Re: Gripping Sheets [Re: Rolf_Nilsen] #184760
07/10/09 10:18 AM
07/10/09 10:18 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
First off, I am at work so excuse the fact that I am using a power cord in the pictures.
My non-hand crush technique has the loaded end of the sheet entering the hand from the pinkie side. The hand is then held at 90 degrees to the strain. This would be for the lighter strains.
For heavier loads I pass the line around my thumb and back down through the hand. This places a bight around the thumb and doubles the thickness you are gripping in your hand. If you have to ease sheet, you simply open your hand enough to drop the bight.
I am also using the latex/nitrile coated gardening gloves now. I find that they have excellent grip on the line without having to squeeze the line.
sheet 001.jpg (244 downloads)
sheet 002.jpg (235 downloads)
Re: Gripping Sheets [Re: Mark P] #184935
07/12/09 01:50 PM
07/12/09 01:50 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Originally Posted by Mark P
Hi Gill
Once on the wire, roughly around 10+mph wind speed (approx 13-14kmph) I find that you can't over sheet the main with my 8:1 mainsheet purchase. However, the wind never appears to be that constant hence I don't cleat. This might have something to do with the sail itself as Stealth Mains have a boom/foot which is at least 9" or 225mm longer than a Blades.
Second downside of change to a bigger purchase is that it is more difficult to take the gusts by sheeting because you have to release to much so it is impossible to sheet in again easily afterwards (if you are helming and sheeting).
Concerning the longer foot on the Stealth, shouldn't this make the loads lighter as there is less power in top?
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
0 registered members (), 14,302 guests, and 571 spiders.
Most Online16,046
5 hours ago
