daniel
Miss Beast 1730
Re: Outhaul Setup [Re: daniel] #184146
07/04/09 05:56 PM
07/04/09 05:56 PM
greymatter Offline
greymatter  Offline
Peter Cobden makes a car that fits into the boom, other people make there own. Usualy running a 3-1 purchase with a cleat at the front of the boom.
http://s51.photobucket.com/albums/f...=view&current=riggin_2006_0917AF.jpg
some people use the same swivel cleat mount for the mast rotation as well.
Re: Outhaul Setup [Re: daniel] #184153
07/05/09 12:32 AM
07/05/09 12:32 AM
Peter_Foulsum Offline
Daniel,
There is a Tee piece Riley fitting RM98 which may do the job. It is a track slide to suit a 16 mm internal track and has a plastic rubbing strip to reduce friction. cool As per the image from the photobucket you would need to cut a slot in the boom section.
Most of the recently built Mozzies use the rope loop. It is simple and effective providing you have positioned the outhaul at the desired position prior to applying too much mainsheet tension. Using the rope loop also gets rid of extra fittings and is possibly less prone to binding than the slider. cool
Peter
Mosquito 1814
Macka Mozzie
0 registered members (), 418 guests, and 42 spiders.
