| Re: Tell me about the Prindle 19
[Re: ferminj]
#187072 08/05/09 02:03 PM 08/05/09 02:03 PM |
Posts: 1,203 uk | How did you get the deck off?. A thin chisel or paint scrapper, and a hammer! Be ready to take a mold off of the other hull's deck if you wreck this one getting it off
[Re: TurboCat]
#187081 08/05/09 02:42 PM 08/05/09 02:42 PM |
Posts: 1,403 | VMG is correct. I used a Putty knife with a thin blade. I tried several tools and the thin putty knife worked the best for me. I started at the front and worked my way backwards. It came off pretty well and didnt get too messed up. You can order new decks from Performance for $98 each. I ordered new ones rather than making my own since i dont know alot about glass. After i reinforce the hulls im thinking of smoothing the bows. My 5.2 has had the bow decks filled and its stiffer than stock and looks great! I am still trying to decide if i want to go this direction though because once they are filled and smoothed future repairs are much harder since you cant just remove the deck and order a new one. TAKE PIXS. And, is that $98 for a set or just one? | | | Re: Tell me about the Prindle 19
[Re: Tornado]
#187082 08/05/09 03:06 PM 08/05/09 03:06 PM | andrewscott
| andrewscott
Unregistered | [quote=andrewscott] Tornado stick is under 30'...29 and change. wow... we have a few mystere6.0's with t masts and i was told they are 31... odd | | | Re: Tell me about the Prindle 19
[Re: ]
#187084 08/05/09 03:11 PM 08/05/09 03:11 PM |
Posts: 67 Daytona Beach | According to Tornado.org waterline to top of mast max is 9800mm or 32.15 feet. What does the typical tornado measure from waterline to mast base?
Jeff Bowers Mystere 6.0(sometimes XL)
[Re: Ventucky Red]
#187091 08/05/09 03:51 PM 08/05/09 03:51 PM |
Posts: 149 | VMG is correct. I used a Putty knife with a thin blade. I tried several tools and the thin putty knife worked the best for me. I started at the front and worked my way backwards. It came off pretty well and didnt get too messed up. You can order new decks from Performance for $98 each. I ordered new ones rather than making my own since i dont know alot about glass. After i reinforce the hulls im thinking of smoothing the bows. My 5.2 has had the bow decks filled and its stiffer than stock and looks great! I am still trying to decide if i want to go this direction though because once they are filled and smoothed future repairs are much harder since you cant just remove the deck and order a new one. TAKE PIXS. And, is that $98 for a set or just one? That is PER side. $98 for each deck | | | Re: Tell me about the Prindle 19
[Re: ferminj]
#187111 08/05/09 05:22 PM 08/05/09 05:22 PM |
Posts: 1,403 | The decks am assuming are three part?. Forward of the front beam, center section and the little square portion aft of the rear beam. For $98 I think its a good price. I am also guessing theres a lip or surface where you can lay the new deck and epoxy to the hull. I would hate to think he is talking the front only? They probably have to make them special for this order.
[Re: TurboCat]
#187121 08/05/09 06:51 PM 08/05/09 06:51 PM |
Posts: 1,383 Kingston SE South Australia | I made the under deck support on my Stingray by putting 3 inch strips of divinacell foam inside the hulls just under the lip. I cut them longer than the gap so they flexed up to match the deck then put a bit of tape on with resin as I put the deck on. I also added another layer of divinacell foam under the decks. Since you are doing a special order have you considered asking them to do a double layer of foam or layer of carbon underneath the decks? The lips are firm enough, keep an eye on the weight your adding. regards
[Re: TurboCat]
#187123 08/05/09 06:59 PM 08/05/09 06:59 PM |
Posts: 1,403 | So my question is should the boat be braced like the front between the rest of the bulkheads? I would assume not since it wasnt designed that way but i want this boat to last me a long time so my ears are open. I dont want to take any shortcuts and want to do it right, do it once, and be done with it. I have another boat to sail so this project will not be rushed. Give me your opinions and let me know what u think.
I have been on other prindles that have flexy decks so i intend to add some bracing of some sort to support the deck more than it is now. The decks are held on by the edge only and seem to flex when stepped on. I would rather the decks feel solid and firm with little to no flex. Something else to think about, and maybe I didn't catch this earlier, and that is put in some tangs for you spinnaker bridals similar to what is being used on the Inter boats. | | | Re: Tell me about the Prindle 19
[Re: TurboCat]
#187147 08/05/09 10:54 PM 08/05/09 10:54 PM |
Posts: 1,200 Vancouver, BC | I have been on other prindles that have flexy decks so i intend to add some bracing of some sort to support the deck more than it is now. The decks are held on by the edge only and seem to flex when stepped on. I would rather the decks feel solid and firm with little to no flex.
Check out the photo section on the Tornadocat Yahoo forum...there's a nutty Aussie rebuilding his glass T boat in his living room. He's added lots of reinforcing including deck frames and gunwale stringers. TornadoCat Forum Photo Gallery
[Re: HMurphey]
#187181 08/06/09 09:28 AM 08/06/09 09:28 AM | andrewscott
| andrewscott
Unregistered | Hi TurboCat,
I'm not very good w/ computers, so I don't know how to "link" ..... Harry Harry you can just paste (or type) the link in here with your copy.. www.msnbc.com
[Re: ]
#187184 08/06/09 09:50 AM 08/06/09 09:50 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Not sure where the 29' measure comes from on the T mast. I measure from the top to the bottom of the mast section (not including the base) of a marstrom untapered aluminum section, 30'- 10 3/4". Now the luff of the sail may be around 29' but mast is about 31'.
The T chute and the N-20 chute may be the same area but the N-20 is a class sail built by one manufacturer. The T sail can be made flat or full and by anyone as long as it measures in.
[Re: catman]
#187185 08/06/09 10:10 AM 08/06/09 10:10 AM |
Posts: 1,200 Vancouver, BC | I stand corrected. For the carbon T, class rules state: Mast Length - - Upper point height - 9294 mm = 30.49' Note this refers to the upper measurement band max height (head of sail cannot be above this line), not the overall length of the mast. I think I was recalling the dimension between the upper & lower measurement bands, which is 8915mm or 29.25'. Not sure where the 29' measure comes from on the T mast. I measure from the top to the bottom of the mast section (not including the base) of a marstrom untapered aluminum section, 30'- 10 3/4". Now the luff of the sail may be around 29' but mast is about 31'.
1 registered members (edraciunas),
692
guests, and 347
