| Re: Hobie 16 Open in Kingston - event has started
[Re: mbounds]
#186104 07/24/09 04:41 PM 07/24/09 04:41 PM |
Posts: 894 Branford, CT | I had dinner with Mike Walker, who is on the jury (but not in this case, since he provided photographic evidence).
The basic scenario was this: Wind about 6 kts, light current running upwind. Tom K. coming into the mark on stbd. Because of the current, it was easy to overstand. Tom was probably cracked off and footing to the mark.
Jason Hess and Bob M. were coming into the mark on port. Jason was to weather of Bob and overlapped from behind.
Jason tacked, and Bob tacked about a second later, well within the zone.
Tom had room to duck beneath them and still make the mark, so 18.3a didn't apply.
The jury found that Jason and Bob broke rule 13 (While Tacking) and tossed them both. This is the jury drawing in the facts found. We are the green, Tom is yellow and Jason is blue. The jury threw Jason and I out on Rule 13. bigger picture here | | | Re: Hobie 16 Open in Kingston - event has started
[Re: brucat]
#186142 07/25/09 11:33 AM 07/25/09 11:33 AM |
Posts: 26 | The word is out that the Hobie class is breaking the 'tacking too close' rules (no kidding). How many times have we either done it or had it done to us at A Mark on the first rounding. Since I was at the windward mark alot, you could see the difference after the results of the protest were posted. Mark roundings were much more 'legal' (he says as a jury member). I also wanted photographic evidence, so I mounted a camera on the mark to take pictures every 5 seconds. http://walker-photo.smugmug.com/gallery/8963691_xAVNu/1/#600665536_J9fHL-A-LB http://walker-photo.smugmug.com/gallery/8963691_xAVNu/1/#601307411_AaLF3-A-LB(did something break in the forum code --- those images used to display on their own -- yes, I was adding an image to a linked picture).
Need a PRO? Will work for food! | | | Re: Hobie 16 Open in Kingston - event has started
[Re: h20racer]
#186170 07/25/09 04:53 PM 07/25/09 04:53 PM |
Posts: 894 Branford, CT | So what’s too close? The way I understand it you need to be on or past a close hauled course before the other boat needs to maneuver. You don’t need the jib filled or even on the correct side and you don’t need to be moving at all to have the tack completed. At that point the other boat is the overtaking boat and needs to avoid you as you get up to speed. If you happen to be inside the zone there needs to be room below you so that a boat can get through to the mark and you can’t cause the boat to go above close hauled if they decide to go over you. Do I have it wrong? | | | Re: Hobie 16 Open in Kingston - event has started
[Re: h20racer]
#186198 07/26/09 11:45 AM 07/26/09 11:45 AM |
Posts: 894 Branford, CT | I’m not sure about the sword and shield stuff. The rule book makes no mention of those items. Regarding the subject of tacking in front of a starboard tack boat the rule is not that complicated. (Getting the facts nailed down off the water does tend to be complicated.) Consider a port and starboard tack boat (Rule 10 we understand) Port must keep clear of starboard. Then what if the port tack boat begins a tack? The boat is still on port tack until she is head to wind (still Rule 10). When she reaches head to wind she is tacking (Rule 13) until she is on a close-hauled course (defined by the direction the boat is pointing). During this time the tacking boat must keep clear. When the tacking boat reached a close-hauled course Rule 13 stitches off and Rule 12 goes into effect. That is provided the starboard tack boat is still clear astern of the boat that just tacked. At this point the boat clear ahead (the one that just tacked) has the right of way. But because she gained the right of way by her own actions she must make sure the boat behind has room to keep clear (Rule 15). What this means is that once the tacking boat is on a close-hauled course on starboard the boat approaching from behind must maneuver promptly in a seamanlike way to avoid the boat that tacked. Now if the boat behind had to start avoiding before the tacking boat was at close hauled then the tacking boat fouled. Also if the boat from behind didn’t start to avoid until after the tacking boat was on close hauled but had to do so in an un-seamanlike way to avoid collision then the boat that tacked also fouled. But if the boat from behind begins to avoid when the tacking boat is on close-hauled and is able to avoid her by maneuvering promptly but in a seaman like way then there is no foul. | | | Re: Hobie 16 Open in Kingston - event has started
[Re: rhodysail]
#186201 07/26/09 12:10 PM 07/26/09 12:10 PM |
Posts: 894 Branford, CT | SECTION A RIGHT OF WAY
A boat has right of way when another boat is required to keep clear of her. However, some rules in Sections B, C and D limit the actions of a right-of-way boat.
10 ON OPPOSITE TACKS When boats are on opposite tacks, a port-tack boat shall keep clear of a starboard-tack boat.
11 ON THE SAME TACK, OVERLAPPED When boats are on the same tack and overlapped, a windward boat shall keep clear of a leeward boat.
12 ON THE SAME TACK, NOT OVERLAPPED When boats are on the same tack and not overlapped, a boat clear astern shall keep clear of a boat clear ahead.
13 WHILE TACKING After a boat passes head to wind, she shall keep clear of other boats until she is on a close-hauled course. During that time rules 10, 11 and 12 do not apply. If two boats are subject to this rule at the same
15 ACQUIRING RIGHT OF WAY When a boat acquires right of way, she shall initially give the other boat room to keep clear, unless she acquires right of way because of the other boat’s actions.
Keep Clear One boat keeps clear of another if the other can sail her course with no need to take avoiding action and, when the boats are overlapped on the same tack, if the leeward boat can change course in both directions without immediately making contact with the windward boat.
Room The space a boat needs in the existing conditions while manoeuvring promptly in a seamanlike way.
[Re: brucat]
#186261 07/27/09 11:10 AM 07/27/09 11:10 AM |
Posts: 3,293 Long Beach, California | My rules come in a little book... where are you guys getting these cool shields and swords??
The tacking-too-close interpretation has evolved in the last few years, and in a good way I think. It used to be that the fouled boat almost had to make contact in order to prove someone had tacked too close.
[Re: John Williams]
#186264 07/27/09 11:52 AM 07/27/09 11:52 AM |
Posts: 3,969 | My rules come in a little book... where are you guys getting these cool shields and swords?? I already answered that question...  I think it remains to be seen if "shield-based" is really the direction that PCs will actually go, or if that's just a guideline that the rule authors are trying to use. The truth of the matter is that all of the tactical seminars I've attended tend to be more "sword-based." Admittedly, I haven't been to one in a few years, but it's hard to imagine pro sailors getting paid to be defensive. Regardless of all of this, I think we have some marketing opportunities here (or at least a chance to have some fun). 1. We should cut some swords and shields out of the plastic they use for the PC hearing boats. (A long time ago, we should have at least made catamarans.) 2. We could come up with a cool logo for some T-shirts. Everyone knows cat sailors are basically pirates anyway! Mike | | | Re: Hobie 16 Open in Kingston - event has started
[Re: h20racer]
#186274 07/27/09 03:16 PM 07/27/09 03:16 PM |
Posts: 833 St. Louis, MO, | Looks like Rhodysail has it exactly right.
What I see a lot of is someone tacks in front of someone near A mark. The person behind has time to avoid as long as they start avoiding as soon as the boat starts it's tack. The problem being that they shouldn't have to start to avoid the boat until the tacking boat has completed it's tack.
I don't quite understand why the rules people put in the phrase "above close hauled". I think that gets sticky a lot of times. Most boats don't have to go above close-hauled to avoid a tacker in the zone. Most boats at the end close to the mark start reaching some to get there. That leaves the door open for boats to tack in the zone.
Mike Hill N20 #1005
[Re: Mike Hill]
#186277 07/27/09 03:43 PM 07/27/09 03:43 PM |
Posts: 3,906 Clermont, FL, USA |
I'm not sure I agree with that statement. If you don't bang the corners it's a pretty easy exercise to sail a tight layline. Secondly proving someone didn't have to sail above close hauled could be a very tough nut to crack. Bottom line... coming in on the port layline and tacking at or inside circle with a crowd is a low percentage play and if you're in an aggressive fleet eventually you're going to get flicked. Oh! Whoever came up with suicide port... Brilliant!
[Re: brucat]
#186285 07/27/09 05:12 PM 07/27/09 05:12 PM |
Posts: 894 Branford, CT | So, what happened in the last race Bob?
Mike I just don't have anything nice to say about that one. BTW: Go to a team race or a match race with a shield and you will get killed. | | |
3,630
guests, and 121
