| sailing MATH!!! Ouch, it hurts!-! #185817 07/22/09 11:30 AM 07/22/09 11:30 AM | andrewscott
| andrewscott
Unregistered | I am a confused a bit... if i add a pig tail to my main blocks.. does it take less (or the same) amount of line to sheet in?
i.e. If i have 8to1 blocks and 3' of line (between the traveler and main blocks).... and i add a 1' pigtail.. then i have 8x2' of line to pull.. this is 1/3 less. wouldn't i have 1/3 less movement (pull) needed to move the boom the same amount (downwards toward the other block) as if didn't have a pig-tail?
OUCH MATH HURTS MY HEAD!
| | | Re: sailing MATH!!! Ouch, it hurts!-!
[Re: ThunderMuffin]
#185820 07/22/09 11:43 AM 07/22/09 11:43 AM | andrewscott
| andrewscott
Unregistered | you'd need less
but then you wouldn't be able to get the boom as low as without the pigtail. How would a pig tail (hanging below the boom) effect the location of the boom/sail clew? | | | Re: sailing MATH!!! Ouch, it hurts!-!
[Re: ThunderMuffin]
#185823 07/22/09 11:56 AM 07/22/09 11:56 AM | andrewscott
| andrewscott
Unregistered | Gotcha
but if i went anywheres near block to block i would have a shredded mainsail... (or bent mast)
[Re: ]
#185827 07/22/09 12:57 PM 07/22/09 12:57 PM |
Posts: 1,200 Vancouver, BC | This would limit how much you could sheet in the main...once you reach block to block you'll still have the pigtail between upper block & boopm...so sail would not be as tightly sheeted.
There is no difference in amount of purchase, so sheeting 8 feet of line generates 1 foot of boom movement with either setup.
Your question was "amount of line to sheet in"...if you start from fully eased and go to fully sheeted (main flat)...then yes, a strop/pigtail will decrease the line needed...because you're getting a head start...upper block already the strop length off the boom. Becareful not to set the strop too long...as you'll not be able to sheet in enough. Also, if hte aim is to trim off some extra mainsheet. becareful not to go too far and limit how much ease out you can do.
My new boom has an internal cascade 9:1 setup. It is the best main sheet I've ever experienced. The efficiency of the cascade over a traditional triple/quad block setup is remarkable. But, it is limited in how far out it can be eased (dictated by length of the boom and the internal moving block..not a 1:1 relationship either). The block haning off the boom travels towards the boom while sheeting, and reaches a limit at the boom...thus limiting maximum sheet in. This takes careful tuning on the setup to arrive at the highest main tension needed.
Mike.
[Re: Rolf_Nilsen]
#185829 07/22/09 01:22 PM 07/22/09 01:22 PM | andrewscott
| andrewscott
Unregistered | Thanks Mike Boy those Norge's sure spell funny (PIIIICCCTUUUURRREEESSSS )  | | | Re: sailing MATH!!! Ouch, it hurts!-!
[Re: Rolf_Nilsen]
#185830 07/22/09 01:23 PM 07/22/09 01:23 PM |
Posts: 1,200 Vancouver, BC | PIIIICCCTUUUURRREEESSSS MIKE! Pretty please with suger and spice Well OK, but only cuz of the sugar & spice! Actually, I don't have any detail shots showing the mainsheet system yet...but here is a link to a shot of the boom proper: Boom My setup is basically identical to this: Only that one uses custom carbon block plates. We have a standard Harken single ratcher w. becket for the lower and another off-the-shelf wire block at the upper. One sig. diff. is that my upper is just a single block without a becket, so I do not have the third blue line coming down to it like this example. I have not dismantled the internals yet to see exactly what's inside...but the two outer turning blocks at the aft end are homemade/custon delrin sheaves...large diameters (& kinda heavy) with lubed bearings turning on 1/4" bolts. The whole boom weighs about 2.5 lbs (~1 kg) less than my quad block setup...that's huge!
[Re: Tornado]
#185834 07/22/09 01:45 PM 07/22/09 01:45 PM | andrewscott
| andrewscott
Unregistered | | | | Re: sailing MATH!!! Ouch, it hurts!-!
[Re: F18_VB]
#185892 07/22/09 09:23 PM 07/22/09 09:23 PM | andrewscott
| andrewscott
Unregistered | Adding a pigtail will reduce windage and weight (marginally) because there will be less line. However, there will be more drag because the blocks will be closer together. An 8:1 mainsheet does not keep each pulley perfectly in with the line. This causes friction because the pulleys press against the side and torque. Bringing the blocks closer increases the missalignment. Its not a big deal until you get close to block to block. Good info, thanks I have a few feet between beam and boom... all good. Harken actually has a min working range (18" if i recall correctly) for their 57mm ratcho-blocks. At least thats what i recall from a murray's catalogue i used to have Again thanks to all for the input
2,592
guests, and 551
