| New BIMARE Javelin 16 is fitted with an hooter! #18590 04/14/03 05:10 AM 04/14/03 05:10 AM |
Posts: 26 | Hi all I am pleased to announce you that the new BIMARE Javelin 16 will be officially launched next Saturday at the Vele di Pasqua Regatta scheduled at Cesenatico (Italy) from April 19 through 21, 2003. It will come ex factory fitted with a furling gennaker. For pics see: www.bimare.netThe boat does not comply with the new F16 rule, anyway it is likely to become the fastest 16 footer on the market. BIMARE boatyard is willing to constitute an one-design class as soon as that a fair number of boats will be sold. Anyway they have already got 6 orders before the launch. | | | Why does it not conform to F16 Rules?
[Re: Maurizio]
#18591 04/14/03 08:43 AM 04/14/03 08:43 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Thanks for the post, but it leaves me wondering.., where does it not comply with present F16HP rules? I further wonder if it is the same reason my Taipan 4.9 does not comply -- the Hooter! or roller-furlling genaker! If that is the reason, I am totally behind a move to allow this type of sail, although my arguments have thus far have fallen on deaf ears. The answer is to simply remove the mid-girth requirement rule. The sail area is probably less with the Hooter or Genaker than the spinnaker, so there is no sail size advantage. And the roller-furling is very much easier to deal with on a single-handed boat. Rick | | | Re: Why does it not conform to F16 Rules?
[Re: RickWhite]
#18593 04/14/03 11:03 AM 04/14/03 11:03 AM |
Posts: 9,582 North-West Europe | rick,
Your comments haven't fallen of deaf ears, the class has only decided against it.
There are some major drawbacks of the hooter you know !
How about trying to win the Texel race or Carnac under ISAF handicap rule with a rating that is significantly faster then ALL other beach cats available and with which YOU'll have to give a beefed up tornado spi 3 minutes time on the finish line. Now the Taipan is fast but not THAT fast. And that is only with a 10 sq. mtr. hooter. Now try a bigger one => 5 minutes time to the intl. tornado with spi.
And that is one reason.
Another is the fact that the F16 class wants to be the light to medium crew weight alternative to the F18's and be able to race them first in wins at club races ands sorts. They feature spinnakers and not Hooters. If we wanted to be fastest class around then we would have build a class around the ARC-26 boat or club Med.
The class decided in favour of the assymmetric spinnaker a while ago and we are not going to force all the members to buy new headsails because the fashion just changed. This maybe okay for other classes but this is not what the F16 class is about.
Some builders won't garantee their product with hooters on them when they will with spis.
All (safety ?) considerations that I think a class should take seriously.
Sorry Rick, no matter how much I personally would like to experiment with a hooter it is not going to be in the F16 any time soon.
| | | Congrats
[Re: Maurizio]
#18594 04/14/03 11:14 AM 04/14/03 11:14 AM |
Posts: 9,582 North-West Europe | Congrats,
I will be looking for those regatta pics !
Just curious ; is this the offical Bimare line ?
| | | Well, it is quite logical really because ...
[Re: carlbohannon]
#18598 04/17/03 01:21 PM 04/17/03 01:21 PM |
Posts: 9,582 North-West Europe | The Girth rule clearly defines what is regarded to be a spinnaker which head sails are nothing more than very large jibs.
To give ane example. Lets say we fit a hooter or rather a reacher to a uni rigged boat. As jibs and Reachers are not celarly defined under the Portsmouth system I can choose to use the lower modification factor of a reacher for my very large jib. Okay I will get into a big argument with the race organisors but what is there to prevent me from declaring my reacher to be nothing more than a large jib
US sailing definition of small jib :
"boats with standard jib tacked to bridal wires and hoisted to or below mast hounds"
US sailing definition of a large jib :
"boats with foils or jibs with tack attached to the deck or from cross beam and/or head attached above mast hounds"
Now my reacher is not fitted to either a deck or crossbeam nor does it really need to be hoisted below or to the mast hound. I will just fit a piece of dyneema line as a make beleive forestay while my reacher luff is actually taken the true loads.
This way it will not be difficult to fit my uni rigged boat in theory with a "reacher" by fitting what actually is an oversized jib hoisted only 2 inches above the mast hounds. I fly this baby both upwind and downwind and only have to take a 2,9 % hit instead of 6,3 % hit for a large jib.
This way I can easily design a rating beater by introducing alot more performance than I get compensated for in the rating. And this is exactly why Texel and ISAF systems hold onto their definitions and regard 0-75 % girth headsails as jibs.
In fact it is more fair this way.
Now with regard to the Texel and ISAF hits, well a beach cat doesn't sail well with a 10 sq. mtr. (100 sa. mtr.) jib. This is just poor designing. The rig is out of balance. Texel and ISAF don't care wether you build your hulls like a rectangular brick they just state the maximum expected performance for a given waterlength, weight, sailarea, crewweight and sailplan. That some designers try to do the equivalent of fitting Nascar 600 hp engine to a Ford Pinto platform and not account for the inbalances is just considered bad designing. You have all the ingredients to go fast, lightweight, small surface area and a huge engine but other aspects are preventing you from obtaining that performance. Things like drive (fragile) shafts when you put 600 HP through it.
Now in theory a 10 sq. mtr. jib can add alot of extra performance. The practical implication is however that such a jib is out of place on our small beach cats.
Is this fair, well one can argue convincingly that even bad designs need to be rated accurately and I agree with that. This is a drawback ot the texel system.
On the other hand however I agree with the Texel and ISAF systems that we don't make this system more fair by knowingly give a superlarge jib (but deceivingly called a reacher) a slower rating than it is known to be able to sail to.
I mean the spinnaker hit is determined on the fact that it is carried only on downwind courses. Now imagine carrying the same sail upwind. Clearly the basis on which the modification factor is determined has no been lost.
I for one would stress for a different modification factor which is to be used for reachers (hooters) that would solve all our problems.
With respect to the Tornado, I'm sure the guys at texel would not give the standard int. Tornado rating to that boat. Class rules will not help the Tornado with reacher in this respect. And Again that would be fair I think. However, more fair would be to have a reacher modification.
I'm also sure that you would win an appeal in the US as the PN system definitions allow you to use the more favourable modification factor.
With respect to F16 class rules; we will not take out the Girth rule as neither the F18, iF20 (inter 20) and also the F18HT class rules have this rule in them.
Maurizio is once again mistaken by saying that Bim could fit hooters or reachers to their jav 2's.
Under F18HT rules they can't.
I quote rule 2 of the F18HTclass website "... Spinnaker must satisfy the following SMG >75 %* SF ..."
Now I welcome anybody who is willing to experiment with these sails to do so and hopefully they will share their info with me.
Some already have and I must say these experiences were very interesting.
With respect to popularity in Europe of these sails. Well they are widely used on ocean going designs like the ORMA tri's.
With respect to beach cats. I may be able to table this issue in the Texel committee, but for now a reacher is not what you want to have when you sail in abig event like Texel or Carnac.
| | | Same applies to ISAF handicap rating.
[Re: Eric Anderson]
#18599 04/17/03 01:25 PM 04/17/03 01:25 PM |
Of course we have a few other designs that can't sail to their rating. And there are more causes to this than just the reacher issue.
Again, Texel and ISAF rating give a prediction on the maximum obtainable performance when the performance potential can be fully utilized. Not all boats can under all conditions.
But this is a topic for the future.
| | | Re: New BIMARE Javelin 16 is fitted with an hooter!
[Re: 49er]
#18601 04/17/03 03:19 PM 04/17/03 03:19 PM |
Posts: 12,310 South Carolina | Is there any other beach cat available that comes factory with a hooter? I can't think of one. I personally think that it's a great sail but understand the complications associated with rating it fairly. Kind of like trying to rate all sorts of apples and oranges so they all taste the same - can't do it. However, I would be shocked if Bimare doesn't have or quickly develop an F16HP compliant package for their boat - it would only make sense for them to open their boat up to that class as well. Unless they're skered!  I am all for seeing formula develop in the U.S. but even though we have some groups touting the logos, it's all still one design. So how about it Bimare? I love the idea of a factory hooter equipped boat but why not step up and make that boat available as F16HP compliant and give us at least one class that is a real "formula"?
Jake Kohl | | | Re: Well, it is quite logical really because ...
[Re: carlbohannon]
#18605 04/18/03 02:26 AM 04/18/03 02:26 AM |
Posts: 9,582 North-West Europe | Sorry I misunderstood your post. As far as I'm aware Texel does not link any rating directly to the class compliant boats. A class can leave the sail area unspecified is they want to but they can not get a class rating then. In that case each boat has to be measured and a different rating has to be calculated. Or the maximum dimensions found will be used to rate all baost in that class. http://www.texelrating.knwv.nl/getanumber.htmlThe Texel rating tries to determine the fastest possible speed for a given set of basis parameters. With respect to your tornado question I think that all Tornado's with the named sails will be rated the same as long as the girth rule is satisfied. The one which doesn't gets a different rating number. We are talking handicap racing here and although it may be fair to rate tornado's with rather equal sail equally, it will be unfair to bend the rule in case of one class in relation to another that does satisfy the Girth rule. A no win situation, I admit. Its unfair to other designs when you rate them equally (PN) and it;s unfair to that class when you don't (Texel). Wouter
[Re: 49er]
#18606 04/18/03 02:45 AM 04/18/03 02:45 AM |
Posts: 9,582 North-West Europe | Man, it must really be going badly in the other class as we're at the "lets bash Wouter and his dumb class" again.
And than I'm predictable.
Answer to -1- Well DUH !
Answer to -3- Yeah right ! And 7 at the Aussie event, 5 to be at the South African Event this weekend and working on South Asia. Glenn Ashby sponsored our Aussie perpetual trophy and MAN ! This class is really going down the drain. Hell we're closer to ISAF status than any other of the newly formed classes. I'm getting really scared now. BWAHAHAHAH !
>>If Wouter were smart he would welcome the Jav 16s into his class, if they agreed to sail with spinnakers only.
Indeed !
Answer -4- Good question !
| | | And here are Valerio's Petrucci (Bimare) comments
[Re: 49er]
#18607 04/18/03 03:27 AM 04/18/03 03:27 AM |
Posts: 9,582 North-West Europe | 4 dec 2001
Part of the e-mail Communication between Valerio Petrucci of the Bim yard and myself.
"Wouter, a few years ago, we tried to start a BIM 16 class, but without too much success. Therefore is no use sending you its class rule. The first BIM 16 had a main of 11 sqm, then 12,50 sqm, then 13,50 sqm before reaching the actual level for the 2001 version. The same was for the gennaker. Valerio"
Even Maurizio never claimed the Bim 16 design (!) to be older than 1991 (12 years = a few years ?)
It is common knowlegde that the concept of the Taipan was first floated in 1985 by Greg Goodall and Jim Boyer. And it was launched on Easter Sunday 1988, 15 years ago this weekend. If anybody pioneered this type of craft and made it succesful than it is AHPC.
Beyond a shadow of a doubt it is the F16 class which is also know under the name F16HP that succesfully set up a FORMULA class around these craft with more than one builder making compliant designs. We soon welcome the third (or forth if Bim still wants to play along) and that means TWO fully optimized designs and one very competative foundation design in the shape of Taipan 4.9 with spi.
The fact that there wasn't a single rating in both ISAF and Texel as well as PN and VYC (Eu, USA, AUS) under the name Formula 16 or F16 prior to our ratings (in contrast to say the F18HT's) is more than indicative of the fact that the "old F16 class" never existed. Which seems to be confirmed in writing by the comments of the person who of all people should be in the know.
Now, I have nothing but respect for the Bimare Yard and father and son Michelangelo - Valerio Petrucci and they have given me none other than dependable information.
My problem is with the well known proxy mouth pieces who seem to knowlingly spread information that is noticably in contradiction with the truth and comments from more dependable sources. And who can argue with with the source named at the beginning of this post ?
Now, I was under the impression that we had a defacto truce. Or shall I start quoting more e-mails and ask questions like why the much heralded Javelin wave peircer design is finishing where is does in the A-cat class itself where the Flyer wave peircer is found on places 1,2 and 3 ?
I was pretty content with the truce actually; I trust you were too.
We may all be living in glass houses but some of us are living class manors.
| | | F16, Bimare F16, Javelin16, and F16HP
[Re: Wouter]
#18608 04/18/03 07:39 AM 04/18/03 07:39 AM |
Posts: 52 | Wouter,
Regarding you comments about the origin of the F16 class, I have a print of a F16 by Bimare from the 1995. I understand that the originia BIM 16 (1991?) was not heralded as a F-16, but please name another F16 cat that predates the 1995 Bimare F16. I know that Cirrus, Mystere, Ventillo, and others build "F16" cats, but not to your rule. Pathetically, You just try to lump them into your class in an attempt to legitimize your class. I applaud you efforts in forming the F16HP class, but you insistance in grouping other designs into your class is laughable. Only Stealth Marine builds a F-16HP. Taipan (AHPC) builds 4.9s and will provide a "F-16HP-ize" version, but their main thrust is the 4.9 Class. The other 16 foot designs that you have tried to group into your "class" were not built to your rule. Face it your rule is largely ignored by the builders.
In the USA, there has not been one successfull F-16HP regatta! Three or four boats at the North Americans? What a joke! None stayed to the end of the event. You tout the Australian event, but even tht event garnered less than 10 boats.
Like the man, Rick White, pointed out in a previous post you and your class shold spend more time sailing and racing than posting. Your performances on the water confirm this keen observation. Maybe you should put away your typewriter and go to a Rick White Siminar.
Got to go-SAILING, so bye-bye for now.
49er | | | This getting rediculous !
[Re: 49er]
#18609 04/18/03 12:43 PM 04/18/03 12:43 PM |
Posts: 9,582 North-West Europe | >>>Regarding you comments about the origin of the F16 class, I have a print of a F16 by Bimare from the 1995. Show it to us please and name the mainsail area that it featured at that time. Please remember that I actually HAVE a bim 16 in the Dutch class at this time, and I know every measurement of it. And while you're at it please name the MASTLENGTH that was featured in 1995 too. I predict you will either lie or not answer the questions. Then I'll invite you to visit the ONLY independent confirmation that exists on the web of a Bim 16 as it was at that time. http://www.schrs.com/schrsratings.asp?id=allAnd what do we see there ? No it can't be ! a platform that is full compliant with the F16 rules. Yes that is right MY F16 rules. The second mentioning of a BIM 16 on the web by an independent party, The Texel committee is a one-off modified BIM 16. Hell it even says "ONE-OFF" in the rating table and is actually called a "Bim 16 special". And would you just have it that that particular Bim 16 is involved in the Dutch start-up ! In 2000 and 2001 I look hard of this ghost rules and you know what. Nothing could be found in either English or Italian. I gave up looking for them after I received valerio's mail which pretty much said to me "Don't bother". Later when I discovered the multiple setups with different mastlengths, mainsail area's and spi area's I understood why. There was no common rule which was agreed upon by multiple builders and there never has been one too. In my case there are. AHPC has provided input and has agreed, Stealth did the same and also launched a F16 in 2002 and a third party was also involved and will launch in 2003. THAT is what makes a FORMULA class. Multiple designers and builders working together to build a common class. And what surprises me all the time is that Neither ISAF nor Texel measurement ever refer to a BIM F16, but always to a Bim 16. I mean, could it be that we are all mistaken and that it has been Hobie F16 all along instead of Hobie 16 !? THAT dog don't hunt my dear. >>Face it your rule is largely ignored by the builders. Well there is only one builder ignoring my rule dear and it isn't Ventilo (Compliant), Mattia (compliant), Taipan (Compliant), Stealth (compliant), Blade (Compliant), hell I have even discussed the class with Cirrus and they are taking this seriously. >>In the USA, there has not been one successfull F-16HP regatta! Oh well the first F18HT event was a big DUT then as we were at the same event and had just as many boats (when NOT counting the Isotopes). We were less loud, I admit to that. And what is worse, YOU KNOW ALL THIS ! We had this talk several times before. But still, you and your companions seems to have a thing for the F16 class. I don't know why. Could it be that ...? Nah ! >>>None stayed to the end of the event. No, none of us stayed to the end of YOUR event , remember that we shortend our event that time and did so well before the event happened ? High school must have been darn difficult for you. >>You tout the Australian event, but even tht event garnered less than 10 boats. Well we had more than you had at your nationals ! And I mean both classes that you have expressed to participate in. >>Like the man, Rick White, pointed out in a previous post you and your class shold spend more time sailing and racing than posting. The much respected Rick White has never expressed anything of that sort. This another one of inventions. And I'm delussional !? Now I think the Jav 16 is a intriguing design and I have no problem with it launch and if you guys want to have your own class, ALL BY YOURSELF, than that is fine with me. But despite this the fact of the matter remains that there was no old F16 class establish prior to my F16 (which is rather OUR F16 class). Our class rating in all the major handicap systems prove this and so do the comments made by Bimare yard. That you have a thing for me personally, well, I'm even okay with that as long as you don't start inventing history or even "a present". I'm looking forward to those 6 jav 16's coming to the USA and I hope to welcome them at a F16 regatta some time in the future. If they are in time they can even participate for a charter slot in the 2005 F16 World challenge. Just like that Dutch "Bim 16 special" will be doing. And that is what I think about letting Bims into the F16 class. Not that it will stick in your memory because I'm sure I can expect another outrage at my class and rule in say 2 to 3 months time. Ahh well, as long as the other forum participants know what your grasp on facts is. Wouter
2,456
guests, and 291
